This particular store has a few different items that the others did not, but the same color laminate
This shelving unit is a bit odd. It has no back and the shelves are deeper than the sides, quite a bit actually.
The sides are 6.5" and the shelves are 10". They mount with some wire bars, rather than the typical clips. This requires a groove in the sides of the shelves. I have done lots of these in the past, but never with the shelves sticking out like this. They are normally cut with a 3 wing slot cutter on the router table, but that is with a raw edge, since it doesn't show. Since these are laminated, the slot cutter is out, those things chip-out something fierce.
The wire bars are 5mm diameter, same as the shelf pin holes, but that is a problem. I probably have half a dozen ways to drill a 5mm hole, but a 6" long slot is a different matter. I don't have a router bit like that. Apparently nothing between 1/8" and 1/4"? I thought I had a 3/16", but no?
So, I ended up with 1/8" and making 2 passes. This was the perfect reason to have 2 edge guides for the OF1010. The rods are barely long enough, but it does work. I set one to limit the cut from each side and it worked out great. I even used the 1/8" collet that I got for the S O to hold the bit.
I thought I took a pic with one shelf in place, but I guess not. I'll get some of the whole job, once it is open. This one is pretty close.
