Author Topic: My modified Kreg Workench/MFT  (Read 11003 times)
Offline Route24Design
    • My Personal Blog
« on: March 22, 2018, 04:12 PM »
Added a flip down extension wing for off cut support.
Festool TS 55 REQ-F-PLUS
Festool OF 1400 EQ-F-PLUS
Festool CT MIDI HEPA
Festool CT Sys HEPA
Festool Domino DF 500 Q-PLUS
Festool PRO 5 LTD (ETS 125 REQ)
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Festool FS 1400/2 (x2)
Festool FS 1400/2-LR 32 Guide Rail
Festool LR32 Router Hole Drilling Set
Online Peter Halle
Re: My modified Kreg Workench/MFT
« Reply #1 on: March 22, 2018, 06:12 PM »
Resized images:
« Last Edit: March 22, 2018, 06:34 PM by Peter Halle »
Offline Corwin
« Reply #2 on: March 22, 2018, 07:28 PM »
What? You just screwed your Festool MFT Guide Rail Support Brackets directly to the apron on your bench? What genius!   [jawdrop] [doh] [thumbs up]
Offline Peter_C
« Reply #3 on: March 22, 2018, 11:27 PM »
I like it! :)
    • My Personal Blog
« Reply #4 on: March 24, 2018, 10:33 PM »
Added a replaceable insert for kerf line
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline OXCanada
« Reply #5 on: March 25, 2018, 11:50 PM »
Very nice, looks great!  Did you use a double thick layer for your top?
    • My Personal Blog
« Reply #6 on: March 26, 2018, 08:12 AM »
Thanks.  No, used 3/4” MDF.
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline SilviaS7
« Reply #7 on: March 27, 2018, 05:15 PM »
This is really cool, I love it.  Great work!
Offline icecactus
« Reply #8 on: December 11, 2018, 05:58 PM »
Awesome bench!
Any more pics of how you did the festool track support brackets in the rear?
TS 55 REQ, MFT/3, CT 48 w/Boom Arm, OF1400, LR32, 55" Holey Rail, 118" Rail, Domino 500, RO150, ETS150/3, RO90, DTS400
    • My Personal Blog
« Reply #9 on: December 11, 2018, 06:09 PM »
Awesome bench!
Don’t have any pics but I did the same as the front bracket setup.  I screwed the bracket to the wood.
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline kevins007
« Reply #10 on: December 11, 2018, 10:23 PM »
Nice work. Can you please tell me where to got the folding arm from?
    • My Personal Blog
« Reply #11 on: December 11, 2018, 10:27 PM »
I got the folding bracket from my local Home Depot.  I believe the brand is Knape & Vogt
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline reelbusy
« Reply #12 on: May 12, 2019, 11:43 PM »
Hi , nice project (and my first post), i used this for inspiration with an old rockler stand i had sitting around. Pretty rough state atm but underneath i put a rail in center and on the backside you can't see sit's a surface planer on a shelf so there is longer infeed outfeed, and the front 1/2 is left open for systainers to roll under (quick and dirty caster base for now), eventually i'd like that to be a unit that rolls out with drawer slides to double as sys storage as well as extra work surface.
I've been sitting here thinking how i was going to mount the hinge and remembered your post.
This may be a dumb question but  how is the hinge bracket mounted just screwed in since it has a tab on back? did you cut it off
or dado your apron or something? maybe i'm missing it.
I was thinking what i'll do is those small holes on the apron are tnuts, so i may just dado a scrap 3/4 piece so the hinge fits flush
and screw it to that, then tnut the 3/4  in so it's removable. I've seen fancier rail setups but this is a budget build aka cheap track saws,etc...i mainly use tablesaws but had to downgrade that too to a contractor saw to save garage space.
297795-0
Thanks!
    • My Personal Blog
« Reply #13 on: May 13, 2019, 08:43 AM »
(Attachment Link)
Thanks!
For the brackets, I removed the metal hook and cut off the plastic tabs.  Then just screwed the black plastic directly onto the wood.
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline reelbusy
« Reply #14 on: May 13, 2019, 09:42 AM »
AHA the infamous K.I.S.S method strikes again. lol here i was thinking complicated. Thanks for the reply and ideas!
Offline reelbusy
« Reply #15 on: May 13, 2019, 04:29 PM »
I ended up going 1/2 way simple. Removed the steel part and there were some premade holes to counter sink and put a flat topped screw to the 3/4. Was going to mount the 3/4 with the tnut holes (an idea i got somewhere about attaching bins, saw holders,glue bottle holders,etc) but in the end seemed more secure to line everything up clamp and just screw the 3/4 in to the apron so did that.
