Author Topic: Today's project  (Read 1664 times)
Offline Crazyraceguy
Today's project
« on: April 15, 2021, 07:13 PM »
Is a simple television surround. It is not structural at all. The TV is mounted to the wall. This just wraps around it, hiding the wires, outlets, etc.
It only protrudes 7" from the wall. It is solid on the left side but the right side has doors in the end. Each panel is individually opened. This allows access to the back of the unit, hides the cable box and whatever else. I'll try to get another pic when it gets installed.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Offline Jasonj888
    • Blog about woodworking and family life.
Re: Today's project
« Reply #1 on: April 16, 2021, 04:48 PM »
Nice work!
I'm starting a project soon that includes some laminate work surface. Hopefully I learned from the advice you gave me.
Offline cider
Re: Today's project
« Reply #2 on: April 16, 2021, 04:58 PM »
Very cool.  Definitely interested in the installed pic!
Re: Today's project
« Reply #3 on: April 18, 2021, 06:43 PM »
Nice work!
Cool, good luck to you. Be sure to come here and ask questions, if you have issues. Hopefully I have already made all of the mistakes and can help you around them.
Then post some pics when you are done.
CSX
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Offline Peter_C
Re: Today's project
« Reply #4 on: April 19, 2021, 01:23 PM »
Never really paid attention to TV covers before but I like that one!
Re: Today's project
« Reply #5 on: April 20, 2021, 06:07 PM »
I think it is supposed to get installed tomorrow. I'll ask the guys to send me a pic.
CSX
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Offline Jasonj888
Re: Today's project
« Reply #6 on: April 21, 2021, 12:52 PM »
Thank you!
I guess I do have one before I even start - I'm building furniture for a friend's design studio. It's a big u-shaped counter top supported by wall cleats and some cabinets. He is, of course, getting a smoking deal because he's a friend. All of his cabinetry will be painted white and he wants white lam. I've sourced the laminate, but I'm not totally sure on the front edge treatment. I don't want to do hardwood, like I have in the past, because it would need to be painted and would like it would get dirty and be hard to clean. Any recommendations for an edging to use? Thanks again!
Offline squall_line
Re: Today's project
« Reply #7 on: April 21, 2021, 05:32 PM »
I'm having a hard time not recommending the plywood-look edge banding that was being asked about this last month or so, just because.
Offline Jasonj888
Re: Today's project
« Reply #8 on: April 22, 2021, 03:47 PM »
I supposed every material has it's place!
Re: Today's project
« Reply #9 on: April 22, 2021, 06:26 PM »
The most durable thing would be 3mm PVC edgebanding, but it's not exactly practical for a DIY person. It comes in huge rolls for industrial use, but it would be hard to get for a single job.
Unless you are going with hardwood, the most common thing is just to use the same laminate as the top itself.
This is referred to as "self edge". It is generally applied before the top surface. This makes it less likely to be snagged by sliding something off of the top.
CSX
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Offline Jasonj888
Re: Today's project
« Reply #10 on: April 23, 2021, 11:24 AM »
Thanks for the advice!
Offline Bob Wolfe
Re: Today's project
« Reply #11 on: April 29, 2021, 10:46 PM »
Build the edge with plywood, cover the vertices edge with a strip of laminate then cover the top with the laminate overlapping the laminate edge and trim flush to the edge, then rout or sand a slight bevel to reduce sharp edge. Top and edge the same colour or different. You could add a narrow strip of hardwood to give a wider surface to ease the edge.
Might work for you.   BW
