Author Topic: How do you define “Reface a kitchen”?  (Read 1083 times)
Offline Packard
« on: March 09, 2023, 09:37 AM »
Note:  I see that my post has gotten long-winded.  Scroll down to the bold-faced question below.  That sums it up nicely.
I am in the process of refacing my kitchen.  I am building all new cabinet doors and drawer fronts.  Also new end panels.  I am painting the face frames and toe kicks only (no interior painting).
I’m about half way done.  Doing a few cabinets each week.  My 74 year old back complains about working on my hands and knees for the base cabinets and also for working off a ladder for the uppers.  So that is the limiting factor.
However, the other day I was reading an “Apartment Therapy” e-magazine and they defined refacing as “new cabinet doors and drawers”.
 Question:  Is it conventional to replace the drawers as well as the drawer fronts when refacing a kitchen?  I was not planning on that.
Also, I am switching from 1/2” overlay to 1” overlay for a more contemporary look.  Because of that, I am replacing all the standard close hinges with soft close hinges.
I was not planning on soft close drawers, however.
All this in anticipation of selling my house in about 5 years.
I have read that refacing kitchens has a high R.O.I. (Return On Investment).  Are soft close drawers also a high R.O.I.?  My back would not be happy doing that work.  (Making new drawers would be easy, however.)
Offline afish
Re: How do you define “Reface a kitchen”?
« Reply #1 on: March 09, 2023, 10:58 AM »
depends on your market but in mine yes buyers like good hardware but in the end all all comes down to price.
Offline squall_line
« Reply #2 on: March 09, 2023, 11:16 AM »
Personally, I don't mind closing a soft-close drawer, but it annoys the heck out of me to open them.  Maybe not all soft close drawers "stick" closed, but the ones I have experience with do.  The overall smoothness of opening and closing the drawer is more important to me, but because I also like old houses, I don't really like some of the more modern trends in kitchens.
Offline afish
« Reply #3 on: March 09, 2023, 11:33 AM »
yep, thats why I said it can vary by market. Rural Wyoming im sure is much different than SE Florida. Here in S FL everything is modern. Here buyers want 2 things 1. The best of everything 2. They want it for free
Offline 4nthony
    • Slack for Recon Tools
« Reply #4 on: March 09, 2023, 12:15 PM »
This is how I defined refacing a kitchen. It was a bit more than a reface because in addition to a visual update, I needed improved storage and functionality. In order to get the look I wanted, I had to replace the drawers.
So, my answer to...
Quote
...would be, "it depends". If the goal of your reface can't be achieved with the currently installed drawers, then yes. If you're happy with your drawers, and can leave them, then no.
I like soft-close drawers. The little bit of tension (stick) when opening them doesn't bother me when the drawer sits on Blum under mount slides.
Though, in a couple of my drawers, I did a "drawer inside a drawer" with side-mount soft close slides. The stick when opening these interior drawers is much greater and I'm tempted to swap them out with slides that are not soft close. My only concern is they might shift around when the main drawer is opened.
Recon Tool Notifications
Anthony
Offline Packard
« Reply #5 on: March 09, 2023, 02:39 PM »
I am adding small cabinets to go above the wall cabinets and bring them to the ceiling.  And new countertops.
I am not ripping out the old boxes.  The end panels I am making and spraying in the shop and the face frames I am brush painting in situ.  By changing from 1/2” overlay to 1” overlay, not much of the face frame remains exposed.  (A good thing, since the original was “golden oak”, and even with the grain filler, a little of the grain still telegraphs through.)
Offline Crazyraceguy
« Reply #6 on: March 09, 2023, 06:05 PM »
To me it generally means that the layout is unchanged and the doors, drawer fronts, and often the counter top get replaced. Almost always this also includes hardware like hinges and pulls.
Actually replacing the drawer boxes would be a bit more intense. It could happen, but really only if they no-longer work because of a drawer slide change, or replaced for wear/damage.
Here in the US, most kitchens have faceframes, especially likely for one old enough to need a refresh. That is an added complication and depends entirely on the intended goal. Refinishing or painting (re-painting) in place is common, but I have also seen veneer added.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
Offline Peter Halle
  • Ain't so Small no More
« Reply #7 on: March 09, 2023, 06:56 PM »
This is what I have done for reface jobs.
Offline tjbnwi
« Reply #8 on: March 09, 2023, 09:05 PM »
I read the quote “new doors and drawers” to mean the drawer faces, not the drawer boxes.
I believe the line should read- “new doors and drawer faces”.
Offline RussellS
« Reply #9 on: March 11, 2023, 05:57 PM »
My answer is do the drawer boxes need replaced.  If the drawer boxes are OK, not super duper fancy and perfect, but OK, average, fine, good enough.  Then no need to replace the drawer boxes.  But if you do a fine job on the doors and drawer fronts, and the prospective buyer opens the kitchen drawers and sees drawer boxes that obviously look much less good.  Then you need to replace the drawer boxes too.  If you go out to eat at the finest steak joint in your town and get served a finely grilled tasty steak, and on the plate is some instant mashed potatoes and the paper pouch mix up instant brown gravy.  You might think things aren't matching up.  Another analogy.  You make a handcut dovetail box.  Beautiful half or through dovetails.  And decide 40 grit is all the sanding you are going to do.  Why only do half the job good?
As for the soft close doors and drawers, I think its a question of symmetry.  If the doors are soft close, and the drawers are not, wouldn't someone say "why are the doors soft close but the drawers are not"?  If one is soft close, you automatically expect the other to be soft close too.  Or if one is regular hinges, then you expect the other to close the same way.  Its sort of a doing half the job instead of doing the whole job question.  Symmetry comes in here too.
« Reply #10 on: March 11, 2023, 06:17 PM »
There is also the possibility that the drawer fronts are integral to the boxes, rather than the more typical false front to a complete box. In that case, replacement is likely to easiest solution.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
Offline 4nthony
« Reply #11 on: March 11, 2023, 07:27 PM »
I think that's a really good look and a great way to show off joinery, too.
Anthony
« Reply #12 on: March 12, 2023, 05:09 AM »
4nthony, it could if you were building them to have through dovetails in the first place.
What I was referring to though was the 3/8" overlay with half-blind dovetails style. That is far more common in dressers and other furniture, but could be in a kitchen. I suppose you could cut off the overlay portion and add a false front over it, but that's ia little beyond the scope of the original question.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
