Author Topic: New CNC spoilboard  (Read 3979 times)
Offline Mario Turcot
New CNC spoilboard
« on: March 18, 2019, 08:37 AM »
My CNC spoilboard was over due so I decided to give it a fresh look. The original had a very basic clamping capability. Butt the board against the two pieces and screw the four corners.
The MDF available here is of poop quality but it's just a spoilboard right! Here some material that will be used. Out of a 4'x8' sheet I got enough material to make 3 spoilboards.
I changed my mind about the brass inserts. They look nice for sure but are prone to strip easily so I went with a more sturdy ones that can be installed with allen key instead.
I did a dry fit just for fun  [big grin]
Installing the first strip, easy peazy.
You know the satisfaction when you use a template to bore holes and everything fit perfectly for the first time ever in your life  [eek]
The t-track (6) are 36" long.
And the final result.
Coming soon: I will make some 20mm holes for clamping purpose
« Last Edit: March 18, 2019, 04:58 PM by Mario Turcot »
Mario
Offline GarryMartin
Re: New CNC spoilboard
« Reply #1 on: March 18, 2019, 10:31 AM »
Will you not miss the Z height by laying the new spoilboard on top of the old?
« Reply #2 on: March 18, 2019, 10:47 AM »
Effectively, it went from 3" to 2" 1/4 of travel. I went that path because all the boards I have carved with the CNC since the last 2 years, were under 25mm thick. Most of the time I use 1/32" to 1/4" bits and those are under 1/2" to 1" of cutting edge. Cutting deeper with the machine I have is kinda tricky. Feasible but I don't see any scenario I would.
If ever I get into CNC more seriously, I will get a full size machine like the Axiom Precision or similar.
For me that CNC machine was an experiment. To see if I could DIY a kit and how useful a CNC can be in my situation. The DYI build took 2.5hrs plus some wire management. Lately I add a zeroing plate to it and job setup is a breeze compare to previously. Oh and a wireless motion controller is a must [big grin]
« Last Edit: March 18, 2019, 10:54 AM by Mario Turcot »
Mario
Online Cheese
« Reply #3 on: March 18, 2019, 11:14 AM »
I like it Mario...nice job.  It reminds me of a Shelix cutter head, you only replace the damaged item. [big grin]
« Reply #4 on: March 25, 2019, 08:39 AM »
Thank you Cheese.
Here a picture of the spoilboard finished. 8x6 dog holes grid. I have two 3mm holes bored on the back of each strip. Haven make the 20mm hole because I don't see using that part yet. Fun fack, I bored all 3mm & 20mm holes with the CXS on one single batteries not even full charged. Boring was really easy.
Blue shapes: They are from Yellowshedbox. L angle to butt your material and cam clamps. They are a very very nice fit into the UJK Parf guide system holes.
Yellow shapes: Again from Yellowshedbox. Easy to pull-out dogs with extreme nice fit.
Bench-Dog Fence: I put it there kust so I can test their dogs. Very nice fit there too.
UJK Parf Bit Tear-out under MDF boring like no tomorrow. I was testing on MDF and bored a hole without worrying (full blown) about tear out. The small adjacent hole is from a Brad Point bit.
L.V. dogs
Three different dogs from L.V. none have a good fit. The stainless steel Super Parf Dog is a ok fit but still have some movement. I will have to get me some TSO Dogs  [big grin]
« Last Edit: March 25, 2019, 09:12 AM by Mario Turcot »
Mario
