« Reply #3 on: March 11, 2023, 05:08 AM »
Thanks for the replies, I personally think there is a large difference in the finish from 220 to 1,200 . I use general finishes Arm-R-Seal. I’ve never tried set sanding of any kind.
Silly question but I assume I use the spray bottle and water and I assume I’d still use my Rotex and sandpaper the same as always then let dry before I add another coat or is there so little moisture it doesn’t matter?
I used to use Odies but imo it had a tendency to yellow the sap on Walnut and I like the contrast.
Sawstop Industrial Saw, TS75,2 800,2 1400 & 2700 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,OF1400 EQ-F-Plus, MFT/3, MFT-SP, FS-HZ 160, TSC 55, T18 E
