Author Topic: Cabinetry Question  (Read 1365 times)
Offline Birdhunter
Cabinetry Question
« on: October 26, 2019, 11:27 AM »
I'be been asked to build a desk for my Pilates studio. It's very much a cabinet type structure and I plan to use Baltic birch with oak edging. It will be painted.
The project will be built in my home, broken down, transported to the studio and reassembled there.
I'd like to use the 500's connectors as I already have the kit, but I was thinking that a combination of Dominos and pocket holes would be a lot cheaper and still allow me to build it as a knockdown.
Comments?
Birdhunter
Offline Gregor
Re: Cabinetry Question
« Reply #1 on: October 26, 2019, 12:24 PM »
In any case: They have asked, they at least have to pay for the material.
I have no idea about the size or complexity of the desk, so no idea how using dominos and the connectors would increase the BOM. What do you estimate for difference in cost? Could you post a sketch, it's hard to answer without any information?
« Reply #2 on: October 26, 2019, 01:02 PM »
Domino/pocket screw joinery is a great combination, especially if you’re doing the reassembly yourself. Keep the screws close to the Dominos to reduce distortion of the panel as the screw is tightened.
If that scheme puts a relatively unsightly pocket hole in a easily seen location you could use the more costly fastener instead.
Offline jobsworth
  • Festool Baby.....
« Reply #3 on: October 26, 2019, 03:02 PM »
Should be fine as long the PH are out of site.
Offline xedos
« Reply #4 on: October 26, 2019, 03:13 PM »
I wouldn't use Oak edging if I were going to paint this.
Better to use Maple or Poplar.
Offline Bert Vanderveen
« Reply #5 on: October 26, 2019, 04:24 PM »
Watch a few video’s from Vitten at YouTube and you will have acquired all the knowhow you need.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950 | TaigaTools VacPods Pro Set
Wishlist: ETS EC 125 w 150 pad, DTS
Offline Birdhunter
« Reply #6 on: October 26, 2019, 04:54 PM »
Thanks to everyone. I will use poplar for edging and I’ve decided on a combination of pocket holes and connectors. The tip on placing the pocket holes and tenons close together makes a lot of sense.
The Pilates studio will have their painter do all painting as I don’t have any spray equipment.
This project gives me an excuse to buy a folding out feed table for my SawStop.
Birdhunter
Offline SRSemenza
« Reply #7 on: October 26, 2019, 07:26 PM »
For painted I'd go maple on that edge. Hard for durability and smooth grain for paint.
I take it that it is just too big to move after assembly?
Offline Birdhunter
« Reply #8 on: October 26, 2019, 07:33 PM »
It’s an L shaped reception desk 45” tall with one side 80” and the other 72” and a desk level at 35”. Made of 3/4” Baltic birch, it will be heavy.
Birdhunter
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #9 on: October 26, 2019, 07:39 PM »
Domino's and pocket screw will work just fine. You can also T&G and pocket screw. As mentioned hide the pocket screws.
Maple plywood paints up much better than BB. You'll need a little more prep work with the BB. Sand it to 150, you may need to fill some grain, trowelable floor filler works great.
Maple edge banding or solid maple nose. If you go nose it can be Dominod or T&G'd. Look into the Collins plywood prep bit.
I'd recommend SW Wall and Wood primer with Emerald Urethane for the top coats. W&W sands great, Emerald will give you a very durable finish.
Offline Birdhunter
« Reply #10 on: October 26, 2019, 07:46 PM »
I have a Mafell DD40 doweling machine that I may work into the project. It’s an amazing machine.
Birdhunter
Offline tjbnwi
« Reply #11 on: October 26, 2019, 08:49 PM »
It should work just fine.
