Author Topic: Steps in our fifth wheel  (Read 624 times)
Offline Don T
  • Phoenix, Az
« on: June 10, 2020, 09:08 PM »
The steps into our kitchen were plastic coated mdf and the plastic was peeling off. So I made these out of oak I had in the shop. The finish is not my best but did not want to break out the spray gun.
Offline ear3
Re: Steps in our fifth wheel
« Reply #1 on: June 10, 2020, 10:37 PM »
Finish looks good to me.  Is the arc on the lower step slightly different than on the top one, or is that just an optical illusion from the way the wood grain on the lower step is biased towards the left?
Offline Don T
  • Phoenix, Az
« Reply #2 on: June 10, 2020, 10:51 PM »
It’s an optical illusion. I made the top step first and.  Copied it onto the bottom step. As long as you don’t look close you can’t see the finish issues. I’m probably a bit OCD when comes to this stuff.
Offline Gregor
« Reply #3 on: June 11, 2020, 05:10 AM »
I learned over the years that there is no real point in telling people about all the flaws of a thing I made (except in cases these could lead to accidents, death or destruction)... as happiness seems to stem from the absence of information, at least it seems to be like that for most humans that I know.
The thing you made looks beautiful, no need to doubt yourself.
« Last Edit: June 11, 2020, 05:15 AM by Gregor »
Offline Don T
  • Phoenix, Az
« Reply #4 on: June 11, 2020, 10:00 AM »
I learned over the years that there is no real point in telling people about all the flaws of a thing I made (except in cases these could lead to accidents, death or destruction)... as happiness seems to stem from the absence of information, at least it seems to be like that for most humans that I know.The thing you made looks beautiful, no need to doubt yourself.
Thanks I appreciate your kindness. And you are correct about the absence of information does bring happiness.
« Last Edit: June 12, 2020, 09:44 AM by Don T »
Offline jobsworth
  • Festool Baby.....
« Reply #5 on: June 11, 2020, 10:38 AM »
looks great Don.
 Well Done
Offline Don T
  • Phoenix, Az
« Reply #6 on: June 11, 2020, 08:39 PM »
looks great Don.
 Well Done
Thanks Ron
