Author Topic: Woodpecker's Align-A-Saw  (Read 4089 times)
Offline 4nthony
    • Slack for Recon Tools
« on: March 14, 2023, 04:25 AM »
A few days ago, I received the Align-A-Saw kit from Woodpeckers. I've never had any table saw alignment issues but I've got some strong OCD tendencies so I placed an order when this was announced.
I set it up on my saw, grabbed my trusty Woodpecker's Saw Gauge 2.0, and started taking some measurements.
At the front of the Saw Plate, I set the gauge to zero.
I moved to the middle of the Saw Plate and the gauge moved very slightly + of 0
I moved to the back of the Saw Plate and my gauge moved to .004.
I moved the Saw Gauge to the opposite miter slot and took a measurement on the "rough side" of the Saw Plate.
At the front and set to 0.
Middle of the Saw Plate, just a hair -0 (-.0998?)
At the rear of the Saw Plate, (-.094-ish)
I noticed in the Deep Dive video, @jeffinsgf takes his measurement on the side of the Saw Plate without the logo markings.
I wanted another measurement with the rough side of the Saw Plate and the Saw Gauge back in the left miter slot, so I remounted the Plate.
At the front I set the Saw Gauge to zero.
I centered the Saw Gauge and the front half measured ~.0075 (sorry about the glare).
And finally, at the back of the Saw Plate, my measurement remained at .0075.
So it looks like I've got a Saw Plate that is incredibly flat for 6", then it goes beyond the tolerance for the remaining 6". According to the specs, the Saw Plate should have a tolerance of .002.
In the video, Jeff gets "about a thousandth of an inch" across the entire width of the Saw Plate.
Also, the rougher side of my Saw Plate has, what looks to be a faded sharpie marking of "344". No clue what that means but the number is very close to the .004 I got above (.00344, perhaps?).
Anyway, I'm not going to adjust my table based on measurements from this tool as I don't think my table is out of alignment enough to warrant an adjustment. As shown in the video, it would've been nice to see a near perfect measurement across the entire width of the Saw Plate rather than half of the plate. Or, a gradual increase from front to back and not from center to back.
Based on this unscientific review, I'll give this Woodpecker's product 2-1/2 out of 5 stars. :-)
Recon Tool Notifications
Anthony
Offline luvmytoolz
Re: Woodpecker's Align-A-Saw
« Reply #1 on: March 14, 2023, 04:44 AM »
Bit ruff to mark the dial gauge down because your saw plate isn't straight Anthony?
Offline Peter Halle
  • Ain't so Small no More
« Reply #2 on: March 14, 2023, 06:15 AM »
I believe he is rating the Align-a-Saw which has that metal plate; not the gauge.
Offline luvmytoolz
« Reply #3 on: March 14, 2023, 06:35 AM »
Ahh, sorry my mistake, that makes more sense now thanks!
Offline jeffinsgf
  • Woodpeckers Marketing Department
« Reply #4 on: March 14, 2023, 06:41 AM »
Do you have a stand or a 1-2-3 block where you could use your dial indicator to measure the plate with it flat on the table top? If it's out of spec, please get in touch with Customer Service.
Offline festal
« Reply #5 on: March 14, 2023, 07:43 AM »
if you have a surface plate and dial indicator you can sweep it and check.  clean the surface plate with IPA, put the indicator stand on it and sweep your plate with it see what readings you get
Offline Steve1
« Reply #6 on: March 14, 2023, 08:13 AM »
Is the gauge's round dowel sitting on the chamfer of the miter slot ?
I have seen similar gauges, and didn't like using the chamfer as a datum.   A chamfer is not a well controlled (toleranced) feature.
I made a similar gauge, but used a flat bar as a datum that contacts the face of the miter slot.   That means I have to push the gage towards the face of the miter slot - no big deal.
You might want to replace the dowel with a flat bar.
Also, you should put the saw blade on the arbor and check your blade lateral run-out.   I did that and found I had a run-out that moved with the arbor, not the blade.   A little sanding of the arbor washer, at the high spot got it much better.   (I call it washer, but it is one piece with the arbor)
The "saw plate" surface looks ground, which would make it very flat.   But if you want to check it, a piece of printer paper is about .002" thick.   You can use the table saw surface or other tool surface to check against.   Your table top won't be flat either, but you should be able to detect a consistent bend in the saw plate.
« Last Edit: March 14, 2023, 08:24 AM by Steve1 »
Offline derekcohen
    • In The Woodshop
« Reply #7 on: March 14, 2023, 09:07 AM »
The time to purchase a gauge like this is when your saw cuts are not square, and to find out why. Why do it otherwise?
Visit www.inthewoodshop.com for tutorials on joinery, hand tools, and my trials and tribulations with furniture builds.
Offline ChuckS
« Reply #8 on: March 14, 2023, 10:11 AM »
4nthony has done a public service, confirming what many of us know that if your saw cuts well based on the actual cutting results, you don't need to do anything else.
Even a perfectly-tuned machine can produce a less than perfect result because of wood itself and/or user techniques.
For my SawStop and Kapex, I checked their accuracy when I first received them (about 7 years ago) using test cuts. The SawStop passed the parallell, 90*, miter and bevel cuts (but please don't ask me the tolerance of those test cuts as I don't know). The Kapex passed the bevel and 90* tests, but not the miter test. It took me a couple of hours and tons of scraps (because I didn't know about and watch Katz's tune-up video) before I could fix it.
Since then, I haven't done any adjustments to them as periodic checks on the cut pieces show they hold up their performances. The only adjustments done have been to the miter gauge or pointers/cursors.
« Last Edit: March 14, 2023, 10:16 AM by ChuckS »
Offline 4nthony
« Reply #9 on: March 14, 2023, 04:32 PM »
My rating of 2.5/5 in the first post was meant to be a bit tongue in cheek because half the plate is great, the other half, not so much. Take the average...there you go.
I have a 38" Veritas aluminum straight edge and a WP 1-2-3 setup block. I was not able to slip a piece of paper under either, anywhere along the Saw Plate.
The large dowel sits on two smaller dowels. The smaller dowels center the large dowel in the slot.
I will check this later today.
Some video observations:
This is a fairly new Ridge Carbide 40T Box Joint Blade. The gauge starts at 0 then gradually increases ~.002 at the arbor and coming to a stop a .003.
This is the Saw Plate on the smooth (logo) side. It starts at 0, wobbles a bit around 0 until center, then climbs to .005.
This is the Saw Plate on the rough (non-logo) side. It starts at 0, gradually increases to .008 at center, then comes to a stop a .007.
This is the Saw Plate on the rough (non-logo) side. I set the Saw Gauge to 0 at the center/arbor. It starts at -.092, hits 0 at the center, then comes to a stop at -.099
I sketched some exaggerations of the results. I would've expected the Saw Plate to have a more gradual change across the entire width, as was the case with the Ridge Carbide blade.
I don't know where my discrepancy is. Assuming a perfect Saw Plate, my miter slots would be shaped like a hockey stick. The hockey stick reverses when I reverse the plate, so my guess is the miter slots are fine. I can't find any gaps in the Saw Plate but the gauge still shows a hockey stick measurement. When measuring blades, the measurements are mostly gradual.
The Saw Gauge 2.0 has been a very useful tool and I'm glad I have it. I always check my table alignment after I trip a brake and it comes in handy for checking my fence from time to time.
As for the Align-A-Saw Plate, well, it wasn't something I needed. I wanted it because I wanted it. But I didn't need it.
I took some measurements with two more blades and also got fairly consistent results.
Examples:
Freud thin kerf: 0, .001, .001
SawStop 80T Titanium: 0, .002, .099
This blade has slightly raised lettering near the center which may have skewed the center reading. I placed the gauge between letters as best as I could.
Maybe I'll reach out to WP customer service and get their thoughts on the matter.
Agreed 100%. My takeaway from all this is that I need to stop buying tools that I think I need, that I think are cool, or that I think will help me achieve perfection in my woodworking.
The more I chase and fail to achieve perfection, the more frustrated I get, and the less fun this hobby becomes.
Anthony
Offline montyss
« Reply #10 on: March 14, 2023, 05:23 PM »
Take 2 more readings .. mark the Ridge carbide blade and your your saws arbor .. take a reading then rotate the arbor 180 deg to your mark on the blade and check your measurement again. See what the result is ? Report back
Offline derekcohen
    • In The Woodshop
« Reply #11 on: March 14, 2023, 07:51 PM »
Exactly. Plus check the mitre slot. There are a number of possible reasons why a reading can vary.
The easiest way to check the blade is to use the saw to make a few cuts. Measure the saw cuts for accuracy.
Offline 4nthony
« Reply #12 on: March 14, 2023, 10:19 PM »
The Ridge Carbide, marked and measured at the front, then rotated 180° and measured at the back, is toed out .005" away from the fence.
This is within the tolerances of ≤ 0.010 for a SawStop PCS, per the video:
As I mentioned in my first post, I'm not planning on adjusting my table at this time. I'm happy with the quality of cuts I'm getting.
What I'm curious about is why the Saw Plate measures < .001 for the first 6", then for the next 6", gradually toes out .005"?
Why am I seeing a curve:
And not a line:
Yet I can't detect any curve in the Saw Plate using my Veritas straight edge (the Veritas has a .003 tolerance across its length).
Anyway, I reached out to Woodpeckers via their contact form. I'll update if I get a response.
Anthony
Offline PaulMarcel
    • Voilà, my blog
« Reply #13 on: March 15, 2023, 01:55 AM »
I have their 1.0 version. It didn't come with the test plate. I like that addition; with the blades, I've had a few with a wobble in the plate that messes with the numbers until I rotate the blade and start over.
Offline jeffinsgf
« Reply #14 on: March 15, 2023, 06:29 AM »
Paul, the plate is a new product. Launched just a few weeks ago.
Offline montyss
« Reply #15 on: March 15, 2023, 06:58 AM »
Anthony did you loosen the arbor nut and then rotate the blade to be 180 deg from the orig marks for those measurements ?
« Reply #16 on: March 15, 2023, 10:27 AM »
I haven’t read the whole thread carefully so some of my comments might be redundant.
I checked my main Forrest blade several years ago and found the position on the arbor that yields the least runout and marked the blade, arbor and washer so I can get back to the optional relationship when I change blades.
Later, when I wanted to make sure the miter slot was parallel to the blade (I use the fence on both sides of the blade) I used a straight edge against that adjusted blade and measured between the straight edge and the miter slot. I wedged a straight piece of flat stock in the miter slot and checked to make sure the stock remained straight. I’m never go to do that again! My old Walker Turner saw is a royal pain to adjust. The trunnions hang from the table so they have to be adjusted  [crying]
The WP plate might not be perfectly flat but a piece of paper is at least .004” thick. If you have a good straight edge test with fine feeler gauge.
If you want to use the miter slot to test the WP plate you have to test the miter slot first. Fix a straight edge as close to parallel to the miter slot as you can and then run the indicator along the straight edge with the plunger riding the upper part of the miter slot, since that is the part the the WP rod rides. You’ll probably have to make or buy a rig that can hold the indicator at the appropriate angle.
Offline Steve1
« Reply #17 on: March 15, 2023, 11:16 AM »
When I first checked my table saw, I found the alignment with the miter slot was not very good.   And it really didn't have provisions for adjustment.   The spindle assembly was bolted to the table top through clearance holes, and already pushed over as far as it would go.  I had to neck down the mounting screws to give some more adjustment.
Also found some wobble in my blades that I was able to mostly get out by sanding the appropriate spot on the arbor face. (The arbor, not the blade, was the problem)
So it is worth going through the exercise of checking.
« Reply #18 on: March 15, 2023, 11:46 AM »
Actually Woodpecker's implementation is quite clever. The large dowel/cylinder mounted to the bracket sits on 2 smaller dowels/cylinders that travel in the miter slot. Any variations in the miter slot width may cause the 2 small dowel pins to move from side to side, however the large dowel pin will always remain centered between the 2 smaller dowel pins thus the centerline of the miter slot is always the datum line. A really simple & reliable method for sure.  [smile]
Offline 4nthony
« Reply #19 on: March 15, 2023, 01:10 PM »
I did not. I left the arbor nut tight and only turned the blade 180°. I checked the runout on the arbor itself and the gauge barely moved. Like 1/10th of .001". The very slightest of movement. I'll do it again.
Long story short, I bought a thing. My expectations of thing were X. My reality was Y. Expectations > Reality.
Currently trying to figure out how to accurately measure thing to see if it's in spec or out of spec.
Realizing none of this is all that important (my saw was already within spec using implements other than thing), convincing myself to stop falling for thing marketing, and to no longer buy things I don't need. :)
When I was into photography, I believe my behavior -- obsessing over mystical numbers -- was called "measurebating".
Anthony
Offline Chainring
« Reply #20 on: March 15, 2023, 03:04 PM »
Alright, Anthony. How many corner sharpness tests have you done? Multiple focal lengths and apertures? I know that one all too well.
Offline jeffinsgf
« Reply #21 on: March 15, 2023, 03:23 PM »
I'm going to mention something I ran into while working on the Align-A-Saw video, while trying to get the saw in my shop under .001" (something I would not recommend to anyone no matter how OCD).
If I ran my angle and/or height adjustment all the way to the stop and locked it, I would get a different reading than if I brought it to the stop and then just removed the backlash and ever so slightly released the tension against the stop.
I mention it because the error was weirdly non-linear, like you're seeing.
I've made the tension release part of my routine when making adjustments, and it seems to be yielding consistently better results.
« Reply #22 on: March 15, 2023, 03:36 PM »
Jeff, that's also what the Saw Stop video is referring to...if I understand both comments correctly. The Saw Stop comment comes at the 2 minute mark of the video.
« Last Edit: March 15, 2023, 03:39 PM by Cheese »
Offline Birdhunter
« Reply #23 on: March 15, 2023, 09:28 PM »
I found a lot more variation in the miter slot to the SawStop Industrial fence than in the miter slot to the blade. My guess is the there is more blade deflection in the wood while cutting than the measurements being discussed here.
If I need a high precision cut, I make the first cut proud and then make the final cut to the exact desired dimension. In no case do I expect metal machining accuracy for wood cuts.
Birdhunter
Offline jeffinsgf
« Reply #24 on: March 15, 2023, 09:48 PM »
Apparently I stumbled into a known issue without knowing it.  [big grin]
Offline box185
« Reply #25 on: March 15, 2023, 10:29 PM »
I think Steven Woodward also discovered this problem.
Offline ChuckS
« Reply #26 on: March 15, 2023, 10:31 PM »
Snip
This is within the tolerances of ≤ 0.010 for a SawStop PCS, per the video:Snip.
I didn't know about the tolerances for the PCS until now.
I know my PCS cuts really well, and have never had any ripping issues. But curiosity drove me to do an alignment test based on the SawStop video.
Tools used after cleaning and marking the tooth (WWII blade)                                                   Result
The above was repeated one more time, and a similar result was obtained.
Even allowing for some checking inadequacy, the 0.001 to 0.0015 deviation proves the saw (miter slot to blade) is perfect in practical terms.
« Last Edit: March 15, 2023, 10:47 PM by ChuckS »
Offline 4nthony
« Reply #27 on: March 16, 2023, 01:43 AM »
I've given up on on the Saw Plate.
I backed off the height as Jeff suggested and that improved the tooth to tooth alignment on a couple saw blades.
- My 40T Ridge Carbide tested above improved to .004".
- The 80T SawStop and the Freud thin kerf improvements were <.001"
- My 24T Woodworker II improved from .004" to .003"
However, measurements from the Saw Plate were basically the same; Very little movement from 0 - 6", then a curve.
Hopefully I'll hear back from WP customer service in the next day or two.
Anthony
« Reply #28 on: March 18, 2023, 12:10 AM »
Hey @4nthony,
I just looked at the Woodpeckers Align-A-Saw video and noticed that they use a 2-step grinding process. The first step is for an outside service to blanchard grind the saw plate and then the saw plate is brought in-house where it is surface ground. To put things into perspective, blanchard grinding is a process used to get material surfaces "close" to flat while precision surface grinding is a process used to get surfaces "perfectly" (within .0005" to .000001" or less) flat.
Blanchard grinding is typically used to condition a flywheel or pressure plate surface and thus a surface flatness of .002" to .004" would be good enough given the end use of these items.
When I first looked at your photos the other day, the first thing I noticed was the strong blanchard grinding marks on your saw plate and thought that was unusual because they were deeper/more defined than they should be which would skew your indicator readings.
However, now knowing that Woodpeckers utilizes a double grinding process, I think your saw plate was blanchard ground and for some reason never went through the final surface grinding operation.
Blanchard grinding will leave circular grinding marks on the surface, while precision surface grinding will leave long parallel grinding marks on the surface. I'd have a long conversation with Woodpeckers about this because there is no area that I can see on your saw plate that has been surface ground.
Here's what your ground saw plate looks like.
And here's what a surface ground plate should look like. This is certainly not the best example (rather crude really) but it does show the straight line grinding pattern that's missing from your saw plate.
« Last Edit: March 18, 2023, 12:34 AM by Cheese »
Offline 4nthony
« Reply #29 on: March 18, 2023, 02:00 AM »
Hey @4nthony,
Interesting find. There's a night and day difference in the two sides of my plate. The side with the logo is so smooth that the dial indicator left a bunch of streaks. The other side, with the faded sharpie numbers, not so much. In the Deep Dive video, Jeff uses both sides to take measurements. And if both sides are supposed to be surface ground, then you're right in that mine missed a step.
I was out in the garage OCD'ing over this tonight, because, Saw Plate...
I also saw their "production update" video, and it's mentioned that the tolerances are "one-thousandth of an inch", not the .002" on the website description.
Though, what caught my eye was the guy measuring flatness:
A lightbulb turned on and I realized what Jeff meant when he said:
Quote
I rigged up my dial indicator onto a piece of scrap and clamped it as snug as possible to the 1-2-3 block. I slid the block along the table and noted some deviation.
Then I started thinking my tables are probably not perfectly flat and maybe the 1-2-3 block is riding across undulations in the table. Do I want to check every inch of cast iron to look for a perfect 12" section that I can use to check if the plate is flat? How far down this rabbit hole do I want to go?
I still haven't heard back from Woodpecker's customer service, though this isn't the first time I've tried to contact them via the website and didn't hear back. I'll pick up the phone on Monday and see where it gets me. Hopefully the person I get on the phone will also know the difference in grind types.
Thanks @Cheese !
Anthony
