Author Topic: new bandsaw  (Read 2783 times)
Offline donduck2
new bandsaw
« on: December 23, 2020, 01:26 PM »
I am thinking of replacing my old 14inch delta with a new bandsaw.  The rikon 324tg sounds interesting. Anyone have one or have an opinion?
Offline Bob D.
Re: new bandsaw
« Reply #1 on: December 23, 2020, 03:05 PM »
Don't know about the 10-324 but I have had the 10-325 for over 10 years and no problems. I have done a few upgrades but never had a mechanical breakdown or any other issues other than a drive belt that needed replacement due to age.
I upgraded the guide bearings and also replace the motor with the DVR motor. What a huge improvement that made. MY saw is now about the same as the 10-326DVR in features and power. I don't see me needing to replace this saw any time soon for my home shop use.
I do wish it had a safety interlock on the doors and a foot brake, but other than that I'm OK with it for the money. Paid $699 for the saw in 2006 plus the guide bearing kit was $99 and the DVR motor was a big chunk at $599 (in 2018) but worth every penny. I bet it would not be too difficult to fit that DVR motor on many 14" to 16" bandsaws. The DVR motor gives you infinitely variable speeds from 50 to 4000 FPM so you can cut plastics and metals with the right blades of course.
Offline festal
Re: new bandsaw
« Reply #2 on: January 10, 2021, 05:03 PM »
Did you use the rikon dvr upgrade or aftermarket?  can you post a link?  hard to swap?  I was looking at 10-326dvr but its a bit expensive.
Offline Bob D.
Re: new bandsaw
« Reply #3 on: January 11, 2021, 05:52 AM »
Yes, I used the Rikon 13-926 DVR motor upgrade kit.
https://www.rikontools.com/new-rikon-smart-dvr-control-motor-model-13-926
It was not cheap, about $600 IIRC (looking at their site just now looks like $699US from Striatech, slightly less at other sources).  The 1.75HP/1250W motor kit from Striatech is available with either a NEMA 56C or B14 Metric motor frame.
So between that and what I paid for my 10-325 I spent as much as the newer 10-326DVR bandsaw, actually probably a little more when you throw in that I upgraded the guide bearings to the new style that are on the 10-326. During the course of upgrading my BS I went over everything. My BS now runs rock steady and smooth. It has more power, MUCH more, and variable speed from 50 to 4000 FPM where before it was a choice of one of two speeds on a stepped pulley.
So I would say looking at it purely from the numbers, if you already have the 10-325 the upgrade might be worth it. I do believe it would be possible to mount the DVR motor on another brand saw. You would most likely have to adapt the mount, but that shouldn't be too tough.
The DVR motor kit is made by Striatech for Rikon.
https://striatech.mybigcommerce.com/shop-all/
I decided to take the chance of the Rikon upgrade kit as I have the NOVA DVR Lathe and it has performed over the 10+ years I have owned it. And NOVA has stood behind the tool. I contacted them once about 8 years after I got the lathe when I found out there was an upgrade to the control board. After sending them my serial number they sent me a new control board which was easy to install, simple plug and pray and I was up and running in 10 minutes.
Do a Google search on "Rikon DVR motor upgrade" and you should find some more info.
« Last Edit: January 11, 2021, 06:03 AM by Bob D. »
Offline Birdhunter
Re: new bandsaw
« Reply #4 on: January 11, 2021, 06:57 AM »
I have the Powermatic 14" and its been a great saw. Comes with a dust blower.
Birdhunter
Offline festal
Re: new bandsaw
« Reply #5 on: January 11, 2021, 07:25 AM »
Thank you.  I don't have one but it seems that going for the 326dvr might be better option then getting another one and upgrading.  going to be around same cost.
Offline Bob D.
Re: new bandsaw
« Reply #6 on: January 11, 2021, 09:24 PM »
Yes, if you already have a rikon it would be worth doing the upgrade on the motor. If you don't have any BS at present and you choice boiled down to the Rikon then the 10-326DVR would be a good choice provided it's capacity met your needs.
Offline festal
Re: new bandsaw
« Reply #7 on: January 18, 2021, 08:06 AM »
No Bandsaw yet.  Defintely leaning towards DVR version so I can do both wood and metal on it.
Re: new bandsaw
« Reply #8 on: January 18, 2021, 10:28 AM »
Then consider finding saw blades that are the same thickness for both wood & metal. That way you don't need to change the saw blade guide adjustment.
Offline Bob D.
Re: new bandsaw
« Reply #9 on: January 23, 2021, 05:45 AM »
I am curious about the dust blower. Is it hype or does it really provide a benefit as in is it effective.
Then my second question is what makes it tick. Seems like it would be simple to add to most any BS but I say that with no knowledge of how it works. I was thinking of an aquarium air pump that started/stopped with the saw might do the trick.
« Last Edit: February 08, 2021, 01:34 PM by Bob D. »
Offline CeeJay
Re: new bandsaw
« Reply #10 on: January 23, 2021, 04:24 PM »
I find the dust blower on the PM 14” is pretty useful. It has to be really close to the cut to work - I have it right in front of the guide bearings down low.
It’s powered off the main drive motor.
Offline CeeJay
Re: new bandsaw
« Reply #11 on: January 23, 2021, 04:27 PM »
It’s powered off the main drive motor. There’s a small air pump running off the main drive pulley.
Offline Bertotti
Re: new bandsaw
« Reply #12 on: February 08, 2021, 10:06 AM »
Out of curiosity what is it with the old bandsaw that makes you want to change? Just worn or is there a performance feature that it doesn't have or didn't live up to your expectations.
I want to populate SD with trees becasue I miss the forests of the river bottoms.
Offline TXFIVEO
Re: new bandsaw
« Reply #13 on: February 14, 2021, 07:12 PM »
I recently purchased the Powermatic 14” and it works outstanding.
