Author Topic: Wall-hugging shelf for my phone and IPad  (Read 1100 times)
Offline Packard
« on: November 28, 2022, 04:03 PM »
I added a breakfast bar to the sunroom the other day and since it is the pass-through area from the garage, it became the logical place to recharge my IPhone and IPad.
I didn’t want to eat up any table so I added a wall-hugging shelf for the electronics.
The shelves themselves are made from 1-1/2” x 1-1/2” pine.  They are mounted on a piece of 1/4” thick birch plywood using glue only.  The power strip is mounted under the counter.
I had only space for 6-1/2” width, but that seems fine.
I applied four coats of wipe on poly + one coat of butchers’ wax applied with 0000 steel wool.
A small project finished on one evening, but I like it.  It suits the pared down Scandinavian modern look I am going for.
Offline Packard
Re: Wall-hugging shelf for my phone and IPad
« Reply #1 on: November 28, 2022, 04:06 PM »
I loaded three images but only two appear.  Here is the missing image.
Offline neilc
« Reply #2 on: November 28, 2022, 08:36 PM »
Nice and simple.  Where do the power cables connect to power?
Offline Packard
« Reply #3 on: November 29, 2022, 10:12 AM »
The power supply is mounted underneath the counter.  Unfortunately the wires are visible  as are the chargers.
I originally planned on using a “conference table pass through” outlet.  These come pre-wired with a cord and a plug.  I only had to drill the hole and install it.  A tidy installation and fairly economical (I found them on Amazon.com for $30.00 to $50.00).
But I did not read all the specs carefully.  The most powerful charger listed 18 amps split between three outlets.  It would work, but I am used to the 20 amp versions I am currently using.  They would charge at least 3 times faster.  I might still make that change.  It depends how annoyed the visible chargers make me.
If I were starting over, I would have used 3-1/2” stock to wrap the counter.  That would have hidden the chargers.
Offline krudawg
« Reply #4 on: December 29, 2022, 09:51 PM »
That is cool. Well done
Ted
MFT/3, DF 500, Hammer K3 Winner, TS55,  Sjoberg Elite 1500 Workbench, Fuji MiniMite4 Platinum, OF1400, CT MIdi, CT26, RO90, ETC-150, OF1010 EQ-F
Former Marine, Vietnam Vet
Offline gunnyr
    • Compass Custom Creations
« Reply #5 on: December 30, 2022, 08:50 AM »
Very nice and clean!  Bravo! [thumbs up] [thumbs up]
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|ETSC 125|DTSC 400|RO 90|RO 150|RAS 115|OF 1400|OF 1010|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|OSC 18|CTC SYS|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|STL 450|DUO-SET|SYSLITE KAL II
Offline Packard
« Reply #6 on: December 30, 2022, 09:39 AM »
Thanks.  It has worked out well.
If you ever decide to do something similar, first mount the chargers and attach the cables.  I did not do that.  The uppermost “shelf” is at the very limit of the cable I have.  If I had mounted the assembly a half inch higher, it would not have reached.
Of course longer cables are available, but I had never even checked before mounting the shelf unit.  I should have been smarter than that.
I was not planning to use the Apple cubes for charging.  As I noted above, I planned on using the unit that goes through a 2-1/2” hole in the work surface of the breakfast bar.  But the 12 amp charger (devised three ways is only 4 amps) would take forever to charge.
Charging time is relevant as Apple now advises not to charge overnight.  I though the reason would have been battery life, but I read recently, it is out of concern for fires.
The genuine Apple cubes are safe, but many people use other makes.  I am using Apple chargers, but I am still not charging overnight or when I leave the house.
Hey guys, don’t trash too many brain cells on New Year’s Eve, but do have a happy and healthy one.
Packard
