Author Topic: Wood Magazine (July 2022) Boom Arm build  (Read 2592 times)
Offline krudawg
« on: May 12, 2022, 08:02 PM »
Just flipping thru the latest Wood Magazine and came across a Boom Arm Build.  Has anyone built the Boom Arm?  I'm thinking about building it after I finish my current project (garage cabinets).
Ted
MFT/3, DF 500, Hammer K3 Winner, TS55,  Sjoberg Elite 1500 Workbench, Fuji MiniMite4 Platinum, OF1400, CT MIdi, CT26, RO90, ETC-150, CT26, Midi,
Former Marine, Vietnam Vet
Offline guybo
Re: Wood Magazine (July 2022) Boom Arm build
« Reply #1 on: May 12, 2022, 09:06 PM »
Hi, I always liked this build
Offline krudawg
« Reply #2 on: May 12, 2022, 10:16 PM »
Holy Cow.  That is very unique and quite functional.  Did you design it?
Ted
Offline 4nthony
    • Slack for Recon Tools
« Reply #3 on: May 13, 2022, 12:38 AM »
For those wondering about the boom in the mag. It looks kinda cool, though not as fancy as guybo's version. The integrated air line is a nice touch.
Recon Tool Notifications
Anthony
Offline guybo
« Reply #4 on: May 13, 2022, 07:14 AM »
I wish I was that talented ,thats from some of the great talent on this forum here is the linkhttps://www.festoolownersgroup.com/workshops-and-mobile-vehicle-based-shops/shop-use-consideration-of-ct-boom-arm-for-dust-extractors reply#12
Offline Packard
« Reply #5 on: May 13, 2022, 09:06 AM »
That is going to cost as much as the Manfrotto boom arm without the flexibility.  I must be missing something.  But this seems silly to me.
Offline Kpp80202
« Reply #6 on: May 13, 2022, 10:02 AM »
There is an earlier thread here where someone made a boom arm using electrical conduit off a simple wall mount. Inexpensive and relatively fast to construct.
Trion
CT22E
CXS kit
ETS EC 150/3
FS1400/2-LR
FS-WA/90
TS55FEQ
FS1400/2
Sold: ATF55E, FS1400 (x2), Rotex
Offline Crazyraceguy
« Reply #7 on: May 14, 2022, 02:56 PM »
I like the idea of a boom arm, but haven't worked it out exactly for my space. I found one that I liked on Amazon, at a good price too, but I waited too long. Now they are out of stock.
I think the one I found was intended to be for a dock-light, for shining up inside a semi truck? Maybe it will come back by the time I figure out how to mount it? My workspace is nowhere near an actual wall.
I have a backing wall, behind my Sysport cabinets, but it is very short. Less than 5ft IIRC, 54-56 inches? It's fine as a backdrop, but I would need a column of some sort, going higher.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline Peter_C
« Reply #8 on: May 14, 2022, 04:54 PM »
Bolt a plate to the floor with a "bearing" of some kind welded to a bent tube. Trailer hubs and spindles are super cheap, or old car parts. If the tubing is sized correctly it could function for the air to pass thru with a 36mm hose plugged into the boom. Quick removal might be necessary for some projects to clear.
I have the Festool boom arm which works well in my situation, as I couldn't have a permanent boom arm.
Offline 4nthony
« Reply #9 on: May 14, 2022, 05:16 PM »
This guy got creative with the range of motion on his boom arm:
Anthony
Offline ChuckS
« Reply #10 on: May 14, 2022, 05:40 PM »
Among all the boom arms I've seen in this forum or on the web, the Wood Magazine's version is one of the more cumbersome in terms of building in my book. Many have accomplished the same job with hinges, tubes, or simple hardware like the one 4nthony shares above.
If one enjoys building for the sake of building (or wants to make the boom arm for skill building or experience), of course, that's a different story.
Offline FestitaMakool
« Reply #11 on: May 14, 2022, 05:42 PM »
Thanks Guy, now Stig do too!  [big grin]
« Reply #12 on: May 14, 2022, 06:02 PM »
I am thinking more along the lines of bolting some kind of tubing to the end of the back wall itself.
That would put it close to where I keep the CT 99% of the time.
I didn't realize how bad my bench looked in this shot. It has changed quite a bit in the last few weeks.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Offline ChuckS
Talking to a woodworker neighbor, and he shared this image he came across years ago:
May look ugly, but does the job (in a simple way)...and doesn't cost over $600 Cdn. [tongue]
Offline Mini Me
« Reply #14 on: May 15, 2022, 08:38 PM »
Does anyone recall or know what happened with the boom arm that was being developed by two different people from this forum a few years ago IIRC. It had bearings in the extension part and was quite complex in some ways but it definitely looked solid.
Offline afish
« Reply #15 on: May 15, 2022, 09:18 PM »
posted this before but this is made from 1.375 fence rail and gate hardware. its around 30 bucks of material and the tube could act as part of the hose. plus the gate hardware would allow it to be lifted off easily if it was in the way. the only bad part is putting the two 45 degree bends but that is easy with a HF tube bender. If I had the room I would make one for sure but my space is way too tight for it.
if you didnt want to wall mount it you can add a leg out of the same material since they flare the ends to slip together and should pivot as well at the joint. if it was tight a little grinder work should make a nice slip fit
« Last Edit: May 15, 2022, 09:24 PM by afish »
Offline Peter_C
« Reply #16 on: May 16, 2022, 02:09 AM »
Since the wall is a decent distance to the far end of the big work bench, going with an articulating arm with a lot of movement would probably be the only way. What is the distance of the wall to far side of work bench?
Either pay the big bucks are copy the design and build one yourself. You got fabrication skills. A TIG might be ideal though for aluminum bearing cups to an extrusion. A strong plywood design cut on the CNC could work for a shorter boom, but not 15ft. The wall behind the CT needs to be solid or floor and wall mount with a vertical steel beam.
Mostly semantics and/or verbiage but there is a difference between tubing and pipe. HF benders are for pipe; think black pipe at Home Depot, which kinks/crushes on tight radius turns. Tubing includes things like DOM (Drawn over mandrel) which takes a lot of force to bend. I use a hydro bender and a single bend can be 90* in 6" on 1 3/4" tubing. This is the die I use for roll cage fabrication (Dang they went up like double since 2005). https://pro-tools.com/products/round-tube-bending-die-1-3-4-in-odx6-in-clr-180-degrees-b-105-sd-hd/
Offline MikeGE
« Reply #17 on: May 16, 2022, 06:52 AM »
The two examples I remember are these threads:
Prometheus Boom Arm by Rick Christopherson (RTS Engineering)
DIY Fully Articulating Boom Arm by Martin Felder
Offline afish
(Attachment Link)
I just noticed it looks like that boom arm is using the CT as a base.  I dont know how that thing doesnt flip over without some sort of bracing.
Offline Mini Me
« Reply #19 on: May 16, 2022, 09:11 AM »
Thanks Mike, they are what I was thinking of.
Offline ChuckS
(Attachment Link)
I noticed that too, and wondered why he didn't mount the post on the opposite corner. May be he needed to swing the arm to the back side of the CT often?
I like the idea of using a piano hinge for the build.
Offline Packard
(Attachment Link)
There might be a substantial amount of weight in the Systainer perched above the vacuum.  That would provide stability.
