Author Topic: Walnut and Salvaged Steel Coffee Table  (Read 1394 times)
Offline rvieceli
« on: May 28, 2020, 11:30 AM »
Thought I'd show off a project I finished up and photographed recently.
Coffee table made from salvaged steel and locally sourced American black walnut.
The single slab walnut top has a live edge on one side and measures 32 inches wide by 23.5 inches deep and 1.75 inches thick. A series of inlays are used to repair knots and flaws in the slab top and bottom.
The base incorporates a piece of salvaged structural steel H beam. The beam is 25.5 inches long by 10 inches tall and has 4-inch flanges top and bottom. The steel beam is clear coated. All fasteners are stainless steel.
The walnut feet, angled at each end, are 1.5 inches wide, 2.25 inches tall and 18 inches long, providing a stable stance. Each foot is equipped with adjustable leveling mounts.
The table support arms are also walnut, 1.25 inches wide, 2 inches tall and 15 inches long. The supports are slotted where they are bolted to threaded inserts in the top to allow for seasonal wood movement.
The walnut is finished with a low VOC hard wax oil.
The table is 32 inches wide by 23.5 inches deep and stands 16.5 inches tall.
Ron
Offline Birdhunter
Re: Walnut and Salvaged Steel Coffee Table
« Reply #1 on: May 28, 2020, 11:34 AM »
The wood is fantastic. What’s your guess on wood movement?
Birdhunter
Offline Rick Herrick
« Reply #2 on: May 28, 2020, 01:03 PM »
That is a very fascinating table.  Those inlays blow my mind.  Nice work.
Offline Rob Z
« Reply #3 on: May 28, 2020, 01:10 PM »
Ron, that's cool, I like it.  I don't think I would ever be able to think of stuff like this. [embarassed]
Where did you get the piece of steel?
Offline mike_aa
« Reply #4 on: May 28, 2020, 01:22 PM »
That's a creative marriage of wood and steel!  Nice look and execution!
Thanks for sharing the photos.
Mike A.
Offline rvieceli
« Reply #5 on: May 28, 2020, 06:39 PM »
Thanks everyone.
Wood might move 1/4 to 1/2 maybe
Steel came from a local scrap yard. They had a bunch of short pieces of H beams a while back.
Ron
Offline Richard/RMW
« Reply #6 on: May 28, 2020, 11:41 PM »
Ron, that's stunning. Great job photographing it also, the fifth photo had me entranced due to the optical illusion of seeing thru the steel.
Did you use origin for the inlays?
RMW
Offline rvieceli
« Reply #7 on: May 29, 2020, 06:41 AM »
@Richard/RMW
Thanks. No Origin Shaper for the inlays. Router and Chisel.
Ron
Offline Richard/RMW
« Reply #8 on: May 29, 2020, 07:29 AM »
@Richard/RMW
Ron
Dang, that's so... craftsman-like.  [not worthy] Beautiful work.
Was the photo preplanned or serendipitous?
RMW
Offline ear3
« Reply #9 on: May 29, 2020, 07:59 AM »
@rvieceli Wow, what a bang up job on the inlays, which make the table much more interesting than if it were just the slab.  Next time I do some slab work, I'm definitely going to try that method.
I noticed that most of the inlays run perpenidcular or diagonal to the slab grain (with a couple of exceptions) -- is that just an aesthetic choice, or is there a structural reason for it?
« Last Edit: May 29, 2020, 08:03 AM by ear3 »
Offline rst
« Reply #10 on: May 29, 2020, 08:27 AM »
Marvelous work, as much art as furniture.
Offline rvieceli
« Reply #11 on: May 29, 2020, 11:23 AM »
Thanks so much folks. Really proud of the way this one turned out.
Richard, Just dumb luck on the illusion.  [big grin]
@ear3 Edward many of the inlays are there to repair cracks or checks in the slab. Those cracks mostly follow the gain in the piece. So it makes sense to have the inlays go across the grain to stabilize that area. I don't trust the long term viability of using just epoxy to fill those cracks so I try not to do too much epoxy fill.
Ron
« Reply #12 on: May 29, 2020, 12:07 PM »
Nice job Ron...very nice job. I really like the inlay within an inlay look.  [big grin]
What prompted you to use square/rectangular inlays?
Are all the inlays walnut and are they all the same thickness?
Offline ear3
« Reply #13 on: May 29, 2020, 12:20 PM »
Got it.  Thanks.
Ron
Offline rvieceli
« Reply #14 on: May 29, 2020, 01:31 PM »
Thanks @Cheese   the inlays are all walnut. I don’t like to mix species. But there’s enough variations even in the same piece to get different looks. Also the grain direction and pattern gives contrast.
The thickness ranges from about 5/16 to about an inch depends on the repair. With the different thicknesses the pieces can interlock where they over lap.
As for the shape I just like squares and rectangles better. 😃 plus they interlace better
Ron
Offline Richard/RMW
« Reply #15 on: May 29, 2020, 01:57 PM »
No way...
That should be entered in a contest.  [not worthy]
RMW
Offline jpmeunier
« Reply #16 on: May 29, 2020, 03:31 PM »
Was this for a customer? I'm curious what kind of money such a unique and well executed piece can demand.
Offline dragoneggs
« Reply #17 on: June 02, 2020, 02:18 AM »
Agreed... I am a long time wanna be professional photographer.  Sometimes dumb luck happens if you take enough shots but that is exceptional even with some planning.  Love the table too!
Offline Svar
« Reply #18 on: June 02, 2020, 04:02 AM »
No dumb luck here. Mirror in the symmetry plane will give see through illusion from any angle.
« Last Edit: June 02, 2020, 04:04 AM by Svar »
Offline Euclid
« Reply #19 on: June 03, 2020, 09:21 AM »
I think Svar is right, isn't he?  If the illusion didn't work, it would mean that the legs/feet and the steel were not at right angles, surely?
