Author Topic: Wall Hanging Plane Tray  (Read 776 times)
Offline carrera4s
« on: May 04, 2020, 09:30 AM »
I recently made a wall hanging plane tray to store my hand planes.  The planes simply slide in and when I drop them down, they hook under the top bracket to hang safely there.  To remove, I simply lift them and take them out again.  The back is pine shutterply and the brackets are from African Rosewood .  the brackets are lined with suede leather to protect the paint / japanning.
Offline Rob Lee
  • Festool Dealer
    • Lee Valley/Veritas
Re: Wall Hanging Plane Tray
« Reply #1 on: May 04, 2020, 10:44 AM »
Nice work - and I see you're planning ahead too....a few empty slots on the rack.... [smile]
Cheers -
Rob
Offline carrera4s
« Reply #2 on: May 04, 2020, 10:47 AM »
Thanks Rob,
The planes for those empty slots are already in the cupboard - they just need to be restored before they get added to the tray.  ;)
Offline GoingMyWay
« Reply #3 on: May 04, 2020, 11:31 AM »
Nice work.  Are the brackets screwed in the from the back?
Inquiring Minds Want to Know
Offline mike_aa
« Reply #4 on: May 04, 2020, 12:53 PM »
Well done!  Thanks for sharing!
Mike A.
Offline carrera4s
« Reply #5 on: May 04, 2020, 03:27 PM »
Jip, they are screwed in from the back.  Even the strips between the planes are held in place only with friction and short pieces of double sided tape (they fit quite snugly) - this way, should I one day decide to build a tool cabinet from nice wood, I can take it all apart and re-use it.
Offline HarveyWildes
« Reply #6 on: May 04, 2020, 09:21 PM »
Very cool design.
Offline ear3
« Reply #7 on: May 05, 2020, 07:39 AM »
Nice call on the suede lining @carrera4s I have my nos. 7 and 8 hung in my tool cabinet exactly like that as well to maximize efficient use of space, but I would like to redo the brackets using your lining idea to decrease the possibility of wear over time from popping them back in and out.  What adhesive did you use to apply the lining?
Offline carrera4s
« Reply #8 on: May 05, 2020, 07:53 AM »
Hi Ear3,
I used contact cement.  You can also use hide glue - according to one YouTube video I saw the hide glue actually performed better (that was in a tail vice application).
