Author Topic: Modern walnut planter box  (Read 1732 times)
Offline blaszcsj
« on: March 31, 2019, 11:37 PM »
The wifey wanted a planter box and I happen to have some 8/4 lying around. Inspiration from Maloof and Jory Brigham stuff
Top box all glued up
On to the legs
Template routed and shaped legs
The glue up
Final fit up
End result with surfing outdoor
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro
Offline Gerald_D
Re: Modern walnut planter box
« Reply #1 on: April 01, 2019, 12:21 AM »
That turned out very nice- I'm sure she'll love it!
Great job on both the design and the build.
Regards,
Gerald
Gerald
I have Festools- Big and Small and a few other tools
Offline RKA
« Reply #2 on: April 01, 2019, 07:37 AM »
I love the design!  It came out beautiful!
-Raj
« Reply #3 on: April 01, 2019, 10:10 AM »
Nice job...nice design.  [big grin]  I especially like the bottom relief on each leg.
Offline jobsworth
  • Festool Baby.....
« Reply #4 on: April 01, 2019, 09:00 PM »
Very nice work great design, Sam would be happy [big grin]
Offline Jiggy Joiner
« Reply #5 on: April 02, 2019, 07:51 AM »
Great job, it looks superb!
Offline jarbroen
« Reply #6 on: April 02, 2019, 03:52 PM »
Looks awesome! I better not show that to my wife... lol
Did you use mortise and tennon for the joints?
I'm guessing hand carving/shaping on the legs?
That's something I need to learn.  So far, all my frames are square.  Unless it's something I can throw on the lathe.
Offline Jim Kirkpatrick
    • Jim Kirkpatrick Woodworking
« Reply #7 on: April 02, 2019, 06:05 PM »
Very nice job,  I like it a lot!!!
Offline blaszcsj
« Reply #8 on: April 03, 2019, 11:56 AM »
@jarbroen I used 8-10mm dominos for all joints. The center column three way joint is only dominoed to the large center leg so it can be assembled.
Legs were roughed and final machined with templates and the used a 3/4 round over to shape. Basically I made one leg template, copied it, then cut the second one where all my joints were. After joining/glue up, I used the original template to route out the final shape. I don’t have a pic of the original template but here are some of the rough layout I did. Hopefully you can see how the pieces go together.
Offline jpmeunier
« Reply #9 on: April 03, 2019, 12:00 PM »
I like it.....my daughters would turn that thing over 25 times a day.
Offline travisj
« Reply #10 on: April 05, 2019, 02:00 AM »
Nicely done.  It’s too beautiful to put dirt and water in...
Offline jarbroen
« Reply #11 on: April 05, 2019, 11:21 AM »
Thanks for showing more of your process!
I have plenty of 12mm BB scrap laying around, looks like that's a good template material.  Just have to be good enough to get at least one freehand looking good. :)
Offline duburban
« Reply #12 on: April 05, 2019, 12:53 PM »
or find a little spindle/edge sander
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
Offline blaszcsj
« Reply #13 on: April 07, 2019, 03:00 PM »
@jarbroen  yes that would work better than the 5mm stuff I used. I basically drew the planter box full scale on the plywood then cut it up and hand shaped it to make the master templates, then transferred it to make a second so I could cut it up for the layout pieces.
