Author Topic: Underbench cabinet  (Read 7299 times)
Offline neilc
Re: Underbench cabinets
« Reply #30 on: January 17, 2021, 10:33 AM »
Like poetry with wood, Derek!
Offline derekcohen
    • In The Woodshop
« Reply #31 on: January 17, 2021, 11:05 AM »
Thanks Neil!  :)
Visit www.inthewoodshop.com for tutorials on joinery, hand tools, and my trials and tribulations with furniture builds.
Online Joelm
« Reply #32 on: January 17, 2021, 11:50 AM »
Beautiful work Derek.
I've only recently found your website after starting hand tool work. What a fantastic resource you have created!
Offline derekcohen
    • In The Woodshop
« Reply #33 on: January 17, 2021, 06:53 PM »
Thanks Joel. I hope you enjoy reading the articles, and finding helpful answers.
Offline derekcohen
    • In The Woodshop
Cock ups
« Reply #34 on: January 18, 2021, 10:23 AM »
I recently wrote that I aim to build as best as I can. Sometimes it does not go well at all :(
I make two repairs today. Usually, the mistakes I make are as I get spatially challenged, and cut the wrong side of the board. The first one here was being a little over-enthusiastic with a block plane when trimming a drawer front (a few days ago). The problem is difficult to detect from a distance ...
... but close up .... !
darn. The drawer front is part of a set of three. It cannot simply be replaced. One also cannot glue a filler to the side of the board.
But one can add a filler to the drawer divider ...
Here it is glued proud ...
When trimmed flush, it is nearly invisible. With a coat of finish, it will be ...
The second fix was this ... after all the mention I made about the importance of a combination square to ensure the side was square to the drawer front ... well, one got away from me. When I placed the three sides on a flat surface, the far end of one side was about 3mm high.
This was the fix. Can you spot the repair?
Eagle eyes will note that there is a light line. This is where a triangular fillet was glued in, and planed flush (The corresponding top side needed to be planed down to fit inside the drawer case).
« Last Edit: January 18, 2021, 10:28 AM by derekcohen »
Offline neilc
« Reply #35 on: January 18, 2021, 11:22 AM »
Great tips.  The challenge is not making mistakes, but effectively recovering from them!
Offline derekcohen
    • In The Woodshop
« Reply #36 on: February 07, 2021, 09:47 AM »
Perhaps I need to explain the title, "Dovetailing for Blood". In part, the description comes from a book, "Backgammon for Blood", by Peter Becker I read about 4 decades ago. It's about taking the game to the most competitive level. This series of articles is not a how-to about dovetailing; it is about the strategies I use when building drawers. I offer them for discussion and your interest.
This is the drawer in question.
In the previous article, the focus was on strategies for connecting the drawer front and drawer sides via half-blind dovetails. The aim there - and continued here - is to complete the dovetailing in such as way that the drawer may be glued up, and dry inside the drawer case. The advantage of drying inside the drawer case is that a good fit is assured.
Today the drawer back needs to be attached with through dovetails.
For interest, here are the chisels I used: Kiyohisa slicks and Koyamaichi dovetail.
Noticeable in the drawer above is that there are no grooves for the drawer bottom. These will now be added using a plough plane and a sticking board to hold the work...
The drawer sides are around 7mm at this stage, with the expectation that they will end up at 6mm. The inside and outside faces have been planed. The groove is 3mm deep ...
The groove in the 18mm thick drawer front is 6mm deep ...
The drawer back receives a shallow groove ...
Reason?
The drawers are designed for a tool cabinet. Unlike drawers for the home, where the backs are lowered, these drawers will have a full rear, in height, ending at the drawer bottom. We start with drawer backs exactly the same dimensions as the drawer front. The lower section needs to be removed. The top of the groove marks this position.
The waste is removed on the table saw, a smidgeon grace ...
 ... and the machine marks then planed away.
It needs to be stated that drawers are not the same as boxes. While they may both be dovetailed, the drawer width is determined by width of the drawer case. It cannot be larger or be smaller. The drawer front and back are made as a pair, and their dimensions are not permitted to be altered.
With boxes, one can leave dovetails proud, and then level them to the sides. Or one may level the sides to the dovetails. You cannot do this with drawers, especially if the game plan is to aim for the glued up drawer drying in the drawer case. Consequently, the dovetails must end up flush with the surface ....
We move over to dovetailing the rear:
The first step, with 6 drawers of the same height and width, is to make a template for the spacing of the dovetails.
While the template stretches across the board, the area of importance is above the drawer bottom.
Mark out the tails, as usual, but then flip the board so that you are sawing from the inside of the drawer ...
Again, this is not a box. The inside of a drawer is seen, and it is important to keep the baseline as clean as possible, that is, no over-sawing.
Similarly, when removing the waste with a chisel, start with the outside face of the drawer, and finish with the inside. That way there is less danger of inadvertently chiseling over the baseline.
Now ... the interesting part comes with transferring tails to pins. This can make-or-break the drawer.
Here we see the tail and pin boards aligned. But are they?
A square shows that the side is out at least 1-2mm at 300mm (12").
Left like this, the drawer will not sit flat. It will act as if it has a twist. Significant efforts will need to be made to align the drawer in the case. It becomes essential that the side is aligned accurately. This can be a little fiddly, but a long square helps considerably ...
At some point, someone will mention the side-alignment fixture designed by David Barron. This is a wonderful concept, however it excels at making boxes and not drawers. Look here ...
The tail and pin boards are not aligned at the square ends (which would enable David's fixture to be used). They are aligned on the reference side, which is the lower edge of the drawer sides. You are aligning from the left side of these boards ...
Having transferred and sawn the tails, the bulk of the waste is removed with a fretsaw (as detailed before). Here is a reminder - first chop out the waste from the outside face, half way down ...
... and then complete from the show-inside face.
My preference is to angle the chisel slightly away and create a "tent" ...
This is then removed with a slicing paring action, again form each side to the centre ...
Use a narrow chisel to pare the ends: having first sawn these away, the remnants for paring lie above the chisel walls (again discussed in a previous article) ..
This is what we are after: flat ...
Dry fit ...
The drawer must fit the drawer case ...
It does, but we are not finished. More in a while ..
Offline derekcohen
    • In The Woodshop
« Reply #37 on: February 07, 2021, 11:45 AM »
The aim is to glue up the assembled drawer and let it dry in the drawer case.
This drawer fits ...
... however it is a tight squeeze and I know that there are issues which need to be corrected before glue is applied. It is the same for every drawer.
Each drawer needs to go through an assessment, trouble-shooting for issues, until the drawer moves smoothly.
I need to point out at this stage that, although drawers are made in batches (a row), each drawer is fitted, tuned, and glued up before assembling the next drawer. At this stage, six (of ten) drawers have been completed to this stage. There is one further stage after this chapter.
So we pull the drawer out of the case. It comes out with effort. The sides twist slightly - I can feel one side is moving more freely than the other. Something is causing it to hang up.
Examining the half-blind dovetails, the first item of note is that there is a slightly raised pin ...
Since the drawer is a dry fit, it is a simple matter to knock it apart to make any fixes.
The pin is planed flat.
I note that the one drawer side sits a little proud at the underside, about 1mm ... maybe not even that much ..
This is also planed down.
The drawer back is presented to the case opening ...
It is a tight fit now. It will be a tighter fit later if there is moisture in the air. The drawer back is removed and the height planed down by about 1mm. Re-assembled,
the sides now are higher ...
The sides are planed to the side height ...
I can still feel a little more stickiness on one side. Are the sides flat, or has there a cup developed to create a high spot?
Yes. Slight but it is there ...
Plane this flat. Just a few thin shavings ...
Now the drawer is moving well - it feels taut, but free.
The case is waxed, not so much at this stage to promote ease of movement, but to prevent any glue adhering to the sides ..
Now we are ready to glue the drawer parts. Here are the items involved ...
I am using Titebond Liquid Hide Glue. I like that it has a longer open time, that it is reversible, repairable, and cleans up with water. There is a spatula for application, a fishtail chisel handy if a corner needs to be cleaned, a small mallet, and a wet rag.
The hide glue is decanted into a small bottle ...
This small bottle is a game changer! I was watching Rob Cosman and noted that he used small bottles as well. I found a bunch on eBay. What they do is let you deposit glue in exactly the spot you want to do, and then the spatula lets you spread it around.
I only glue one side of the joint, but there is enough for both sides ...
It is important that the sides are seated flush ...
The drawer looks good ...
... and, importantly, slides into the case smoothly and firmly.
Offline zachjowi
« Reply #38 on: February 12, 2021, 11:45 AM »
Great work! Looks nice
Offline derekcohen
    • In The Woodshop
« Reply #39 on: March 15, 2021, 01:07 PM »
Drawer Bottom and Slips
One of the least pleasurable areas of drawer making is fitting drawer bottoms. Why? Because there always seems more to do than anticipated - there are more panels to machine to thickness and area, and this feels like it is endless. Mindless.
Before starting on the bottoms, the drawer fronts are planed, chipped dovetails repaired, and fine-tuning of the bottom-less drawer is completed ...
Link to the fixture here:  http://www.inthewoodshop.com/ShopMadeTools/DrawerPlaningFixture.html
One of the rules I set for myself at the start of this project was that, being a just for the workshop, I would use as much scrap or cheap wood as I could scrounge up. The Jarrah drawer fronts are the exception. The case is Merbau stained to match the Jarrah drawer fronts.
Over various projects, I save bits which I think may be used ... don't we all :)   For now, offcuts of Tasmanian Oak, which make great drawer sides and drawer bottoms.
Modern machines, such as jointers and thicknesser/planers, enable the redesign of cabinet parts. In this case, drawer bottoms. One can use the minimum thickness, saving weight and wood.
I am very fortunate to own a Hammer A3-31, which turns the scrap into usable boards ...
These boards ended up a smidgeon over 5mm thick. The grooves in the drawer sides are 5mm wide and 3mm deep. The drawer sides are 6-7mm thick.
Joining such thin boards is quite easy - no clamps used. Just blue tape :)
Butt two boards, and stretch the tape across the join. The blue tape has some flex to it, and the stretch contracts and pulls the joint tight ...
Do this with all the joins, and then lay a strip down the seam (which is to prevent glue squeezing out ...
Flip the boards and insert glue into the seam. Wiggle the boards open-and-closed to spread it evenly.
Lay flat and wipe away the glue (Titebond II) squeeze out with a wet rag. Freshen this for each join.
Yes, I know many warn against this practice, but I have not experienced any problem with finishes. Once clean, tape the side to hold the joins tightly together ...
The machining and glueing takes all day, and finally ...
Of course - Murphy's Law - the next day I discover that I am going to be one drawer short, and more offcuts are found and glued together. Smaller pieces this time ...
Then it is time to unwrap the presents and make a blue tape Christmas tree ...
The drawer bottoms are roughly sized, and the top side is sanded to 240 grit (the underside will not be seen, so just leave it be) ...
Why sand? Well, it is just easier. The panels are curvy, not flat, and would be too awkward to hand plane. This is what sanders are for. What I have here is a Mirka Ceros, which uses Abranet mesh. Hooked up to a vacuum cleaner, the result is the closest thing to dustless sanding.
One edge on the underside receives a very shallow rebate. This is to enable the panel to fit the groove. The plane here is a Veritas skew block plane, which has a nicker as it is planing across the grain. It has a fence and a depth stop. Great little plane ..
The width of the panel is measured. Note that the drawer bottom runs across the drawer (expansion then takes place front-to-back) ...
After ripping to size on the table saw, fine tuning takes place with a shooting board ...
Time to fit the drawer bottom.
Of course, if it is too tight, it will not run smoothly. But even if it appears to run smoothly, it can be creating a potential problem.
In the earlier chapters (Dovetailing for Blood), one aim was to make the dovetails an exact depth so that the newly glued drawer could dry in the drawer case. The other aim was to fine tune the drawer (minus the drawer bottom) to move smoothly in the drawer case. Now, if when adding the drawer bottom, the smoothness is lost, then we know that something is wrong.
So, the drawer bottom is dropped part way ...
... and this is presented to the drawer case at this point. Will it run as smoothly as before?
If the drawer appears to have tightened in the case, the problem may be that the sides are slightly bowed. Try tapping the sides to push them flat ...
The drawer bottom is lowered further, and again tested for fit ...
All good, and the bottom is tapped into the groove behind the drawer front. A good fit :)
Slips are a traditional way of reinforcing thin drawer sides to increase the surface area and reduce wear over time to the runners. Usually when making slips, I would groove the slip rather than, as here, the drawer side.
Here is one of Richard Jones' wonderful illustrations ...
I decided to do something a little different this time. I am not sure whether this can be termed a true slip, but it functions exactly the same way. The drawer sides have a shallow 3mm groove. To support the thin drawer side, as well as support the drawer, a 6mm square Jarrah section was glued to the drawer side directly under the drawer bottom. Care was taken to allow the drawer bottom to remain free to move.
Drawer stops were added ...
All the drawers fit and move smoothly ...
And this is what it looks like at present ...
Of course, there is the case back to make, and the handles to fit .... and then the fun bit begins - fitting out each of the 10 drawers for tools. Lots to do still.
Offline CeeJay
« Reply #40 on: March 15, 2021, 04:43 PM »
Beautiful work Derek - thanks for sharing in such great detail.
Offline derekcohen
    • In The Woodshop
« Reply #41 on: March 22, 2021, 01:25 PM »
These are final pictures of Stage One. "Stage One" - what does that mean? Well, the first step is to build the cabinet under the bench. The second stage will be to fit out the drawers for the tools. I plan to do some of the latter shortly, and some later. I will post these as they are done. For now, here is the underbench cabinet ...
The rear, before the back was installed ...
The front. The ring pulls are antiqued brass (they are not shiny). I need to work them a little more to remove the still-new look. These were chosen as they drop down and do not project out from the front of the cabinet  ...
Under the bench ...
The bench top received a little flattening, and a single coat of danish oil ...
Someone is sure to ask why the cabinet is low. The answer is that there needs to be space for hold downs ...
The drawers manage about 90% extension ...
One of the first fit outs will involve this set of Kiyohisa bench chisels I have been collecting one-by-one (these are no longer available) ...
And here is one of the small drawers ...
Thanks for supporting the build to date. Hopefully there were some aspects that will prove helpful.
Offline neilc
« Reply #42 on: March 22, 2021, 04:00 PM »
Very nice work, Derek!  Appreciate the level of detail and your time in sharing it!
« Reply #43 on: March 22, 2021, 06:49 PM »
This must be one of the finest utility cabinets ever made. Unobtrusive yet superb.
Thanks for sharing the process.
Offline derekcohen
    • In The Woodshop
« Reply #44 on: April 05, 2021, 09:33 AM »
What lies behind drawer #1?
The underbench cabinet is done ....
... and now the drawers are being filled, starting with the centre drawer in the top row.
There are 10 drawers in all, and the aim is to use the space as efficiently as possible. Into this cabinet will be those tools I want close at hand, and to access readily.
The centre drawers in the top two rows are for marking tools. The top drawer will be for squares I use all the time.
Opening the drawer produces a 300mm Starrett combination square, a 150mm Starrett double square, and a Veritas Sliding Square. these are french fitted into a Jarrah panel (more on the french fitting shortly). ...
Now you know how I like secret drawers :)  - well, if you slide this panel back ...
... you find the treasure drawer with a pair of Colen Clenton mitre squares infilled in Sheoak, and pair of Chris Vesper 4" and 7" squares infilled in Tasmanian Blackwood, and a 2x2" Bridge City saddle square ...
The Jarrah panel for the latter squares is a loose fit, snug at the sides and about 5mm of expansion space at the end. At the right side of the photo are the rails, which were glued to the sides (but not the loose panel)
Below is the upper panel for the Starretts and Veritas squares. The panel needed to be thin - it is 6mm thick - and cut outs made rather than french fitted. This was to save space by having the tools handing down rather than sticking up.
The eagle eyed will have noticed that the rear of the drawer was cut away. This was to allow for the upper tray to slide past the drawer back, which takes advantage of the space behind the drawer when it is opened.
There was a little extra shaping as the body of the Veritas hung down lower than the other squares.
The upper tray runs on the Jarrah rails attached to the inside of the drawer sides. Finally, there is a rail added above the tray to prevent it tipping as it is slid back. This is in the same Tasmanian Oak as the drawer sides.
The drawer manages about 90% extension without any support.
Offline Alex
« Reply #45 on: April 05, 2021, 09:44 AM »
Truly amazing work, Derek, you're a regular old-fashioned master carpenter.
Offline derekcohen
    • In The Woodshop
« Reply #46 on: April 17, 2021, 11:54 AM »
Drawer #2 - the skeleton drawer  [eek]
Here is the second drawer to be filled ...
Why "Skeleton Drawer"? Well, it does not contain dark secrets, buried bodies, or other clandestine material   :D
It is just the name I have given to the drawer design since, unlike Drawer #1, which hid a jewellery layer, this discloses all from the outset.
The drawer holds my Kiyohisa chisels: paring slicks and bench oire nomi. It is important to be able to find, and extract them easily when working at the bench.
The paring chisels lie in the upper level ...
These slide into the cabinet and, below, are the oire nomi (3mm through 30mm) ...
There are two others at the rear, a second 30mm and a 36mm ...
This is a clearer presentation ...
The chisels lie on shaped rests. The blades lie on rare earth magnets, which prevent them moving from the rests when the drawer is opened and shut, or the top layer extended into the cabinet ...
The wood used for the rests and the slide is West Australian Sheoak ...
The rear of the drawer, the drawer back, has been cut away above the second dovetail. This is how the the top layer slides into the cabinet ...
I trust you are finding this fun as well :)
Offline tjskinny
« Reply #47 on: April 17, 2021, 01:35 PM »
Truly beautiful work Derek !   I love these detail builds you share with us!  Thank you so much for taking the time to photograph and document everything.
Offline hdv
« Reply #48 on: April 17, 2021, 01:57 PM »
This thread is pure entertainment to me! Plus part education (thanks for showing in detail how you approach your projects) and part envy (both for the beautiful chisels and the workmanship). No telly show that even comes close!
Offline Tinker
« Reply #49 on: April 19, 2021, 03:29 PM »
And for all of the explanations THANK YOU
Tinker
Wayne H. Tinker
Offline Vondawg
« Reply #50 on: April 20, 2021, 09:49 AM »
Yes! We are fortunate to be able to look over your shoulder, thanks to your master workmanship and you documenting it....thank you!
Offline derekcohen
    • In The Woodshop
« Reply #51 on: April 26, 2021, 12:11 PM »
Drawers 3 and 4
Moving across to top right. This is a drawer for wheel cutting gauges ...
I went through many ideas before coming up with this design. Simple, but effective for access and keeping the gauges from moving around.
Two Tite Marks with fine adjusters and two Veritas gauges (these were a steal several years ago - Anniversary gauges in stainless steel. Brilliant!). The gauge at the front is one I built. My idea of Veritas-going-Japanese :)
Everything is removable. The slots for the arms were made with a fluting blade in a Veritas Combination Plane ...
Drawer #4 was much more work. Much more.
This is the middle drawer, second row. The drawer above holds large squares. This drawer holds more squares, small ones for joinery ....
The only way to keep these from moving around in a drawer is to french fit them ...
The little "dot" at the top end is a rare earth magnet. This is to keep extra blades (for the squares) from getting lost.
This is where I moved the Veritas sliding square. There is a Vesper small double square along with a similar Starrett. These are so useful for checking dovetail sockets. Below is my favourite double square, a 4" Moore & Wright, along with a 4" vintage Browne & Sharpe machinist square.
Now slide the top tray away, and below are large and small Starrett dividers, and a vintage Starrett compass ...
Again french fit to prevent any sliding around ...
I managed to get all these rules inside the drawer - Starrett and Mitutoyo in metric and imperial ...
Easier to stack them this way ...
Two more drawers, and I am going to call it quits for a while. Lynndy has orders for night stands.
I hope you are still having fun! :)
Offline rmhinden
« Reply #52 on: April 26, 2021, 01:19 PM »
Very impressive as usual!
Bob
Offline Imemiter
« Reply #53 on: April 26, 2021, 02:25 PM »
This bench belongs in a museum. But not yet!
Thanks for the quality thread Derek.
CSX T18+3 TID18 HKC55 OSC18 OS400 OF1010 LR32 DF700 RAS115 DTS400 ETC125 CTSys CTMidi CT-VA
