Author Topic: Solid edge band clamps  (Read 1627 times)
Offline Richard/RMW
« on: March 11, 2023, 03:32 PM »
I'm mulling over doing a project with a bunch of birch ply panels, applying 1/4" birch solid edge banding, hence the need for a bunch of edge clamps. Rather than buy them for one-time use, I'm wondering if anyone has suggestions for DIY alternatives to the Rockler-type clamps?
I have a bucket full of ninety-nine cent spring clamps, maybe I can round up some old bike inner tubes or similar and add the rubber band to the clamps.
Appreciate any recommendations or alternatives.
Thanks,
RMW
Offline mrFinpgh
Re: Solid edge band clamps
« Reply #1 on: March 11, 2023, 03:37 PM »
There was a fine woodworking article about doing exactly this using bike inner tubes over spring clamps:
https://www.finewoodworking.com/2019/10/24/shopmade-clamps-make-edge-banding-easy
I think as long as you're using 1/4" or thicker banding, it should work out well.
« Reply #2 on: March 11, 2023, 04:41 PM »
 Bought some of those Rockler clamps when they had a sale and also some that Taylor Toolworks sell. Both styles have broad pads made of extra grippy rubber to grasp the surface of the board. I don’t think regular spring clamps will compare well but if you have enough to apply them side by side that will probably be good enough.
Offline ChuckS
« Reply #3 on: March 11, 2023, 05:08 PM »
I agree that the FW hack doesn't offer any extra surface grip. For one-time use, I have had success with the binding tape: https://www.leevalley.com/en-ca/shop/tools/supplies/adhesives/tape/70856-3m-binding-tape?item=25U0330
« Last Edit: March 11, 2023, 05:12 PM by ChuckS »
Offline Crazyraceguy
« Reply #4 on: March 11, 2023, 06:21 PM »
I have seen the innertube method done several times, but never done it myself.
I think it actually came first and Rockler created a ready-made version.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
Offline Peter Halle
  • Ain't so Small no More
« Reply #5 on: March 11, 2023, 06:36 PM »
After watching an Izzy Swan video I bought these.  Haven't used them on a project but in testing it held thicker 1/8" strips well.
The clamps and rubber bands:
clamps:  Clamps
rubber bands:  https://www.amazon.com/gp/product/B08377XG1Y/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
« Reply #6 on: March 11, 2023, 06:38 PM »
I haven’t seen those but assuming the bicycle inner tube fits over the jaws of the spring clamps the inner tube rubber will be a lot more grippy than the plastic overmold. Might work and is easily reversible.
« Last Edit: March 11, 2023, 09:40 PM by Michael Kellough »
Offline 4nthony
    • Slack for Recon Tools
« Reply #7 on: March 11, 2023, 07:22 PM »
I bought a couple pairs in medium and was pleasantly surprised by how grippy they were. I still use a lot of blue tape with my edge-banding but will probably grab a few more Bandy clamps when I see them on sale.
I have not tried the inner tube method but will give it a go after my next flat tire.
Recon Tool Notifications
Anthony
Offline afish
« Reply #8 on: March 11, 2023, 07:48 PM »
i used the inner tube and spring clamp method and it works good, you do have to make sure you get he right inner tube but otherwise no issue. The rocler ones look nice but when you need 50 or more it starts to add up.
Offline woodferret
« Reply #9 on: March 11, 2023, 08:01 PM »
I use the inner tube clamps.  Works fine and is grippy.  Except be wary of the rubber wearing out after a few years, as they start leaving marks.  Nothing a sand won't clean up though.
Offline Richard/RMW
« Reply #10 on: March 12, 2023, 05:07 AM »
Thanks all. I'd forgotten about Izzie's rubber band trick, I'll play around with that first before moving to inner tubes if needed. Found this also.
RMW
Offline mike_aa
« Reply #11 on: March 12, 2023, 04:03 PM »
If you've been around here a while, you might remember erock.  He no longer posts here, but has an instagram channel where you can find his take on making up a bunch of these clamps for not too much money:
https://www.instagram.com/p/BkD3WYFgKxx/?utm_source=ig_web_copy_link
I hope this helps!
Mike A.
Offline Richard/RMW
« Reply #12 on: March 12, 2023, 08:36 PM »
Hey thanks Mike. I haven't seen Eric post here in a while, he always had good stuff to share.
I stumbled across the YT video early this AM (up @ 4:30, forgeting the time change...) and ordered a 2 pack of tubes. Looks like a pretty easy project and I should be able to remove the tubes if I need to use the clamps for other stuff.
Did a second test run today using the lime green 3M painters tape and that worked fine. You'd burn thru a lot of tape for a 8' long section, so the clamps make more sense for bigger projects.
Thanks,
RMW
Offline Richard/RMW
« Reply #13 on: March 15, 2023, 07:54 PM »
So, they work as advertised and aren't too fiddly to make.
  • Clamps $1
  • Tubes 2 fer $14 = (26) 5-1/2" sections or ~$0.50/each
  • Time perhaps 5 minutes each, done in batches while listening to an audiobook/podcast
I'm gonna say they are worth the cost. Thanks for the input.
RMW
Offline Oldwood
  • Alberta, Canada
« Reply #14 on: March 15, 2023, 10:12 PM »
They look great! I am going to give them a try.
I bought the Lee Valley version when they first came out but found the bands too stiff. I think these will be much better.
« Last Edit: March 16, 2023, 02:17 PM by Oldwood »
Confucius
Offline mike_aa
« Reply #15 on: March 16, 2023, 01:41 PM »
@Richard/RMW
Nice Job!  Thanks for sharing.
Mike A.
Offline IronStool
« Reply #16 on: March 20, 2023, 01:52 PM »
I put together a set of 10 inner-tube spring clamps for a project last year and they worked great!
I picked up the inner-tubes for free at the local bike shop.  Mine were the used discarded tubes from bikes in for maintenance.
With the $14 I saved, I bought a Festool couple cups of coffee :-)
I thought my FOG handle was clever.  Now it makes me think I've just had too much sharp cheddar cheese.
