Author Topic: Inset Drawers - How big of a gap?  (Read 11100 times)
Offline 72anthony
« on: August 10, 2013, 05:16 PM »
I am constructing a built-in with inset drawers that will be on the same plane as the face frame and looking for some guidance on the size of the gap between adjacent drawers and the face frame.
The drawer boxes are about 27 inches wide and the drawer fronts vary in height from 5 to 11 inches. Drawer front material is 3/4-inch red oak, S2S, and is already acclimated to my shop. The wider drawer fronts will be glued up panels.
Thanks,
Anthony
MFT/3 - TS-55 w/ holy rail - 118" Rail - Rail asscy kit - CT-26 - Ultimate D.D. - Workshop Cleaning Set - ETS-125 - RO-125
Offline neilc
Re: Inset Drawers - How big of a gap?
« Reply #1 on: August 10, 2013, 05:55 PM »
I do around 1/16 usually, maybe a little wider to 5/64.    I think smaller is better if you can do it depending on your drawer glides.
neil
Offline Jon Hilgenberg
« Reply #2 on: August 10, 2013, 06:16 PM »
1/8" reveals all around when I do them.  Inset can be very unforgiving, and 1/16 is just a tad too close for comfort IMHO.
Jon
The more Festools I buy, the more money I earn.  The more money I earn, the more Festools I buy.  The more...
TS 55, TS 75, Domino, CT22, OF 2000, C12, CXS, RAS, Trion, Fogtainers!
Offline builderbob
    • RJP Remodeling
« Reply #3 on: August 10, 2013, 07:18 PM »
Jon
+1 all day long with Mr Jons response!
Kapex, TS55, CMS GE, Carvex 420, Domino DF500, MFK 700, OF 2200, OF 1400, OF 1010, EHL65, RAS 115, RTS 400, RO150, ETS 150/3, ETS 125, CT 22 (2), CXS (2), C-15+3, T-12+3, PSB 300 & more MFT's than i can count!
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
« Reply #4 on: August 10, 2013, 07:28 PM »
I agree that 1/8" (or maybe 3/32") would be a better choice.  With you solid wood drawer fronts you could easily lose a 1/16" gap with wood movement caused by seasonal changes in humidity.
« Reply #5 on: August 10, 2013, 08:14 PM »
Absolutely 1/8"....unless you like spending free time adjusting reveals.
Offline mastercabman
  • NORFOLK,VA
« Reply #6 on: August 10, 2013, 09:58 PM »
3/32"-1/8" is typical
Also a lot of cabinet manufacturer puts a 10* bevel on all 4 edges
Offline amt
« Reply #7 on: August 10, 2013, 11:21 PM »
Is the bevel on the face frame or the door/drawer fronts?
« Reply #8 on: August 11, 2013, 03:31 AM »
I can't say I know of any manufacturers that incorporate a back bevel to there doors and drawer fronts. But anyway, a bevel would only make sense on strike & hinge sides of door (stiles).Top & bottom (rails)of doors , and drawer fronts ,would be pointless to bevel. Just to clarify , only application that might require bevel to stiles would be full inset door with barrel hinges.
« Reply #9 on: August 11, 2013, 08:37 AM »
I've seen back beveled door/drawers before, maybe 5 degrees or so.
Offline farms100
    • please visit our woodworking guild
« Reply #10 on: August 11, 2013, 09:18 AM »
on furniture I usually go with the thickness of one of those prepaid store cards on the sides and a bit more than that on the top.  during the dry winter I'll make it a bit looser on top.
I usually assume 1/8 inch per foot for seasonal wood movement.
eastern mass guild of woodworkers. http://www.emgw.org
« Reply #11 on: August 11, 2013, 10:43 AM »
Thanks,
Anthony
I assume you mean taller rather than wider drawer fronts.
1/16" on each side looks good so I'd make the drawer front 1/8" less wide than the opening and the length of the fronts won't change significantly through the seasons.
Certainly you should consider seasonal movement but that is just one of the factors needed to determine how tightly to fit the drawer fronts to the opening at the time of construction.
How dry is the stock?
Sounds like it's already dry and stable so no allowance needed
What is the grain orientation?
If the fronts are plain sawn you can expect the board to change significantly with the seasons. The closer it is to quarter sawn the less it will change. Depending on how wide the face frames are (and grain) they factor in to the size of the gap too.
What is the current season?
It's already August, how much more can you expect the wood to swell? If you cut it loose now it will be even looser in the winter but again, it depends a lot on the orientation of the growth rings.
Where will the piece reside?
If I built a piece now in the warm humid NE and sent it to Arizona I'd fit the drawers close to the face frame.
A small back bevel is a good idea too.
So, for the 5" fronts I'd deduct 1/8" from height and width of the opening regardless of grain orientation.
On the 11" fronts I'd do the same if the stock is quarter sawn. If the stock is plain sawn it depends on if it is expected to expand more or not. In my region it's more likely to shrink than expand from this point.
  • NORFOLK,VA
« Reply #12 on: August 11, 2013, 02:39 PM »
5-10 degrees +/-
For the drawers,i think it's because if the drawer face is not really centered,the back of the drawer face should not hit the face frame,so no damage done.
« Reply #13 on: August 11, 2013, 03:52 PM »
5-10 degrees +/-
quote]that actually may be a good idea..so the bevel would ride up f.f. rather then crash into it
« Last Edit: August 11, 2013, 03:58 PM by Guilliaume woodworks »
Offline Joe Duarte
    • www.creativemillwork.ca
« Reply #14 on: August 11, 2013, 05:18 PM »
I use 2mm gaps (5/64) in all my doors and drawer fronts.
Joe
  • NORFOLK,VA
« Reply #15 on: August 11, 2013, 07:17 PM »
5-10 degrees +/-
You got it!
I rather go back and do adjustment than fixing the face frame
