Author Topic: Recent Build - Credenza (aka Family Room Toy Chest)  (Read 985 times)
Offline SDWW2019
« on: March 15, 2020, 12:12 PM »
I noticed there has not been many recent posts of projects so I thought I would share my recent project.
I built this credenza for our family room. Basically it's a huge toy chest. Dimensions are approximately 60"x32"x18" (actually built to metric) and I used two sheets of 18mm (case sides, top, bottom, 2 shelves, base, and 3 drawer faces), half sheet of 12mm (3 drawers), and one sheet of 6mm (case back and drawer bottoms) baltic birch plywood. Joinery includes mostly dominos (4 and 5mm), glue, and a few strategically placed Kreg pocket screws. Drawers built out of 12mm baltic birch with 4mm dominos, glue, and 18g brad nails and ride on soft-close slides.
Build time was a very slow 2 months (while juggling work, kids, and other responsibilities) and I finished with 8 coats of water-based wipe-on poly and light 500g sanding between coats. Tools used in build include: TS55 Saw, OF1400 Router, Domino 500, MFT/3 Table, 1400 (holey)/3000 guide rails, CT Midid, parallel guides, ETS 125 Sander, hole drilling set, Grex 18g Greenbuddy, TSO GRS-16PE Rail Square, and Seneca Metric Domiplate.
Offline Don T
  • Phoenix, Az
Re: Recent Build - Credenza (aka Family Room Toy Chest)
« Reply #1 on: March 15, 2020, 12:18 PM »
Looks great. Clean lines.
Offline WarrenT
« Reply #2 on: March 15, 2020, 12:39 PM »
Your credenza looks great and the lines between the inset drawers and the case are very crisp.  Nice job.
What kind of drawer slides did you use ?
Offline gunnyr
    • Compass Custom Creations
« Reply #3 on: March 15, 2020, 12:45 PM »
I always enjoy the exposed Baltic Birch edges, well done!
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|ETSC 125|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|STL 450|DUO-SET|SYSLITE KAL II
Offline jobsworth
  • Festool Baby.....
« Reply #4 on: March 15, 2020, 03:23 PM »
real nice clean build look great
Offline Rick Herrick
« Reply #5 on: March 15, 2020, 04:57 PM »
Very cool.  Can I assume its in the Mid Century Modern theme ?  I am really liking this time period and there seems to be lots of different ways to get it.  You did a great job here.
Offline Bert Vanderveen
« Reply #6 on: March 16, 2020, 07:33 AM »
I think exposed plywood edges is more a seventies/eighties thing. Victor Papanek was very influential at the time (and still is worth reading up on) & furniture became more 'basic' — as in the sense of exposing construction and no frills materials.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline Chris Cianci
« Reply #7 on: March 16, 2020, 09:49 AM »
That’s a great piece, As a hobbyist I appreciate you mentioning how long it took you and the other commitments you had to juggle prior to completion. It helps me keep things in perspective as I learn along the way. Thanks for sharing!
Best
« Reply #8 on: March 16, 2020, 11:01 AM »
Thanks for the name/reference.  I will look him up.
