Author Topic: Smoking Hot Walnut  (Read 731 times)
Offline Birdhunter
Smoking Hot Walnut
« on: October 18, 2020, 03:57 AM »
I was ripping some 8 quarter (2”) black walnut in my 3 HP SawStop fable saw when the blade came to a smoking stop. This was a relatively new Forrestt combo blade embedded firmly in my beautiful walnut. Stuck hard!
Once I freed the blade and took a 30 minute breather, I mounted a Forrestt rip blade. Cut like warm butter. First time I ever used a rip blade. Definitely the right way to go.
Birdhunter
Offline ChuckM
Re: Smoking Hot Walnut
« Reply #1 on: October 18, 2020, 10:27 AM »
The rip blade does make a huge difference even on 1-1/4" stock (but mine is a PCS 1.75HP). For all stock prep. sessions, I use only the rip (1/8" 30T)...like cutting butter when compared to the combo. The Forrest blades are expensive but great. I only use the SawStop titanium blade when they are put aside for cleaning.
« Last Edit: October 18, 2020, 11:33 AM by ChuckM »
Offline ear3
« Reply #2 on: October 18, 2020, 11:23 AM »
I actually just picked up a thin-kerf Forrest blade for help with thicker rips.  I also have a 20T 1/8" kerf rip blade, but the cut quality on it is not as good, so the thin kerf model is now there when I need to plow through 2"+ hardwood.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 26 w/BT module • CT Sys w/Long-Life Bag • MFT/3 • STM 1800
Offline GoingMyWay
« Reply #3 on: October 18, 2020, 11:30 AM »
Jonathan Katz-Moses posted a video today showing the different table saw blades cutting at 19,000 frames per second:
Inquiring Minds Want to Know
Offline CeeJay
« Reply #4 on: October 18, 2020, 02:29 PM »
That’s very cool. Really shows how much difference a good rip blade makes.
Offline Birdhunter
« Reply #5 on: October 18, 2020, 06:04 PM »
I made the rip blade cut a little proud and cleaned up on my planer. The rip blade cut was ok, but not as smooth as the combo blade.
Birdhunter
Offline CeeJay
« Reply #6 on: October 18, 2020, 06:15 PM »
I usually re-rip on the table saw, with the last cut less than the blade kerf, say 1mm.
If the rip blade is clean this usually gives a good enough finish. Does sometimes need a run on the jointer, maybe 1 in 3 or 4 times.
Offline ChuckM
« Reply #7 on: October 18, 2020, 06:57 PM »
Even the WWII combo blade 1/8" - 40T doesn't leave a furniture-grade edge. I handplane all show edges with a couple of light passes, following the grain direction.
