I have a love/hate relationship with that piece of gear. I know I should use a blade guard, and the SawStop is one of the few I've been able to keep in place for more than a day or two. I love the dust collection efficiency of the guard. I have it hooked up to an extractor with the 4" lower outlet connected to a dust collector. The first problem I have with it is, when you lift the guard when the vac is running the port seals itself. With a direct connection to the vac, it just makes a funny noise (the same one it makes if you put your palm over the end of the hose). But, if you have a Dust Deputy attached, it will collapse your 5 gallon bucket in a hearbeat.
Next is offcuts being trapped within the guard. If your rip offcut is less than about an inch wide, it's captured between the blade and the guard with no way to retrieve it without shutting off the saw. If it's long enough, you can reach behind the saw and pull it out, but that's dicey and usually pushes the offcut into the back of the saw.
Finally, the thing is worthless if you're trying to rip something narrower than 1-1/4". Wait a minute...when am I most likely to NEED a blade guard? Right...when I'm ripping something narrow.
I will say that in just shy of 50 years of using table saws the SawStop guard is the only one that has ever made it back onto my saw after the first time I took it off. I'm pretty sure that has more to do with dust collection than safety, though.
