Author Topic: Library bookcase  (Read 1279 times)
Online Crazyraceguy
Library bookcase
« on: November 17, 2022, 06:33 PM »
This is just the initial dry-fit. I've been working on the parts, for last couple of days. The shelves are two layers of 3/4" ply with a 1/4" solid front edge. They are set back from the vertical members about an inch. The verticals have a ladder-frame spacer, as do the thicker shelf parts up near the top. The thicker ones are there to support a rolling ladder, which only attaches to the smaller unit.
It is a corner unit, thus the pic showing the corner-filler arrangement.
There will be more pics after the stain-finish is done and the parts come back to me. It will ship fully assembled, in 2 pieces, split at that corner. It joins there with Dominos and Lamello Zeta Clamex connectors.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Offline smorgasbord
Re: Library bookcase
« Reply #1 on: November 17, 2022, 11:45 PM »
Looks good - just curious, how did you attach the ¼" solid front edge to the plywood? Glue? Brads and Glue? ¼" is too shallow for biscuits or dominos....
Offline ironchefboyardee
« Reply #2 on: November 18, 2022, 10:41 AM »
This looks great. Do you usually get photos of the final install? It looks like white oak and I'd love to see what the final result looks like.
Are the shelves joined to the case by tenons, or is there some hardware they slide onto, that allow removal for any reason?
Online Crazyraceguy
« Reply #3 on: November 18, 2022, 07:26 PM »
The 1/4" front edges were simply glued in place. They were slightly over width (1 5/8") so they didn't have to be perfect, trimmed flush with the MFK700. I usually do this by combining two shelves in the same clamps, with the glued edges facing each other. It cuts down on the amount of clamps required.
It is indeed white oak, rift sawn to be exact. The shelves are doweled into the sides. These parts are all cut out on a 5' x 12' CNC machine, which does all of the dowel drilling. Then the horizontal parts are doweled by another boring/inserting machine. This is all done by the "production" side of the shop. Then   it comes to me for the assembly, building up the thickness of the shelves, sides, etc. along with the edges. The edges of the other parts are 3/4" thick and are joined with Dominos.
Not shown in these pics, but they all have backs too.
As far as installed pics, it's hard to tell. Sometimes I can get them, others not. Since this will ship in a mostly assembled state, I will get better pics before it leaves at a minimum.
It's all back apart today and I would have taken a pic of the stack of parts, but I forgot my phone at home this morning. The parts are going to the finish department tomorrow, probably not back to me until after the holiday.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Offline smorgasbord
« Reply #4 on: November 21, 2022, 12:49 PM »
Thanks.
I'm trimming some thick plywood edging (¾") and am using something like this:
« Reply #5 on: November 21, 2022, 01:28 PM »
Thanks.
I used a similar configuration recently for the same purpose but the router was the MFK 700 in the vertical base and the bit was a Whiteside 1” diameter spoil board surfacing bit. (Didn’t have the right kind of bit handy for the horizontal base) Had to add a 1/8” shim to the base to clear the glue squeeze out and surplus edging but it was really satisfying to just easy peasy slide the router along and mow the surplus down, mostly dust free. The easy height adjustment to the sub .1mm on the MFK is wonderful.
Online ChuckS
« Reply #6 on: November 21, 2022, 02:05 PM »
For edge trimming, the Fastcap little lipper does it well: https://m.youtube.com/watch?v=eYz1idJxssw&feature=youtu.be
Online Crazyraceguy
« Reply #7 on: November 21, 2022, 05:30 PM »
I have seen that method, but much prefer to do this cut horizontally. I even go as far as to do it with a climb cut. You get a fantastic finish that way.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
