Author Topic: UJK Parf Guide System Storage Box  (Read 2343 times)
Offline cubevandude
« on: January 15, 2019, 11:32 AM »
I thought I would share my version of a storage box for the UJK Parf Guide System with a sliding lid.  I decided I would try dye for the lid and used a icing dye in copper by Wilton.  I then sealed the wood with 5 coats of Minwax satin wipe on polyurethane.  There is even room for the instructions.  I still have to find a magnet to hold the 3mm bit.  Its made from 9mm Russian Baltic Birch plywood with a 4mm lid.
290801-0
290803-1
290805-2
« Last Edit: January 15, 2019, 11:47 AM by cubevandude »
Offline Bernmc
Re: UJK Parf Guide System Storage Box
« Reply #1 on: January 15, 2019, 02:39 PM »
Very nice.
Offline tony_sheehan
« Reply #2 on: January 15, 2019, 03:20 PM »
That's very nice.
At first I thought here's someone with too much time on their hands, but on reflection the parfguide system is not something you're gonna use all that often so to keep it in a good quality storage box actually makes a lot of sense. Well done!
Offline cubevandude
« Reply #3 on: January 16, 2019, 10:09 AM »
Yes, it was a lot of work, but the system comes in a 4 foot round tube with the parts in plastic bags.  Not an easy thing to access or store easily.  This way I can open it up and use what I need right out of the box and everything is protected from damage.  I have never used dye as a finish before and thought it would be a good thing to try and match the UJK colours.  Its hard to tell in the pictures, but the dyed grain looks really cool.  Would be better with a gloss finish I think, but I may just keep adding layers of satin and see where that goes.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #4 on: January 16, 2019, 01:52 PM »
Excellent work - I like the idea of the top opening which is an improvement on my own efforts.
Offline online421
« Reply #5 on: January 16, 2019, 04:56 PM »
I still have mine in its original tubes, If it survived the postal system handling from UK to New Zealand, then it will live happily in my workshop.
I used my UJK Parf guide and made my MFT table using Saligna, or Sydney Blue Gum (no blue tho). the hole is very very tight for the UJK dogs I bought. definitely not as easy as it seems on Youtube with table top made of MDF.
Griggio Unica400
Felder AD951
Masterwood OMB1V
Omga T55300
SCM 5 RCS1100
Casadei FV110
Comatic DC40
Chicago Pneumatics CPRS10500
Ceccato CDX 12
Holytek DC006
Festool DF700XL, LEX3, OF1010, OF2200 CT36
Starmix 1635
Danfoss VLT 2880
Sicar TOP6
« Reply #6 on: January 17, 2019, 12:36 AM »
That is an amazing top.
The holes are designed to be quite tight in MDF and so I am not sure about your wood. You can use a little Vaseline in the holes that you use most for the dogs. After time they will ease a little as the wood dries further.
Offline Mario Turcot
« Reply #7 on: January 18, 2019, 10:47 AM »
I read your comment (no glue tho) and I was like HOW?
The first time I read your comment I read glue instead of blue so I was a bit confused  [wink]
Awesome top by the way.
« Last Edit: January 18, 2019, 11:48 AM by Mario Turcot »
Mario
Offline Paulhoward
« Reply #8 on: September 01, 2020, 11:19 AM »
Just saw this post I have parf guide system mark 1 and 2 both are great to make replacement tops and jigs. I will use the design for boxes for safe keeping of my PGS. GOOD WORK!
Offline Don T
  • Phoenix, Az
« Reply #9 on: September 01, 2020, 05:02 PM »
That is a well thought out storage and beautiful.
