@neilc I've eyeballed this thread more than once, excellent setup you built!
I've been noodling on building something similar which brought me back for another look. I was wondering what you did behind the systainers and noticed you said storage from the side or back for long items. Do you have any photos of that?
I currently have a Kapex cart now with 21" drawer slides. It's fine if I build drawers to use the full space, but a waste if I want a systainer accessible at the front. Now that I say that, I suppose I could design an accessories bin at the back of the Systainer pullouts.
However, it would be cool to see the ideas you came up with to utilize the back part of the carts.
If I build a setup like that the ends would be blocked by other tools when it's against the wall. I wouldn't want to pull out the carts to get to stuff I'd need frequently.
I also like the flat tops - I'm thinking of using one side to incorporate a SYS-Vac setup to hold the pump and quick way to mount the heads for clamping. The no fence option means more usable work surface in that scenario.
I've also contemplated cart(s) under MFT's, but I like your idea of organized wall space better - plus the additional workspace to pull out when needed.
Thanks!
