What is the run time on the mower?
http://egopowerplus.com.au/products/mower?gclid=CjwKEAiAgvyxBRDmuviAj67g-XQSJABTLMcHxiBUoJIgXGZHI7aV554X5musE4vTcWx2thDBirPWhxoCY8Lw_wcB
45 minutes on the 4.0Ah battery
And they say it takes 30 minutes to recharge -- well, 'they' probably started with a dead battery. I've never had the battery take that long.
It is very difficult to find fault with the mower. You may find it just a little long, as the very useful front handle does stick out a little and thus may not get as close in front as others. But, that's being very, very picky. The handle is a little long also, compared to other mowers I've owned. Similar issue with the deck being double walled -- it just keeps you another inch further from any obstacles along side. Yet, while it requires just a little more room in tight spaces, the lightness of the mower makes it so easy to handle. Without the weight and drag of a power feed, this mower is a breeze to operate. Even for an old disabled person like myself. I have one small area of grass that is very tight, and have found that I can turn the mower around (180) by standing alongside during the turn holding the handle both on the end (as normal) plus the other hand up further on the handle as I swing it around. Much, much easier to handle than a gas mower. Oops, I was trying to find fault...
Okay, then some may not like the cut quality at higher settings, but I'm not sure on that point. It seems to me that it does better on the #2 setting, which is fairly low, than even the next higher setting. The mower may not have as much vacuum effect to lift the grass blades up to be cut at the higher settings, but, I haven't had the best conditions to test this aspect this year due to our lack of rain until just recently.
As I mentioned earlier, cleanup is the coolest feature. And one that I don't see advertised. In all my years of owning a lawn mower, I hate to admit that this is the first mower that I have cleaned
on a regular basis until it became a necessity. It is just too simple. And the whole job of mowing has become a lot quicker and easier for me.
My EGO blower and hedge trimmer are also of top quality and performance. I purchased those without the smaller battery, and just have the larger 4 Ah battery that came with the mower. Works great for me. And they all save a bunch of time in the process.
