Author Topic: DIY Retractable castors for workbench  (Read 547 times)
Offline carrera4s
« on: June 12, 2020, 09:20 AM »
I am busy building a split top Roubo workbench and recently added some retractable castors that can lift the bench off the ground to move it around, and drop it down again to ensure it stand still when in use.
« Last Edit: June 13, 2020, 03:19 AM by carrera4s »
Online hdv
Re: Retractable castors for workbench
« Reply #1 on: June 12, 2020, 11:22 AM »
Wow! That sure looks much more sophisticated than my bare bones solution. I was lazy and just bought some of the shelf retractable castors (I think it was Axminster, but it might have been Amazon) and made a pedal out of two pieces of beech that I glued together. By comparison your version is almost a piece of art. Well done!
Offline Gregor
« Reply #2 on: June 12, 2020, 11:59 AM »
That is a very interesting idea.
Offline Sparktrician
« Reply #3 on: June 12, 2020, 12:30 PM »
OK, I'm confuzzed.   [huh]   How to you keep the casters in a locked-down configuration>
- Willy -
Offline ChuckM
« Reply #4 on: June 12, 2020, 12:38 PM »
The casters stay locked down when you push them down: https://www.leevalley.com/en-ca/shop/hardware/casters-and-wheels/110198-workbench-casters
« Last Edit: June 12, 2020, 12:41 PM by ChuckM »
Offline ChuckM
« Reply #5 on: June 12, 2020, 12:41 PM »
Snip.
(Attachment Link)
That's a clever design... and much simpler than other shop-made caster solutions I've seen. The use of dominoes is a bonus feature. ;D
« Last Edit: June 12, 2020, 12:43 PM by ChuckM »
Online hdv
« Reply #6 on: June 12, 2020, 02:54 PM »
What ChuckM said. You push the lever down and the construction of the system ensures the wheel stays locked. To unlock you just move the lever up again. I was too lazy to do this for each leg every time. That's why I made the bars. It also makes "finding" the right place for your foot much easier. I can keep my eyes on the important things now and let my feet do the pushing or pulling without having to look.
I didn't buy these castors at Lee Valley, but those look like they are exactly the same. They probably are from the same (Chinese?) factory with just another name on box.  [unsure]
Offline ChuckM
« Reply #7 on: June 12, 2020, 06:37 PM »
I got my casters on Amazon long before Lee Valley started carrying them. My design is similar to hdv's and others that have the casters linked together, except that I include a hole so I can engage the casters with a dowel.
« Last Edit: June 12, 2020, 07:18 PM by ChuckM »
Offline ear3
« Reply #8 on: June 12, 2020, 08:26 PM »
That's freaking brilliant.  Definitely will incorporate that design if I ever build a heavier mobile workbench.  Bravo.
