I've been looking for better storage options for my guide rails, and I know the Track Rack is quite popular, but I was looking for something that would (mostly) support the guide rail along its length, rather than just at the ends. I also wanted to design something that would use my existing garage door bracket installation points, not requiring drilling into the door itself.
I had some spare baltic birch plywood sitting around, so decided to use that for the backing material, along with a lip that runs along the bottom to support the guide rail on its thick side, with the splinterguard facing up. There is also a shallow lip along the top for the turn latches to mount. These hangers were longer than 8 feet, so I had to add a joint. I picked it dead square in the middle, probably not the best given there's also hardware mounted there, but I offset the joint locations of the lips and it's strong enough, especially with the center-mounted support bracket.
My favorite part about this project is the black plastic turn latches, McMaster part number 1579N12. For some reason it's really satisfying to turn these knobs up and easily access the guide rail I need. Behind these turn latches, I used steel tee nut inserts (McMaster 90975A301) and button head hex drive screws to connect them (McMaster 91255A245). I used threadlocker to keep the screw from moving when I turn the latches, and dialed in the tightness so they don't swing freely.
I used SendCutSend to laser cut some custom mounting brackets to attach the guide rail hangers to the doors.
This design is custom to my doors. I made it as wide as I could. I was elated to just BARELY be able to fit the Festool 106" guide rail. Back bracing was cut on the CNC, obviously! Happy to share 3D files or DXFs if anyone has an interest in building something similar.
