Author Topic: Nova Voyager Drill Press  (Read 31343 times)
Offline ear3
Re: Nova Voyager Drill Press
« Reply #240 on: August 03, 2019, 04:32 PM »
Brilliant job @Jiggy Joiner .  Can you provide some additional info on the hand wheel crank?  That looks like a great solution.
Offline Jiggy Joiner
« Reply #241 on: August 03, 2019, 05:29 PM »
Thanks Edward, the wheel is aluminium, 120mm diameter (4-1/2”) It came with a 12mm centre hole, so I drilled it out to 14mm, then drilled the side of the boss, and tapped an M6 thread to take the original lock screw and nut from the crank handle.
It works well, the table needs a little lift with my other hand whilst cranking, for elevating. That could be from the extra weight of the additional table though? Lowering is easy, just the one hand.
I would like to source a steel wheel, and I think up to 5” diameter would be ok, depending on the table design.
The thing with a 4” to 4-1/2” wheel though, would allow for a deeper table to wrap around the pillar more.
I worked out how big I needed my table to be before starting, and it’s so far been more than big enough.
I was going to use the table from my old press but, it needed a fair bit of modifying, so I decided to just start from scratch but, glad I did now.
Offline ear3
« Reply #242 on: August 04, 2019, 08:38 AM »
Lol, I also started to type a question about how you got you managed to modify your DP with such a monster 12" quill travel -- and then I realized where you were writing from.
« Reply #243 on: August 04, 2019, 10:15 AM »
Jiggy...FWIW...when it comes to tooling components such as drill bushings, spring plungers or hand wheels these are my go-to people.
Jergens:
http://www.jergensinc.com/Handwheels-Handles-x20-And-x20-Knobs
Carr-Lane:
https://www.carrlane.com/en-us/product/handles-knobs-screw-clamps/hand-wheels
Winco:
https://www.jwwinco.com/en-us/products/1.3-Adjusting-with-handwheels-and-cranks
Kipp:
https://www.kipp.com/gb/en/Products/Operating-parts-standard-elements/Handwheels-crank-handles-position-indicators.html
McMaster:
https://www.mcmaster.com/hand-wheels
« Reply #244 on: August 04, 2019, 01:12 PM »
@ear3  lol Edward, imagine having that kind of quill travel!  [blink] [big grin]
@Cheese Thank you very much Cheese, I was struggling to find a decent one, I rang an engineering company who had one but, wouldn’t post, they were 150 miles away. The one I bought was clearance stock at an Axminster branch, so I’ll study those links.
Many thanks.
« Reply #245 on: August 04, 2019, 01:56 PM »
That kind of quill travel...
Between the on axis movement of both the table and quill support you can drill a hole about 3 feet deep. Now in storage in Jersey City.
« Reply #246 on: August 04, 2019, 02:29 PM »
Wow! What’s the runout like on that machine Michael?
« Reply #247 on: August 04, 2019, 03:48 PM »
Never measured, but could probably check it with a grade school ruler.
« Reply #248 on: August 04, 2019, 04:26 PM »
Yeah, I love the old presses, we still have an old Fobco that runs well, I think it’s older than me?
They knew how to build them in those days.  [thumbs up]
« Reply #249 on: August 05, 2019, 08:05 AM »
All I know about the Voyager is that I absolutely love mine!
« Reply #250 on: August 29, 2019, 10:27 AM »
Well after the Rohm chuck situation, there was a wait for inspection and refund etc.
So I then ordered the Albrecht, and it didn’t arrive at the stated time. The supplier said there was a hold up in Germany because of their shut down period, and did I still want one, or a refund.
I figured it would be difficult to source one elsewhere without a wait, so I said I wanted it and would wait a little longer.
Anyway, it arrived today, and it’s a nice bit of engineering, and I’m now glad I had the Rohm issue, as in my opinion, this is a better chuck, and by quite a margin.
I’ve mounted it onto a Rohm arbor, as I just could not get an Albrecht. I’m very pleased with it, it’s the finishing touch the Voyager needed  [thumbs up]
« Last Edit: August 29, 2019, 02:09 PM by Jiggy Joiner »
Offline rvieceli
« Reply #251 on: August 29, 2019, 10:49 AM »
You will certainly enjoy using it.
Offline msc
« Reply #252 on: August 29, 2019, 11:03 AM »
@Jiggy Joiner Ime in Uk as well, just wondering where you purchased from?
Ime after a used drill press (probably Meddings) and all I’ve seen have keyed chucks.
« Reply #253 on: August 29, 2019, 02:11 PM »
Thanks.
@msc I bought it from Knighton Tools, and dealt with John
There was one on ebay last week stated as new.
Offline msc
« Reply #254 on: August 29, 2019, 03:20 PM »
@Jiggy Joiner could you send a link please? I have seen one but looks like a weird arbour. I assume arbour can be removed and i morse taper put on? Sorry I don’t know much about pillar drills as I’ve just used cheap machine mart Clarke type ones in past. I do know meddings are engineering quality hence looking out for one on ebay in single phase (missed out on one last week)
Thanks for the supplier info
« Reply #255 on: August 29, 2019, 03:28 PM »
@msc Yes Meddings and Fobco, Startrite all made really good drill presses. We have an old Fobco that’s still going strong.
Do you mean a link of the chuck?
Offline msc
« Reply #256 on: August 29, 2019, 03:39 PM »
@Jiggy Joiner yes one on eBay and/or the one you bought.
I’ve had a look on Knighton tools website and there so many different ones and kind of appears there’s different  chucks for different arbours
« Reply #257 on: August 29, 2019, 03:55 PM »
Yes mate, they are all different sizes and fitting. Some have integral Morse tapers too.
Mine is a B16 2MT
That means the end of the arbor/morse taper, that goes up into the drill’s quill/spindle, is 2MT fitment size, the other end of the arbor/morse taper that goes into the chuck, is B16 size/fitment. My chuck takes 3-16mm drill bits.
My chuck, is 15th down the list, the last one before the integral chucks:
http://www.knighton-tools.co.uk/acatalog/ALBRECHT_CHUCKS___JAW_SETS.html
This is the one on ebay:
https://www.ebay.co.uk/itm/3-16mm-Albrecht-Precision-Keyless-Drill-Chuck-B16-Taper/143204264134?hash=item2157a3a8c6:g:8uoAAOSwWkFcqM2p
Offline msc
« Reply #258 on: August 30, 2019, 11:23 AM »
@Jiggy Joiner thanks for enlightening me on this. I didn’t realise there was so much to chucks! I just remember the term morse taper and thought this was standard for pillar drills. I think I’ll have to keep looking for the drill and then upgrade the chuck.
« Reply #259 on: August 30, 2019, 12:29 PM »
They say a drill/jigsaw is only as good as the bit/blade. The bit part still applies to a drill press (pillar drill) but once you need a stationary drill (as opposed to holding a drill by hand) you really want the bit to spin true and that’s where the superior chuck comes in. Even then you need spend enough to get a sufficient straight quill for the chuck to engage.
« Reply #260 on: August 30, 2019, 01:45 PM »
@msc You’re welcome mate, it sounds a bit confusing but, makes sense once you delve into it.
I very nearly bought the chuck with an integral arbor but, that would have limited my use of it on other machines. With a different arbor, I’ll now be able to mount it on another machine if needed.
If you can pick up a decent Fobco Star drill press, they are an extremely good engineering drill press. Meddings are also superb, original Startrite are another.
@Michael Kellough I totally agree, the chuck and arbor that come standard on the Voyager, are usable but, seem to made from cheese or chocolate, the metal is very soft.
Offline 08G8V8
« Reply #261 on: December 05, 2019, 06:35 PM »
Mario
Here's the stand I made for my Voyager drill press.
Drawers are on full extension slides.  Rear sides have adjustable shelves for additional storage.
Mobile with four fixed wheels to pull forward.
Rubber pads can be screwed down to hold the unit in place under the press, though it does not move with them up.
I purchased the wheels and pads from McMaster.com
Wheels - https://www.mcmaster.com/#2781t72/=1e9mktj
Pads - https://www.mcmaster.com/#6103k167/=1e9ml41
Photos:
(Attachment Link)
(Attachment Link)
(Attachment Link)
(Attachment Link)
(Attachment Link)
(Attachment Link)
The table was made from phenolic ply.  I cut out the right rear corner to give me maximum table size but still allow the table adjustment to work.
Light is a magnetic base from Lee Valley that attaches to the fence.
(Attachment Link)
Sketchup Plans are available on the 3D Warehouse. HERE
They are also attached as a zip file below.
neil
Neil, where can I get this hose attachment?
