Author Topic: Walnut slab desk  (Read 6322 times)
Offline LazyGretlWoodWorks
  • Just a guy with a saw standing in front of lumber.
    • Lazy Gretl Wood Works
Walnut slab desk
« on: August 07, 2023, 08:59 PM »
Step son bought a slab and asked me to make a desk. It's a walnut crotch piece. I despise the whole overly-done river table look, so I filled the V with sapele. There's some epoxy on the bottom of the V to help fill the thickness difference, but it's not visible. The only epoxy on the top is there to fill voids and cracks around knots and checking. Legs are sapele. Stretchers and supports underneath are also walnut. Everything is rubbed with Osmo Polyx except the top surface of the slab; that's two coats of Rubio pure. I didn't think the second coat did anything really until it cured a few days, and it turns out it kinda does change the sheen and the general feeling when touching it. Took ~4 day or so for me to feel like there was a difference. The second coat seems to age nicely.
(that's not a weird optical thing, the left legs are canted out at 10*)
Soon to be a full time venture.
Offline luvmytoolz
Re: Walnut slab desk
« Reply #1 on: August 07, 2023, 09:20 PM »
Very nice work! The sapele's a nice touch!
Offline squall_line
« Reply #2 on: August 07, 2023, 10:22 PM »
It's beautiful!
I would love to see a build diary on this, especially the parts where you use the sapele for the fill instead of epoxy.
« Reply #3 on: August 07, 2023, 11:54 PM »
I can absolutely add more pics and a write up.
Thank you!!!!
« Reply #4 on: August 08, 2023, 09:17 AM »
Please forgive what looks like total disarray in my shop. I recently moved my shop out of a wonderful ~30x~30 rented space into my 1950s era barely-two-car garage because my landlord at the shop space couldn't get or couldn't renew or lost her insurance. I'm not sure I'm getting the whole story, but here we are, cramming way too much stuff into my tiny garage. I'm still working through layout and storage options.
Step 1 - the slab. We live in Northern Delaware. The slab was bought online from Alderfer Lumber in central Pennsylvania. So we hiked up there in my truck to grab the slab. My step son bought it all on his own, and I have to say, for the price (~$275), I wasn't expecting much. I was prepared to reject it and buy up a little bit if we needed to. Turns out, the slab was rather lovely, so now Alderfer Lumber is on my go-to list of places to get this kind of stuff.
Step 2 - debarking and prep work. After chipping away some bark and digging out soft bits from various voids and checked areas, I used the combination of a track saw and some chisel work to clear out the crotch void and turn it into straight lines. I'd already decided - with step son's blessing - that I wasn't going to do a full epoxy pour on this thing (re: my aforementioned disdain for that weird trend). I had a single board of sapele left from a previous project, and it had a lovely tone and chatoyance to it once oiled. I know it would look good standing out against the walnut. The board wasn't wide enough to fill the void, and I couldn't find a grain match that I liked, so I decided to cut pieces to match the rough widths of the void, glue them up into a panel going the other way, and shape it and drop it into place perpendicular to how most might do it. I told my step son that if wood movement becomes an issue, we can cut it out and deal with it, but honestly, now that it's assembled and it sat in my non-AC'd, unheated shop for about 6 weeks in total and hasn't moved an iota, I'm not worried about movement in a more climate static environment in our house or in his college dorm, where ever it ends up.
Dilbert DeWalt looking quite determined after a big round of sanding, and ready for more.
Step 3 - the inlay. We conferred on the look, and decided to add a white oak key to the top mostly for visual interest, but also to add some strength to the cross grain party going on between the walnut and the sapele. I laid-in a 1/2 x 1/2" section with a simple router trough and some chisel work on the ends. Not gonna lie - that was nerve wracking as I was doing it free hand because my 1/2" wide white oak was a hair over 1/2". I was able to get it very close with the router, then chisel in to a nice tight fit. But yikes... sllllooooomow and steady. That took about 20 minutes to just do the routing with all the slow moving and frequent stops to check fit and make sure I could still see my lines. Once in, some hand plane work to level it all out and Bob, as they say, is your proverbial uncle.
At this point, the filler is held in only with glue, and we were about 72 hours into the filler and inlay glue drying and curing. It's not getting any drier or more cured, so it was time to move on.
(not pictured)
I flipped the top over and hand chiseled in pockets to glue and hammer in some dominos, three per side, between the walnut and sapele, then planed them down to the level of the sapele. This added more mechanical binding. The slab is ~1.5 inches and the sapele is about .8 inches, so there's still a thickness difference. This is where I decided to break out the epoxy rather than piece more wood in. Did all the typical prep for that; some spray shellac to inhibit color wicking, chiseled in a few divots for the resin to adhere to in the walnut slab's bottom where it rises above the sapele, etc. Across about a week and a half I did 3(?) thin-enough pours. I didn't want to do a big deep pour (I mean, is ~.75? really all that deep?) because I wasn't sure what would come through, and I was using a non-brand-name epoxy that got good reviews, but I'd never heard of. Thin pours could be cleaned out or ignored if there were issues.
There were no issues, and toward the end I mixed in a little color just for some fun.
(quick note: didn't at this time have my own Domino machine, but I had a pack of dominos from when I borrowed one to practice and figure out if I wanted to buy one. I have, since.  [big grin] )
In this image, at the left of the pour, near the bottom, you can see two areas that look like bubbles. They're the end of the domino that didn't lay down quite as flat, and I didn't plane it down quite far enough that this layer fully covered it. That's the extend of the domino usage in this project.
Step 4 - the frame and gaming PC shelf
(no real mid-build pictures here)
Decided to design this thing so that the right column, where a drawer stack might normally be, would include a floor-level(-ish) shelf to hold step son's gaming PC. It's a full sized tower with water cooling and all the goodies. The deck/shelf is a pile of glued-up walnut off cuts (I don't like "scrap wood" as a term for usable wood) all nicely jointed and planed into a 12" wide, 2" thick, 24" long shelf that gets rabbeted into the four legs on the right. Since the top is so heavy, I wanted something weighty and solid toward the bottom and between this shelf and the PC that will be sitting on it, you know the old dad saying... "that ain't going nowhere!"
It's beefy.
The left two legs are canted out at 10*. We were going to go with a bigger angle, but decided to keep it shallow for strength and to minimize the footprint to roughly the same as the slab, while still providing ample room for his gaming chair and gangly-ass legs on his ~6' frame. The 6 legs used the remaining bits of my sapele that wasn't set aside for an upcoming curio box I'm commissioned to make. The runners/stretchers in the frame and connecting the frame to the slab are made of 1" runs of walnut, castle-cut into the tops of the legs, then pinned with oak dowels, through-drilled here and there. The left two legs are also bolstered with white oak floating tenons (visible in the picture of the frame standing alone). Before putting the slab on it, I put a piece of plywood on it and sat on it.
"That ain't going nowhere!"
Drilled in some threaded inserts into the slab, and slotted the frame to allow for movement, oiled and rubbed everything, then final-assembled it all.
The mounting bolt recesses have since been chiseled, cleaned up, and oiled as well. This was at the initial test fit.
And that's that. Thank you for the interest, and hanging in to the end of this write up.
I've dubbed it The Nathaniel as that's my step son's name. I have SketchUp drawings for it, and I may make a short run of them for sale at some point. Locally. I'm not shipping this behemoth, though I could be talked into a road trip for delivery :)
« Last Edit: August 08, 2023, 11:09 AM by LazyGretlWoodWorks »
« Reply #5 on: August 08, 2023, 10:38 AM »
Oh, and here it sits in our dining room waiting to go to its final destination.
Offline luvmytoolz
« Reply #6 on: August 08, 2023, 05:32 PM »
Sensational work, it looks great!
Offline Crazyraceguy
« Reply #7 on: August 08, 2023, 05:47 PM »
That's a great looking piece. I especially like the castle-joint/half-lap on the tops of the legs...and the fact that they are different on the left side legs. Though it's kind of a shame that no one will ever really see them once it is assembled. A lower structure like that would look really cool with a glass top.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
TS60
Offline rvieceli
« Reply #8 on: August 08, 2023, 05:55 PM »
Very nicely done. Great work.
Ron
Offline squall_line
« Reply #9 on: August 08, 2023, 06:09 PM »
Thank you!!!!
It's beautiful!
Wow!
Great write up, great pictures, and great craftsmanship!
 [welcome] to the FOG!
« Reply #10 on: August 08, 2023, 06:22 PM »
Thanks, all. Very kind. I'm about a year in to returning to furniture making after a ~12? 13? year hiatus not of my choosing (divorce, ex sold everything for pennies on the dollar, really broke me for quite a while). Mentally and emotionally healed, and ready to restart this passion into my next career. I can't wait to get out of tech. For now I'm selling a few small pieces, but also doing a lot of "you pay materials and spread my name, I'll build you a thing" with friends and family. It's going well.  <3
« Reply #11 on: August 08, 2023, 06:33 PM »
Oh, and here's Gretl, the name and logo inspiration for the company. My wife does the art, the website, etc.
 [not worthy]
Offline luvmytoolz
« Reply #12 on: August 08, 2023, 07:14 PM »
At first glance I thought you named your company after a kangaroo! ;-)
« Reply #13 on: August 08, 2023, 07:42 PM »
lol We hear that a lot. :)
Here's a picture in full dog mode. <3
Offline Speedy48
« Reply #14 on: August 08, 2023, 09:05 PM »
Thank you for sharing pics and taking us on this journey with you, really enjoyed reading through.
« Reply #15 on: August 09, 2023, 06:03 AM »
Thank YOU.
Offline luvmytoolz
« Reply #16 on: August 09, 2023, 07:20 AM »
Dogs are such a crack up...it's such a hard life!
« Reply #17 on: August 09, 2023, 08:20 AM »
Thanks much. Wanted to circle back to this. With the top being an experiment - all the various grain directions and long term question mark around the wood movement - who knows? Something like a glass top might be a future change to it. :) I hope not; it was a lot of work. Sapele and walnut are both pretty stable on the charts you can find online for projected movement and in warping and such, so I truly don't expect any issues. Maybe a bees wax fill or something if any gaps open up, but again, I'm betting on it just staying as it is until I'm too old to do anything about it. :)
Thanks again. I appreciate all the kind words. This design was completely a slap-together bundle of ideas while my step son and I were looking at options and picking sizes for things and such. The mixing of these two species looked good in small tests I did, which were essentially a few varying off cuts glued together, sanded, and oiled. I'm thrilled with how it all came together.
Offline neilc
« Reply #18 on: August 09, 2023, 01:37 PM »
Very nice work, and a nice contrast of woods.
Curious if that base gave you any movement given the weight of the top.  It would seem that side to side movement might be the greatest with no cross bracing, but wondering about your experience once it was in place.
Thanks for sharing.  Always appreciate new techniques and approaches.  And I agree with you, the 'river table' look is way over done these days.
Neil
« Reply #19 on: August 09, 2023, 01:47 PM »
It's really solid; I think the rabbeted bottom shelf adds a lot of rigidity, as well as adding the stringer down at the user's feet (where the bottom edge of a modesty panel might live if it had one). It helps, too, that the left legs are canted out at 10*, giving some natural resistance to racking to the left side, and again, the shelf stack I think resists racking to the right.
« Reply #20 on: August 11, 2023, 08:27 AM »
I put much of this write up on FB and IG with an eye toward a couple sales. I set an introductory, early-buy-in price of $1200. Way too cheap, but it looks like two people (friends of friends) are giving it real thought and are supposed to hit me iwht the required 50% deposit. I said I could do 3 by Christmas time, keeping my other queue of work intact, too. That looks like 2 of those 3 slots filled. Nice. :)
All my (very modest) sales are word of mouth and very local, so I want to thank y'all for all the kinds words and the confidence to go wider with my push.
I didn't want to bite off too much shop work as I'm not ready to quit my tech job yet (this was a 5 year plan 2 years ago when I started back up), so I guess I'm entering that phase where I'm balancing the job I hate and the job I want to grow, about 2-3 years earlier than I was hoping. (but man oh man, I just don't want to build ANY MORE cutting boards) lol
Offline Mtpisgah
« Reply #21 on: August 29, 2023, 09:15 PM »
Very nice, I really like the contrasting woods for the top.
How did you mark and cut the sapele to get such a perfect fit?
DF500
ETS 125
RO 125
RO 90
DTS 400
PS 420
TS 75
MFK 700
OF 1400
MIDI
MIDI w/ Bluetooth
TID 18 Impact
T18 Drill
TPC Hammer
« Reply #22 on: September 04, 2023, 10:17 PM »
Thanks much!
I used the track saw to make the straight cuts in the walnut (and also a jig saw for the part that was too small for the track saw), then flipped it upside down, traced it out, cut it the tiniest hair oversized, then started shaving it with a block plane and sanding it as necessary. It took a couple hours, but it was faster than I think I was expecting.
Offline Mtpisgah
« Reply #23 on: September 24, 2023, 07:42 AM »
I have always been afraid of doing something like that and getting half way through and finding I have taken too much off.  Maybe I will try it sometime.
DF500
ETS 125
RO 125
RO 90
DTS 400
PS 420
TS 75
MFK 700
OF 1400
MIDI
MIDI w/ Bluetooth
TID 18 Impact
T18 Drill
TPC Hammer
