Author Topic: Track Tubes MFT top  (Read 28973 times)
Offline John Russell
Re: Track Tubes MFT top
« Reply #60 on: May 06, 2021, 10:51 AM »
I am missing something about attaching the Dashboard rail clamp to the TrackTubes or are you using something attached to the Tracktube to hold the Dashboard clamp?
Offline DynaGlide
« Reply #61 on: May 06, 2021, 10:55 AM »
See Reply #45
Instagram @matts.garage
« Reply #62 on: May 06, 2021, 12:25 PM »
Thanks, but bear with me here, but the general idea is that the Tracktubes function as the base for the top which overlaps the Tracktube.  Then the T15 extrusion is attached flush to the edge of the table and then the Dashboard clamps attach to that.  I assume you could also use Rob's https://dashboardpws.com/products/universal-track-star for cuts as well?
Offline DynaGlide
« Reply #63 on: May 06, 2021, 12:58 PM »
@John Russell Correct. I suppose you could, I don't own that product from Rob. My setup, I drop the fence in, attach a guide rail, square it up and go. I know @Grev just uses dogs now. I prefer having a pivoting guide rail and fence.
With the way my table is setup the guide rail gets registered against two dogs the same every time. The fence is always dropped into the same two dog holes using benchdogs.co.uk fence dogs. I have a calibrated measuring tape applied to my fence. As long as the guide rail is tight to the two dogs when I put it on, then the whole thing is square and calibrated.
Offline festal
« Reply #64 on: September 26, 2021, 08:59 PM »
So I finally started to do the bottom for my tracktubes top.
I went with kreg 64” x 28” universal bench.
My question is how do I secure tracktube extrusions to the metal frame? Not sure what connector to use.
Also I was thinking of doing melamine or plywood on the top of the bench and putting tracktubes on top of that
Here is a mock up
This way I can use the gap for fence, track storage etc and keep the dust away from the inside where I’m planning to put a cabinet with drawers
Any suggestions on which way to go and what top to use?
Offline Bugsysiegals
« Reply #65 on: September 26, 2021, 09:28 PM »
Are you alright with a few holes in the top of the table?
I attach my fence to my Parf table using  Parf Anchor dogs.  You could attach them to the bottom of these rails and then just drop them in place when needed. The downside is the rails would have the PAD’s attached all the time and you’d have a few holes in your top … I’d solve the holes with a 3D printed plug when not in use.
https://www.axminstertools.com/us/ujk-technology-parf-anchor-dogs-106323
Offline festal
« Reply #66 on: October 04, 2021, 11:01 AM »
Thats not a bad idea.  I have track dogs that i might use for this.
« Reply #67 on: November 20, 2022, 08:22 AM »
I’m considering a set of TrackTubes but hesitant on the 90” since they wouldn’t fit in the bed of my pickup if I ever traveled with them. Does anybody with 72” set regret not getting the 90” set?
Offline Mike Goetzke
« Reply #68 on: November 20, 2022, 09:50 AM »
I bought my tubes few years ago before the t-track was added to both sides. I'm a hobbyist working out of a garage shop and the 90" is perfect for setting up an 8' long work table using 3-mft style slabs but for around the house they were too long so I bought a second set and cut them in two (50" pair and 40" pair). One set for a single slab top and the other for a two slab top.
Mike
« Reply #69 on: November 20, 2022, 12:21 PM »
is there any difference between these and regular aluminum extrusion?  Perhaps wider so they don’t wobble in sawhorses?
Offline tsmi243
« Reply #70 on: November 20, 2022, 03:00 PM »
That's basically it, they're sized to fit a standard sawhorse notch without wobbling around.  It's essentially just a 2x4 that won't warp or splinter.  They're VERY straight, too.  I think 200 bucks is totally fair, but not everybody will.  Kinda like another brand you might have heard of.....
To your other question, if your truck holds more than 72", I'd get the 90's and cut em down to whatever your max length is.  There's nothing magical about the 90" dimension.  Closer to 96, the better for holding a full sheet, that's all.
Offline cdconey
« Reply #71 on: November 20, 2022, 07:48 PM »
You can offset the tops cantilevered on the 72" to whatever length you need.   For an 8' work top that would only be 12" on each end of the 72" rails.
I have the 72" and think they are fine for an 8' top.  I haven't had any issues  using the 72" on an 8' OAL top.
I have 5 top sections total for a variety of worktop surfaces that I can use for multiple configurations and also made a top for my Conturo edge bander so it fits between the rails and can use my other sections for the extension on the conturo top.
The dangers of cut & paste.....
« Reply #72 on: November 20, 2022, 09:03 PM »
Thanks for sharing, so you have pics?  I’m wondering if it wouldn’t be better for me specifically to use the 1.5” thick aluminum extrusion i used to build an outfeed table since it has the side slots which fit my dashboard hinge rail …
Offline Mortiser
« Reply #73 on: November 20, 2022, 10:00 PM »
With the 90" rails you can cut a foot or so off of each end and then make sliding extensions. Remove them and use just the center sections of the two rails if you want a shorter set-up. The extensions allow for a lot of extra length options and store away inside the longer sections for transport or storage. If you don't need optional space, I think you would be fine with the 72" length for cutting full sheets of plywood.
Sliding crosspieces allow for lots of flexibility. Sacrificial strips help when using the tracksaw.
I bought mine before the track on the bottom was added. I remember when receiving mine, I thought to myself, it sure would be nice if they also put a track on the bottom. Three months later, they did. That's one I wish I'd waited on a little longer. But then, isn't that always the case regarding upgrades.
« Reply #74 on: November 21, 2022, 08:32 AM »
Really slick, I like what you’ve done there!
Offline Grev
« Reply #75 on: November 21, 2022, 04:17 PM »
TRACKTUBES were originally designed (by me) so I could have a quick and easy setup to use with my folding sawhorses and an MFT top.  I wanted a hollow core for telescoping extensions and tracks that would fit my Festool track clamps (as well as others I owned).  Since my top extended over the edges of tubes, I just attached a bracket to the edge so I could use my guide rail hinge.  I now attach a length of 1010 series t-slot extrusion, so I have a full length t-track on both sides and it also serves to keep the top flat when storing.  Super quick to set up/take down and it all stores flat on the wall.
« Reply #76 on: November 21, 2022, 06:34 PM »
Very nice, I bought a set of 90's!  Now do I get rid of my Dewalt Toughbuilt for Portamate's or are these not much different besides the name?
Offline Mortiser
« Reply #77 on: November 21, 2022, 09:51 PM »
Glen has done some really nice things with TrackTubes. Of course he had a head start over all of us ;).
If you are going to get some folding sawhorses, I'd look at the Ridgid at Home Depot. I like them better than the Stanley/DeWalt as they have a 2x4 top which can be switched for any width you want. Plus the top can be easily replaced if it gets cut up and you can easily clamp things to it; something you can't do with the plastic folding models. And the release for the leg height adjustments is half as much effort as the DeWalt.
Enjoy your TrackTubes!
Offline Grev
« Reply #78 on: November 22, 2022, 12:25 PM »
Any sawhorses will do .. I personally use both the folding DeWalt and BORA Speedhorse.  I like the Speedhorse because they are 42" wide ... similar to the ToughBuilt I think?  I added a T-track to the top which makes them much more versatile and I can use the tubes and some brackets to position the tubes the distance apart I need them.  See the photos.
« Reply #79 on: November 22, 2022, 02:34 PM »
That's quite the setup, thanks for paving the way for me!!
Offline rvieceli
« Last Edit: November 22, 2022, 03:35 PM by rvieceli »
