Author Topic: My coronavirus at home project  (Read 4227 times)
Offline StanB
Re: My coronavirus at home project
« Reply #30 on: April 23, 2020, 01:48 PM »
@Cheese Do you happen to make/document templates for this dust collection sheet metal?
Yes @blaszcsj however my printer will only print 8 1/2" x 11" paper so for the 2 end pieces, I had to cut & paste 2 sheets of paper into one.  [smile]  The files are .cad
@Cheese Would you mind sharing them? I would love to build a similar dust collection unit for my delta.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM SET | MX 1200 E MIXER | DF700 XL | PDC 18 | TID 18
« Reply #31 on: April 24, 2020, 08:51 AM »
@Cheese nice work. But what's with all those rivets? Shouldn't you have welded that together? [wink]
Hey Ron @rvieceli I sure wish I could have as it would have trimmed a good 6 hours off of the project. I have gas & stick only... [sad]  no MIG and certainly no TIG.  [crying]
There was certainly an over abundance of assemble-mark-disassemble-punch-reassemble-mark...events, the TIG would have been perfect, just align and tack. [smile]
« Last Edit: April 24, 2020, 10:21 AM by Cheese »
Offline BarneyD
« Reply #32 on: April 24, 2020, 11:54 AM »
If you guys promise not to laugh, I share my dust collection solution. @Cheese yours is much more elegant. And thanks for the info on the Iturra knobs. I'll definitely be grabbing some of those. One other upgrade I recently made was getting a new tensioning crank from Highland Woodworking. It's their Part 185193. It has acme threads and is just a dream to use.
Cheers,
Barney
Barney
« Reply #33 on: April 24, 2020, 02:16 PM »
@BarneyD   yours looks a lot better than mine though the form of mine is more like Cheese’s, except mine is made of foam core and hot glue. [tongue] Amazingly it’s been held up for at least 20 years. Cheese’s will last at least a century.
Offline Picktool
« Reply #34 on: April 25, 2020, 08:27 AM »
Ron
For those that cant weld can join with the Lord
Aint cheap but good in the tool arsenal.
Well Dogey
« Reply #35 on: April 25, 2020, 09:30 AM »
That's good information... [smile] it appears to be very similar to the 3M™ Scotch-Weld™ DP190 that I used to assemble a stainless hand rail/railing for the loft master.
Offline Picktool
« Reply #36 on: April 25, 2020, 11:02 AM »
Quote
Same from you too. Never looked into 3M for that even tho they make everything.
Well Dogey
Offline Sbradley0911
« Reply #37 on: April 29, 2020, 08:03 PM »
Had a little time this weekend so I made some pulls and got some stuff organized and put away.... sure fills up fast lol
My coronavirus at home project: Delta Bandsaw Dust Collector
« Reply #38 on: June 25, 2020, 10:21 AM »
So a couple of months ago I decided to fab a dust collector for my Delta bandsaw. Recently the bandsaw has been used for just smaller projects, cutting aluminum and plastic. Yesterday I needed to rip some 4 1/2" wide mahogany and I was curious to see the results.
This was a piece of mahogany 4 1/2" wide, 4 foot long and I wanted it to be 1 1/16" thick. I prepared the saw and made one continuous rip, opened up the two pieces and this was the result. I was stunned...anyone that's done much ripping of medium wide boards has experienced tons of sawdust on the table and once the boards are pulled apart the kerf is filled to overflowing with sawdust.
I'd estimate that's less than a tablespoon of sawdust on the table and there's less than a teaspoon full on the two boards on the LH side.
I then noticed a light dusting on the outside of the dust collector and was curious how much was left inside the bandsaw door and on the lower wheel where it always collects. Again I was shocked, absolutely clean. The dust that's on the lower wheel is not mahogany, it's caked on the wheel from previous sawing escapades before i fabricated the dust collector attachment.
Offline RKA
« Reply #39 on: June 25, 2020, 10:41 AM »
That's pretty incredible!  Well done!
-Raj
Offline Christopher Fitch
« Reply #40 on: June 25, 2020, 11:05 AM »
That's pretty nice!
