Author Topic: Stairs "floating" oak.  (Read 10105 times)
Offline Jak147
Re: Stairs "floating" oak.
« Reply #30 on: December 27, 2016, 06:34 AM »
Beautiful work, very jealous,
@Lbob131 it sounds like you should stay be staying at ground level
Offline RickyL
« Reply #31 on: December 28, 2016, 08:53 PM »
Truly Amazing! Is the metal an inverted pan with stiffeners?
Yes,
TXS, TSC 55REB, CTL Midi, BHC 18, C18Li, T18+3, PSC 420EB, Kapex KS120 EB, OF1400, EHL 65 EQ, ETS EC150/5, RO150 FEQ
Offline RickyL
« Reply #32 on: December 28, 2016, 08:54 PM »
Nice stairs  but  not that safe  with no hand rails.
And if your   like me  this year with broken  legs  from two  separate building site falls  off roofs   then two  hand   rails  are important.
When you get old and infirm that's another matter.
If they were the main stair I would put a second rail on the wall, but these are just in a bedroom.
You can use the verticle uprights as a hand rail I guess. They under tension so don't flex much.
Thanks.
Re: Stairs "floating" oak. Smarthome & Insteon out of business.
« Reply #33 on: June 19, 2022, 02:18 PM »
Very nice. Are they a US based thing? I've not seen them here in the UK. I have "Lightwave" which is very similar by the sounds, but UK.
FWIW...here's the keypad and the switching module I mentioned.
http://www.smarthome.com/insteon-2334-232-keypad-dimmer-switch-dual-band-6-button-white.html
http://www.smarthome.com/insteon-2443-222-micro-on-off-module.html
Just found out today that Smartlabs the manufacturer of Smarthome & Insteon products is no longer in business.  [mad] This is the latest information from June 10th, 2022.
https://www.reviewgeek.com/115308/insteon-may-have-joined-the-list-of-failed-smart-home-companies/
https://www.reviewgeek.com/120635/insteon-is-back-thanks-to-a-small-group-of-passionate-users/
Offline X
« Reply #34 on: June 19, 2022, 06:08 PM »
HomeSeer has a plug-in for Insteon.
