Author Topic: Milwaukee 12V Compact Air Compressor  (Read 17472 times)
Offline Shane Holland
  • Festool Dealer
Re: Milwaukee 12V Compact Air Compressor
« Reply #30 on: September 26, 2018, 05:06 PM »
Toolnut still has a store?  I thought that they went to all internet sales.  @Shane Holland ?
@Peter Halle, yes, we still have a store that serves walk-in customers.  [wink]
And, we've sold a lot of these inflators. Dewalt has one now too.
« Last Edit: September 26, 2018, 05:08 PM by Shane Holland »
877-866-5688
Offline Z48LT1
  • My excuse is I never expected to be caught.
« Reply #31 on: September 26, 2018, 06:36 PM »
My $.02US: the problem with ignoring the first TPMS warning is that the next thing that may happen is the rim ruining the tire when the tire actually loses all its pressure which can happen before you know it.  So I'm with Peter_C in reply 5 about having a 12V air compressor in each car to determine whether the TPMS warning is real or not immediately.  My choice is this $35 gem from Amazon: https://tinyurl.com/y8lztqod.  It has the Milwaukee compressor's feature of shutting off when the digitally set pressure limit is reached.  It is powered by a standard 12V cigar lighter type plug.  It does have a screw-on tire valve attachment but releases only a very brief "pffft" when unscrewed.  It's quiet and remarkably quick in topping off standard car tires; I haven't tried to inflate fully deflated tires or used it to top off truck tires.  Comes in a tidy zip-up vinyl bag with simple instructions and inflator adapters for the usual non tire inflatables.
Offline Peter_C
« Reply #32 on: September 26, 2018, 10:41 PM »
Not long after this thread was started I bought a small Viair compressor for our little car. Also picked up a plug kit, and one of those small lunch boxes from Costco. The lunch box is pretty small and padded, so it holds the compressor, the plug kit tools needed, a few pairs of latex gloves, and two pairs of pliers, dikes and a pair of pliers to pull the screws/nails. Very compact, and because it uses the cars battery I never have to worry about swapping batteries, as it could be years before I use it. Compressor doesn't do any good if you don't have a battery with enough charge to fill a completely deflated tire.
https://www.amazon.com/gp/product/B005ASY23I/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Plug patches installed from the inside are a requirement in most states for tire shops, with plugs not being allowed. In all my years of experience with plugs I have seen them fail due to improper installation, causing a slow leak. Of course I have seen interior patches leak too. Flats tend to not happen very often with good quality tires and I am okay with plugging them myself and not driving on a mini spare.
FWIW always put a mini spare on the rear of the vehicle, and move the rear tire forward if need be. Has to do with braking and steering. How many people routinely check their mini spares to make sure they are at the recommend 60 psi?? Yeah some vehicles still come with full spares, but they are far and few between.
Offline RKA
« Reply #33 on: September 26, 2018, 11:39 PM »
On a related note, if you want a good plug kit to pair with your inflator, this is the ticket!  Between my neighbor and I, we have used 6-7 in the last 2 years.  Not a single leaky plug!  In his case, he usually tries with his auto store kit and one of two things happen.  The tool bends or the plug leaks before he gets the wheel back on the car.  If either of those happens, he calls me, I bring over the safety seal kit and in 10 minutes it’s all done, no leaks.  The plugs are better, the tools are better and the lube does help.
https://www.amazon.com/Safety-Seal-KAP30-String-Storage/dp/B001DIECCK/ref=sr_1_4?s=automotive&ie=UTF8&qid=1538018776&sr=1-4&keywords=Safety+seal
The only negative is the reamer is on the large side, so you’ll need the wheel off the car to put your weight into it.  Forget about laying on your side and trying to plug a tire still on the car.
-Raj
Offline GoingMyWay
« Reply #34 on: September 27, 2018, 08:16 AM »
My wife recently had a screw in one of her tires.  Luckily it was a slow leak so she was able to just keep putting air in it until she could take it to the gas station down the street to be fixed.  The shop just used one of those plugs to fix the hole rather than a patch from the inside.  I guess I could have just bought a plug kit and essentially have done the same thing (though I've never done it before, but it seems pretty straight forward).  Obviously the plug is a lot easier and faster considering you often probably don't even have to take the wheel off of the car.
Are plugs really that dangerous?  It seems like plugs have been used for a long long time and only more recently (maybe past 15 -20years?) have I started hearing about these vulcanized patches that are applied from the inside.  Patches also seem like another upsell that a shop or store will force you to buy along with a nitrogen fill.
Does anyone have any recommendations for an inexpensive tire pressure gauge?  My wife wants one for her car after her recent leaking tire problem.  I have this Michelin: https://www.amazon.com/gp/product/B00139YMUQ/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1 and it works fine.  I don't use or have a need for the programmable target pressure, but I know it works well just a little more expensive than others.  Anyone have any experience with either of these cheaper gauges:
https://www.amazon.com/gp/product/B07255XLG5/ref=ox_sc_act_title_4?smid=A3COC6SF6EGCHZ&psc=1
https://www.amazon.com/gp/product/B01J8DLGU2/ref=ox_sc_act_title_3?smid=A2NOFZGOKNP3PJ&psc=1
It doesn't look like the cheaper units specify their accuracy.  The Michelin says it's accuracy is "+/- 1% plus 0.5 PSI" - maybe it's really not that serious and does not even need to be that accurate as a few other posters have mentioned they're not overly concerned about tire pressures on a car.  I used to use those cheap stick gauges for the longest time and that seemed to be good enough also.
Inquiring Minds Want to Know
Offline pixelated
« Reply #35 on: September 28, 2018, 03:17 PM »
I've been anxiously awaiting the DeWalt unit to become available, I have 4 battery systems already  [scared], and I don't need a 5th. Plus the DeWalt adds some versatility in that it can be powered from a tool battery or wall plug, or a vehicle battery.
Offline RKA
« Reply #36 on: September 28, 2018, 04:43 PM »
@GoingMyWay The patches are unlikely to leak since they are applied from the inside of the tire and the pressure of the air is effectively pushing it into the hole.  All other things equal, that would be my first preference.  But...
With the plug, you usually get a fixed size plug and have to ream the hole in the tire first, often expanding the hole (so the plug will fit) and abrading the inside of the hole to provide a little tooth for the plug to grab.  It can take a bit of force to jam the tool in there and ream it enough so the plug and other tool will fit.  I've had problems with cheaper plugs and tools and this method does run the risk of doing damage to the internal construction of the tire, though I've yet to see it myself.
With quality plugs and tools, I can deal with it at home in 30 minutes and it never leaks again.  It costs me nothing over the initial investment in the plugs and tools.  With a patch, I have to take it to a shop, I'm at the mercy of their workload, at a minimum they have to take the tire off the wheel (or at least break the bead), reinstall and rebalance the tire (most shops will rebalance unless you ask them to mark the tire and wheel and reinstall in the same location).  Around me, low profile tires can run up to $30 or more for a mount and balance.  The cost is fine, but losing 90 minutes watching an 18 year old kid learning to use the tire machine and scratching my wheels isn't fun.  So, for convenience, I'll just plug it myself and move on.
-Raj
« Reply #37 on: September 28, 2018, 07:22 PM »
That’s funny...just had that experience myself last week.
Offline RustE
« Reply #38 on: September 29, 2018, 11:23 AM »
@GoingMyWay, I give people Milton S-921 or S-925 pencil gauges as gifts.  My next choices are the S-923 straight pencil gauge or the S-931 dial gauge.
I've owned some dial gauges in the past that were difficult to use because of their shallow head.  Basically you couldn't get the gauge aligned well before pushing it on the valve stem and frequently had leaks.  The S-923 straight pencil gauge is probably the easiest to align and use on automotive tires.
@RKA and @Cheese, had a young guy at a tire shop install the wrong shape of wheel weights.  The wheel weights were not sitting flush on the rim and probably would have flung off at some point.  Went back to get the problem fixed but they tried to tell me it was not a big deal.  After a conversation with the manager I got the correct wheel weights installed and a refund.
Offline leakyroof
« Reply #39 on: October 09, 2018, 09:33 AM »
   These ARE nice, we used to use them all the time at work, but then were required to switch to the Combo Patch/Plug repair pieces. I still have them, and generally I've never had one leak on me once installed, but a patch on the inside is preferred or even required now in many places.
 I save mine for when I'm on the road and getting to a shop or my work is not an option at the time.
 NAPA also sells a much better quality all metal reamer and install tool set than the small, plastic tools that commonly come with the inexpensive plug kits.
 You get a much more comfortable handle style to work with and more leverage.
 One bad caveat to installing Patches over a plug is the new style' Quiet Tires' that are around now. Basically a 1/4" to 3/16" thick layer of foam is installed on the inner tread/carcass side of the tire, glued with what appears to be a butyl rubber adhesive to the tire. Trying to hack through that and get a smooth, non-glued surface to apply a patch can be very time consuming. I know Continental Tires uses this as a option[ Conti Silent Tire ] and I suspect other tire makers could move to it if it catches on.
Offline DynaGlide
« Reply #40 on: October 09, 2018, 10:37 AM »
@GoingMyWay I caught a screw in my Subaru ~15k miles ago. Not wanting to replace all 4 tires (necessary for AWD vehicles), I put the spare on and drove home and got out my tire plug kit I keep for my motorcycle and plugged the tire and put it back on. Haven't had a problem since.
Instagram @matts.garage
Offline GoingMyWay
« Reply #41 on: October 09, 2018, 10:42 AM »
Thanks for those suggestions.  I ended up just buying the Michelin Gauge since she's familiar with using mine.
Yup, I think the plugs are pretty much as good as the patches in most situations.
Offline travisj
« Reply #42 on: November 24, 2018, 01:14 AM »
I came to this thread late, but I appreciate the review on the compressor.  I definitely see one of those in my future.  It would be ideal for the kids bikes, lawn tractor, etc...
A couple of comments
Nitrogen is much more stable than compressed air.  I know it had been available for passenger vehicles for quite some time, but it has been used in racing applications for quite awhile.  I know several drag racers (cars and bikes) that run it because it less susceptible to temperature effected pressure changes.
Aluminum wheels are notorious for not holding pressure.  The expansion, contraction, and corrosion rates are all significantly higher than steel.
I have installed several nitrogen generators in a previous career.  When I installed draught systems, if a bar would go through enough Guinness, it would be in their favor to install a generator and a mixing valve to get the proper 75% N to 25% CO2 ratio to push the liquid without over carbonating.  The ones we installed were based off of a normal-ish looking air compressor and ran $3-5k.  Since there is a small percentage of nitrogen in the atmosphere in general, they are designed to separate the nitrogen from the other gases in compressed air.  A capital expense for the bar that could be depreciated and quickly would offset the cost of running separate nitrogen tanks to mix with bulk CO2.  Same principal would work for a tire shop assuming they push enough Nitrogen to make it worth while.
Offline wpz
« Reply #43 on: November 24, 2018, 07:09 AM »
Quote
Actually, about 78% of the earths atmosphere is nitrogen, so quite a large percentage.
This means the majority of gasses in compressed air is nitrogen already, you just need to get rid of the 21% oxygen and 1% other gasses.
« Reply #44 on: November 24, 2018, 12:21 PM »
One more thing, adjust the pressures when the car is parked in the shade or garage.  I used to make a habit of adjusting them when the tires are cold, but found even if I drove the car 15 miles home, it really didn't increase the pressure more than 1-2 psi.  but if one side was exposed to the sun, the pressures on that side would increase up to 4 psi vs. the side in the shade.  If you set them all equal, that side will end up low when the tire temperatures normalize.
Ya I agree...I've made it a habit to adjust the tire pressures in the morning when the sun is still low on the horizon and the tires are all the same temperature.
Offline JimH2
« Reply #45 on: January 17, 2019, 06:15 PM »
I bought a $7 kit at Walmart and have successfully repaired 3 tires with no issues. Anyone reading the FOG can fix a nail or screw flat. No reason to ever bothering to pay someone for that type of fix. Best of all if the repair fails you end up with a slow leak which puts you back where your started. Of course if the hole is on or near the sidewall you are most likely looking at a new tire.
« Last Edit: January 17, 2019, 06:21 PM by JimH2 »
Offline GoingMyWay
« Reply #46 on: January 18, 2019, 08:41 AM »
I just watched this video the other day: .  I didn't know that could happen to a tire unless it had been run pretty low on air.  The outside of the tire sure looked fine.  Maybe patching from the inside isn't such a bad idea after all...
Offline GoingMyWay
« Reply #47 on: November 21, 2019, 09:14 AM »
Project Farm did a comparison of several cordless tire inflators.  He recommended the Milwaukee M12 for tires under 40 PSI:
Offline RKA
« Reply #49 on: November 21, 2019, 12:00 PM »
I love these things!  I have an older ryobi like the one he tested.  I hate it.  The gauge is inaccurate, you have to hold the trigger to keep it running (rubber band solves that) and it's slow.  But the kit I got included a 1.3ah battery and I think PF was using a 4.0ah or something, which could easily account for the difference.
I have both Dewalt and Milwaukee platforms but went with the Dewalt because it can run on a 12V socket if necessary and the increase in size was inconsequential to me.  Otherwise they are probably pretty close as long as you're putting a larger battery on the Milwaukee (3-6 ah).  I love that you can set the pressure and it stops where you want it.  And the gauges are pretty accurate.  Previously I would overfill with the Ryobi by 2-3 lbs, come back with a proper gauge and drain until I hit the mark. And the battery was full in the spring and still indicates 3/3 bars on a 5ah battery.  I've used it to top off 3 the tires in 3 cars and the off season tire set in two of those cars (essentially 5 sets of tires were topped off).  And I've used it to refill a tire I had to plug, so it was probably down to 10 lbs and I brought it back up to 38 lbs.
-Raj
Offline Jiggy Joiner
« Reply #50 on: November 21, 2019, 04:21 PM »
Makita now do a 12 v version. As much as I like Makita, I think the design/shape of the Milwaukee and De Walt is better.
Offline Alanbach
« Reply #51 on: November 21, 2019, 06:11 PM »
Toolnut.com also has the Milwaukee tire inflator bundled with a battery, a charger and a usb power source for $99. Great deal!
Offline rst
« Reply #52 on: November 22, 2019, 09:12 AM »
My daughter who lives in FL called to catch up and mentioned that she was at a pay for air pump as her tire regularly, albeit slowing, loses pressure.  I had bought the Milwaukee pump when they came out and I had multiple chargers so I bought two more batteries and sent the kit and kaboodle to her.  I had bought the original pump on sale and just replaced it for the same $79.00 bare tool that i paid originally.
Offline JimH2
« Reply #53 on: November 28, 2019, 08:24 PM »
I’ve fixed a truck, an SUV, and lawnmower tire with no problems whatsoever. Anyone can do it and they work. In a world where everyone has unlimited money you would buy four new tires every time you had a flat. That is not reality. Plugs have been in use for probably 100 years.
« Reply #54 on: June 18, 2020, 01:33 PM »
Just received a notice from Toolnut.  The small M12 compressor is on sale for $99 with free shipping.
I paid $79 for just the bare tool 2 years ago.
Offline Alanbach
« Reply #55 on: June 18, 2020, 04:01 PM »
@Cheese  - Have you seen that Milwaukee just introduced their M18 portable air compressor? It’s 68db so pretty quiet. It’s a bit pricey at $349 tool only but still, another nice add to their platform.
Offline Peter_C
« Reply #56 on: June 19, 2020, 12:25 AM »
Should have been in a Packout format like everyone has been asking for. *shakes head*
My wife is happy with the Viair compressor I bought for her car. She uses it twice a year or so to check air pressures and top up as needed. As it is all in one kit with pliers and a plug kit, one of our friends borrowed it to repair a screw hole. Makes me more comfortable knowing she can get herself back on the road quickly. New tires help keep flats away too.
« Reply #57 on: June 19, 2020, 11:33 AM »
Ya thanks for that Alan...🙏...I keep the little M12 in the garage and use it for inflating tires. Just set the pressure where I want it and I'm good to go. No going back and forth between the air hose and an air gauge just to get the correct pressure in each tire. Each tire is the same pressure and the TPMS display on the dash verifies that.  [smile]
« Last Edit: June 19, 2020, 11:35 AM by Cheese »
« Reply #58 on: June 19, 2020, 01:08 PM »
I keep my M12 inflator in the car because I need it so often. I seem to have a bad rim. It’s amazing how much air you can get out of a little 17wh battery.
Offline rst
« Reply #59 on: June 19, 2020, 01:16 PM »
Liked mine so much I gave my first one to my daughter in St Augustine and bought another.
