I wanted to try something different than my Incra fence and since TSO doesn't have anything equivalent I figured I'd try the Benchdogs fence ... plus I wanted their fence dogs.
I received it today and was surprised to see it's not the larger 8020 aluminum but the smaller stuff like my Ender 3 Pro 3D printer. At first, I thought it might be cheap, but it doesn't seem to flex easily and I'm considering the lighter weight might be nice!?
The threaded rod on the star knob for fence dogs could be slightly longer as they're probably halfway in the nut when it's tight which means loosening them anything more than needed will cause the nut to fall off.
Other than that, my only complaint so far is the fence dogs are too tight for my Parf drilled table. The fence dogs measure 19.98mm versus my TSO dogs which are 19.95mm and fit perfectly. While the fence has no movement, you literally need to remove the fence from the dogs and then twist each dog individually with your best hulk grip to get them out.
It's really such a shame how much this little difference could make these perfect. Do you think I can recover 0.03mm if I sand the anodizing off the bottoms? Do you have any other recommendations other than wearing out the holes in my table?
