Author Topic: Reception Desk Assembly  (Read 909 times)
Offline Birdhunter
« on: January 29, 2020, 06:55 AM »
I will be assembling a large (8' by 7') complicated reception desk that I made for a Pilates studio.
I made the large pieces to be mated with Domino tenons and inset screws. One end of each tenon is already glue in place. The other end is not glued as of present.
I've done one dry fit and everything went into place.
I am wondering if I even need to glue the tenons as the screws will pull the pieces together.
All the pieces are already painted and I'm worried that the glue squeeze out will mess up the painted surfaces.
The studio owner know some touch up will probably need to be done.
P.S. The pieces will be transported to the studio in a flat pack. There is no need for the reception desk to be disassembled.
Birdhunter
Offline Bert Vanderveen
Re: Reception Desk Assembly
« Reply #1 on: January 29, 2020, 07:39 AM »
If you use PU glue (the kind that ‘foams’), it cleans up nicely without leaving a residue on the paint (but it never hurts to use some tape!).
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline Bob D.
« Reply #2 on: January 29, 2020, 08:52 AM »
This sounds like a large piece once fully assembled. It might be wise to allow for disassembly so it can be moved should the company move to a new location or they need to relocate within the same facility.
Offline jarbroen
« Reply #3 on: February 01, 2020, 12:16 PM »
Not a bad idea to plan for a possible move.  The Domino connectors work really well to draw the pieces together.  I just built two loft beds with that method.
