Author Topic: Lounge chairs  (Read 1584 times)
Offline HowardH
Lounge chairs
« on: February 07, 2022, 10:56 AM »
A customer asked me if I could build 4 lounge chairs made from composite decking material.  I had never built one before but of course I said yes and then started my search for an acceptable unit. This is the chair, I hadn't cleaned it up yet when photographed. This material is HEAVY!  It probably weighs at least 150#s. I got a Domino to put the frame and the adjustable back together. The material is from Armadillo Decking and is solid core with a plastic wrap. I discovered Titebond III won't stick to the wrap but it will bind the cut ends, especially when used with the Dominos. As with any new project, I learned what to do and not to do with the first one so the next 3 should go much smoother and not have any waste.  :o ::)  For the exposed ends, I found that using oil-based gel stain works great to match the walnut wrap.
Howard H
mft1080, P1cc, MFT/3, T15, TID-18, RO150FEQ, ETS EC 150, MT55cc, RTS400, CT22, CT36E, 800, 1080, 1400, 1900 rails, OF 2200, OF1400, CSX, C18, VacSys, Vecturo, Domino, Qwas dogs, Parf Dogs, Zobo's, Syslite Uni, CMS GE, Sawstop contractor, PM 1500, Shaper Origin. Felder AF-14
Offline afish
Re: Lounge chairs
« Reply #1 on: February 07, 2022, 11:19 AM »
very nice. How many feet of decking per chair?
Offline HowardH
Re: Lounge chairs
« Reply #2 on: February 07, 2022, 11:33 AM »
about 90, give or take a few screw ups...  I bought all they had, 24 pieces at 12' but it's not going to be enough.  Looks like I need to buy 4-6 more.
Howard H
Offline Crazyraceguy
Re: Lounge chairs
« Reply #3 on: February 07, 2022, 06:38 PM »
Looks cool, got any pics of the tilting mechanism?
I built some planter boxes at work for the side patio, last spring. They came out nice, but like you said, there's a bit of a learning curve with composite.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline Bob D.
    • My Cordless Workshop
Re: Lounge chairs
« Reply #4 on: February 07, 2022, 09:37 PM »
Found some technical info on their site.
https://armadillodeck.com/technical-safety-information/
It's made from HDPE and wood mostly according to the SDS sheet.
They recommend sealing with Armadillo End Board Sealer.
I was curious what the Coefficient of expansion is for the decking,
but didn't find it listed in the tech specs.
Offline HowardH
Re: Lounge chairs
« Reply #5 on: February 13, 2022, 04:09 PM »
I finished up construction on another one.  Not cleaned up yet but this will show you the mechanism.  I got the plans from a guy who was willing to share them.
Howard H
Offline jobsworth
  • Festool Baby.....
Re: Lounge chairs
« Reply #6 on: February 13, 2022, 05:36 PM »
nice work Howard
Offline HowardH
Re: Lounge chairs
« Reply #7 on: February 13, 2022, 05:40 PM »
Thanks, the Domino came in really handy.  The plans called for pocket screws on the back side of the adjustable back and can you imagine how ugly that would have been? I used double dominos on the miters and poly glue so it should be plenty strong.
Howard H
