Author Topic: Shed I built  (Read 2719 times)
Offline Kevin Johnson
Shed I built
« on: May 30, 2008, 05:10 PM »
Here are some pictures of a cedar shed that I built.  On this shed, the customer wanted beaded cedar siding so I ran the cedar siding through my router table to form the bead on the edge.
I made the window, the cupola, flower box and the doors in addition to framing and everything else.  On the doors, I had wished I had a domino, but that wasn't in the budget.  So I clamped the stiles to the side of an MFT and routed mortises for loose tenons.  I of course, did the same thing for the rails.  I used the TS 55 to cut the cupola from MDO and applied cedar to it.
The door lock was a full mortise lock set and I used the OF 1400 to plunge route the mortise for that.
8576-0
8578-1
8580-2
8582-3
8584-4
8586-5
Offline Tom Bainbridge
  • Limey Carpenter
Re: Shed I built
« Reply #1 on: May 30, 2008, 05:23 PM »
kevin
working in minature makes the task that bit more exacting
this is the sort of project apprentice carpenters ought to be given, it teaches almost all the techniques needed to build a house
good work
Bromley, Kent. UK
aka dirtydeeds
Offline SRSemenza
Re: Shed I built
« Reply #2 on: May 30, 2008, 11:22 PM »
  Cool doors.  Is the shed about 4' x 8'?
Re: Shed I built
« Reply #3 on: May 31, 2008, 06:09 AM »
Thanks for the compliments. The shed is 6x10.
Offline poto
Re: Shed I built
« Reply #4 on: May 31, 2008, 08:07 AM »
Great job! You should consider making play houses for kids. And I liked the gratuitous inclusion of the Systainer in the shot!
