« on: February 07, 2022, 10:56 AM »
A customer asked me if I could build 4 lounge chairs made from composite decking material. I had never built one before but of course I said yes and then started my search for an acceptable unit. This is the chair, I hadn't cleaned it up yet when photographed. This material is HEAVY! It probably weighs at least 150#s. I got a Domino to put the frame and the adjustable back together. The material is from Armadillo Decking and is solid core with a plastic wrap. I discovered Titebond III won't stick to the wrap but it will bind the cut ends, especially when used with the Dominos. As with any new project, I learned what to do and not to do with the first one so the next 3 should go much smoother and not have any waste.
For the exposed ends, I found that using oil-based gel stain works great to match the walnut wrap.
Howard H
Mark Twain: "I didn't attend the funeral, but I sent a letter approving of it." "If you tell the truth you don't have to remember anything."
mft1080, P1cc, MFT/3, T15, TID-18, RO150FEQ, ETS EC 150, MT55cc, RTS400, CT22, CT36E, 800, 1080, 1400, 1900 rails, OF 2200, OF1400, CSX, C18, VacSys, Vecturo, Domino, Qwas dogs, Parf Dogs, Zobo's, Syslite Uni, CMS GE, Sawstop contractor, PM 1500, Shaper Origin. Felder AF-14
