Author Topic: What grit do you stop using the Rotex mode?  (Read 2340 times)
Offline Mtpisgah
« on: August 25, 2019, 07:17 PM »
I flattended a slab yesterday with a router sled and started sanding it today. I have only used my Rotex 125 a few times fro minor projects so today was the first big test.
I started with 60 grit on Rotex mode and the slab is looking great. I am ready to move to 80 grit but and not sure if I should stick with Rotex mode or go to standard mode. When I get to 120 I will switch to the ETS 125.
What do you guys usually do?
Offline Rich Kline
Re: What grit do you stop using the Rotex mode?
« Reply #1 on: August 25, 2019, 07:39 PM »
Working a similar project with a walnut log that will become a bench.  Making it perfectly flat wasn't within my reach because I don't have a router sled.  So I did 80 grit with a belt sander and then 80 grit in rotary mode.  I used the rotex mode in a couple of spots to remove some small branch "nubs"  I will switch to the ETS for 120
Offline waho6o9
    • Garage Door Handyman.com
« Reply #2 on: August 25, 2019, 07:41 PM »
Great sled work on a nice looking slab Mtpisgah!
After I Rotex the item I switch it to normal mode and sand it up using the same grit as I climb up the sanding grit chart.
If the Rotex gets too hot I hook up my 150 Festool and sand with the same grit all the way up to 180 or 220.
Offline ChiknNutz
« Reply #3 on: August 25, 2019, 09:12 PM »
I've made many slab projects, mostly walnut.  I use Rotex up to about 150.  I then switch to the ETS and go back one grit to 120 and finish up at 220.
-Chris
Rotex 150/5 FEQ, CT 36 E, ETS EC125/3, TS75, Domino XL
Online Alanbach
« Reply #4 on: August 25, 2019, 10:14 PM »
I agree with @waho6o9 . Follow the 60 grit in geared mode with a fresh 60 in random orbit mode. Then on to 80 grit in geared mode followed by 80 in random orbit mode. Keep going until you are totally pleased with the flatness. Then I use some water or mineral spirits to check the scratch pattern to see if I am happy. Once I am happy with the flatness and that I have the scratches where I want them I then switch to the ETS. Sometimes that happens (for me) after 80 grit but usually after 100 or even 120 occasionally.
Offline SRSemenza
« Reply #5 on: August 25, 2019, 11:48 PM »
I would only use Rotex mode for what it is really needed to do ............  remove material. Going to finer grits in Rotex can really add to the amount of sanding that is needed in random orbit to get rid of the Rotex scratch pattern.
Start  with whatever you need to remove material and flatten. In this case 60 (?). I would then do Rotex in 80. Followed by random orbit in 60. I find that backing up one grit when switching to random orbit after Rotex mode really helps get rid of the Rotex swirls.
Be thorough with the back track random orbit grit and the one following it. You do not want to get all the way to the end only to find Rotex swirls still left in the surface.
I would use the RO125 (in both modes) for everything except your final pass. The ETS125 does not have a very big stroke for removing previous grit swirls.
Offline Mtpisgah
« Reply #6 on: August 26, 2019, 08:01 AM »
Thanks for all the input. Based on the comments, I think I will go from the 60 to an 80 in Rotex mode and then drop back to the 60 in RO, then 80, and see how it looks. Hopefully I can then keep going up in RO with the Rotex for the bigger orbit until I get to 125 or 150.
Since I need to do both sides, I might switch it up on the second side and see which I like best. I will have a day or two to sand this week, then it is two weeks of vacation. I will try to give up an update when I get back to it.
« Last Edit: August 26, 2019, 09:13 AM by Mtpisgah »
Offline nvalinski
« Reply #7 on: August 26, 2019, 09:01 AM »
Shockingly, my most recent projects have just taken me up to 1500 in Rotex mode, no ETS-EC. But if you are stopping midway stop Rotex ~120, finish up to 220), then you need the ETS. 1500 looks fantastic on even just normal wood surfaces. Not worth it on legs and stuff though.
Offline Mtpisgah
« Reply #8 on: August 26, 2019, 09:15 AM »
How do you keep from removing too much material in Rotex mode through all those grits? I know as you get to finer grits it will remove less, but it still seems like it would remove too much to easy. Also, what about the swirl pattern from the larger orbit?
« Reply #9 on: August 26, 2019, 09:53 AM »
Here's a video where Larry Smith from Festool goes from 40 grit to 1500 grit and then polishes the walnut all in the Rolex mode.
I know there are others on the forum that do the same thing.
« Last Edit: August 26, 2019, 09:56 AM by Cheese »
Offline SRSemenza
« Reply #10 on: August 26, 2019, 10:05 AM »
Yes, when getting into the really fine grit you start getting into the polishing realm which is where the Rotex mode starts helping again.
Offline Mtpisgah
« Reply #11 on: August 26, 2019, 11:55 AM »
Interesting. As I said, I have not used it much yet and bought it mainly for smoothing slabs after flattening. I may have to do some more playing with it and see how fine a finish I can get.
Would it work to polish epoxy too?  I have done some non visible patching with epoxy that did not require polishing, but want to do a table with full depth epoxy in the center this fall.
Offline nvalinski
« Reply #12 on: August 26, 2019, 11:57 AM »
Epoxy is the exact reason I went this high in the first place. Works fantastic going up to 1500, then polishing with anti hologram compound.
Offline rvieceli
« Reply #13 on: August 28, 2019, 08:31 PM »
@Mtpisgah I work with slabs a lot and my sanding sequence is to go Rotex mode from 60 to 150 then I switch to the ETS EC150 and sand from 150 up to usually 320. Works for me in walnut, cherry, oak and maple.
I am finishing with OSMO Polyx.
Ron
Offline Mtpisgah
« Reply #14 on: August 28, 2019, 09:07 PM »
I made it to 120 on one side last night and that is likely all that will be done for the next two weeks due to vacation.
It is super smooth in most areas, but there are a few areas I can feel little cracks so I think I need to go back down a few grits and work through those. I epoxied the visible cracks and some worm holes but missed some non visible stuff.
I think I was too excited about the results and did not feel the whole slab, only the pretty parts.
Offline Untidy Shop
« Reply #15 on: August 28, 2019, 09:36 PM »
As can be seen from the varied answers here there is no definitive answer! It all depends on the timber species, soft or hardwood and the intended finish(s).
With an intended  oil finish I have usually left ROTEX behind by 120, moving back to 80 and then back on upwards to 220/240. But that is with Australian Hardwoods.
Offline Mtpisgah
« Reply #16 on: August 28, 2019, 09:48 PM »
Yeah, I agree. This is a piece of American oak and I am making a waterfall coffee table with it. It is a gift for my wife’s best friend so I get  to play with it some and try different things.
And i am just a beginning hobby woodworker, so I know almost nothing. I just have access to some good wood and bought good tools.
Offline zapdafish
« Reply #17 on: August 30, 2019, 11:01 AM »
with red oak I rotex to 80 then give it pass on non rotex mode then maybe take it to 120 on an ets. all the other grits just sit in a drawer, lol
« Reply #18 on: August 30, 2019, 11:52 AM »
Here's a white oak slab that I turned into a kitchen counter top.
There's a 2 mm thick West epoxy coating across the entire surface. I started with 60 grit and went up to 1500 grit using a RO 125. I didn't want a highly polished surface as it looks too plastic-like for my taste. However, you can still see the reflections of the stainless pot on the stove, the under cabinet lighting in the upper cabinet & the stainless backsplash.
The last photo is a worm hole and that helps you see the thickness of the epoxy top coat.
Offline ultane
« Reply #19 on: September 10, 2019, 08:46 PM »
So Cheese, you sanded the wood, or the Epoxy up to 1500?
I might be wrong… Just ask my X...
« Reply #20 on: September 11, 2019, 12:51 AM »
I sanded the oak to about 180/240, can't remember exactly, just to flatten everything out and give the wood some tooth.
I then applied the epoxy and sanded that to 1500. Here's a shot of the various discs I used. Some have holes...some don't, some fit the Rotex 125, some don't...just to let you know that using the proper grit paper is ultimately more important than using the correct sized paper.
Of course, this situation could be easily corrected if Festool decided to offer packages of abrasives in quantities of less than 100 each.  [poke] [poke] [poke]
Offline Mtpisgah
« Reply #21 on: September 11, 2019, 06:18 AM »
Cheese,
Woodcraft sells Festool paper in smaller packets, 10count I think, up to a certain grit size. It is what I have been buying since I am just a hobbyist.
« Reply #22 on: September 11, 2019, 10:08 AM »
Cheese,
Ya, the local Woodcraft originally sold everything in quantities of 10 each, including Platin  [smile]...then they went to a simple package of 10 each 80-120-180-220 grit assortment which really was pretty useless, and now even that's discontinued.
Festool Nirvana offers custom assortments in Granat & Rubin 2.
https://www.festoolnirvana.com/search?q=custom+abrasive+assortment
Offline Mtpisgah
« Reply #23 on: September 11, 2019, 10:42 AM »
I did not know they had discontinued the small packs, that sucks.
Offline JMcFly
« Reply #24 on: September 30, 2019, 09:33 PM »
Looking through this this thread pretty much has me sold on a Rotex 125.  I have some personal projects coming up with slabs and what not and by going with a rotex I won’t have to buy a belt sander. Thus saving money.
at least that’s what I keep telling myself.  [tongue]
Offline Mtpisgah
« Reply #25 on: September 30, 2019, 10:03 PM »
Here is the table I was building when I started this thread. I took it to 400 in Rotex mode and stopped because it was so smooth.  It was so much faster than what I had been doing previously with my ETS 125, I do not mind sanding as much now.
Sanding slabs i flattened to 120 is the reason I bought it, but now it will get more use as a finish sander.
« Reply #26 on: October 01, 2019, 02:35 AM »
And the reason is that the ETS 125 is strictly a finish sander, especially the first generation  because it’s underpowered. It’s used for final sanding or between coats sanding.
Here’s a challenge, put some 400 paper on that ETS 125 and resand that table, then compare the results.
Offline Mtpisgah
« Reply #27 on: October 01, 2019, 08:30 AM »
@Cheese I will try that for the next project.
Offline nvalinski
« Reply #28 on: October 01, 2019, 09:46 AM »
I'd strongly recommend you take a look at the 150. The extra inch in diameter makes a big difference in balance and the amount of work you get done if you are okay changing paper formats.
Offline JMcFly
« Reply #29 on: October 01, 2019, 10:11 AM »
I haven't even started a paper format.
there is a used 150 for sale in the classified here, just waiting for the seller to respond. I'm trying to buy used
