Author Topic: SawStop Outfeed  (Read 1367 times)
Offline Birdhunter
SawStop Outfeed
« on: February 18, 2020, 05:56 PM »
I bought a SawStop flip up outfeed table today. Will install it soon.
Anyone have any tips for installing the table?
Birdhunter
Online justaguy
Re: SawStop Outfeed
« Reply #1 on: February 18, 2020, 06:08 PM »
  • Loosely assemble as a test fit before tightening everything down every single fastener. You do have to have the two outer hinge mounts tight at a minimum.
  • It's easier to install with two people. I did it by myself.
I have a PCS with the overarm dust collection, ICS mobile base and router table mounted on the right. I seem to recall I had to play with the positioning to accommodate all of the accessories. It's been a while since I set it up so I don't recall the specifics.
Offline Birdhunter
Re: SawStop Outfeed
« Reply #2 on: February 18, 2020, 07:35 PM »
Birdhunter
Offline Birdhunter
Re: SawStop Outfeed Update
« Reply #3 on: February 23, 2020, 12:39 PM »
I'm about 3 hours into the assembly of the SawStop outfeed table and about half way through the process.
It's very involved. I have just about worn out the manual reading and rereading it. The quality of the parts is excellent and the manual is well written.
Birdhunter
Online justaguy
Re: SawStop Outfeed
« Reply #4 on: February 23, 2020, 12:53 PM »
Your patience will be rewarded
Offline JimH2
Re: SawStop Outfeed
« Reply #5 on: February 23, 2020, 01:54 PM »
All tips are consistent with my experience. It seems flimsy, but once assembled it is solid. If I had any say in the matter I would have liked a few more rollers. This is tremendous improvement over the other model.
Offline Birdhunter
Re: SawStop Outfeed
« Reply #6 on: February 27, 2020, 05:33 AM »
The assembly is complete!!!
The outfeed table is now totally solid with ALL (lots and lots of bolts, nuts, washers) the bolts tightened.
All I need now is a project for which the outfeed table is needed. I almost always buy something after the need is past.
Birdhunter
Offline Rich Kline
Re: SawStop Outfeed
« Reply #7 on: February 27, 2020, 08:52 AM »
Thanks for this advice.  It’s the next item on my purchase list.
Offline cpw
Re: SawStop Outfeed
« Reply #8 on: February 27, 2020, 09:50 AM »
I don't think I've flipped it down once.  It's super nice not to have to worry about off cuts falling or the height of a roller stand.
It is sturdy, even if it doesn't look it.  At the moment, I've got about 400 lbs of 8' long oak boards on the saw table waiting to be edge jointed.  Without the outfeed, no way I'd want that stack on just the 2.5' of saw and would need to find some other place to stick them while processing.  With the outfeed table they are supported well.
