Author Topic: H&K Custom Barn Doors  (Read 144512 times)
Offline TXFIVEO
Re: H&K Custom Barn Doors
« Reply #510 on: January 25, 2022, 04:37 PM »
Diamond Door built and installed in Ponder, TX…
Offline TXFIVEO
« Reply #511 on: January 27, 2022, 10:21 PM »
Pattern white door built and installed in Gunter, TX…
Offline TXFIVEO
« Reply #512 on: January 30, 2022, 07:00 PM »
Shiplap accent walls installed in Celina, TX using only the FESTOOL HKC to make the cuts…painting will be done tomorrow.
Offline TXFIVEO
« Reply #513 on: January 31, 2022, 09:13 PM »
Shiplap accent walls installed in Celina, TX and painted today..
Offline TXFIVEO
« Reply #514 on: February 01, 2022, 07:01 AM »
Double Diamond door built and installed in Celina, TX…
Offline TXFIVEO
« Reply #515 on: February 04, 2022, 05:55 AM »
Steel and clear glass doors built and installed in Gunter, TX…
Offline TXFIVEO
« Reply #516 on: February 13, 2022, 08:11 AM »
Knotty Alder door built and installed in McKinney, TX…
Offline Peter Halle
« Reply #517 on: February 13, 2022, 09:14 AM »
@TXFIVEO
Is it an optical illusion, or isn't that a rather narrow opening into the other space?  What is on the other side of that door?
Offline TXFIVEO
« Reply #518 on: February 13, 2022, 07:22 PM »
@TXFIVEO
The opening is 35” wide and 102” tall. The door is 39” wide and 103” tall.  The opening leads to another wing of the house that includes a couple bedrooms.
Offline TXFIVEO
« Reply #519 on: February 16, 2022, 06:01 AM »
Shaker doors built and installed in McKinney, TX…
« Last Edit: February 16, 2022, 06:03 AM by TXFIVEO »
Offline jobsworth
  • Festool Baby.....
« Reply #520 on: February 16, 2022, 10:33 AM »
Wow brutha you got a new career building those doors, you do a great job and man you are busy...
Offline TXFIVEO
« Reply #521 on: February 16, 2022, 05:00 PM »
Haha, the “hobby” has turned into a second job.  That’s for sure!  But it’s still fun!  And as far as being busy…busy is an understatement!!!
Offline jobsworth
  • Festool Baby.....
« Reply #522 on: February 16, 2022, 10:20 PM »
But you do do good work bro
Offline TXFIVEO
« Reply #523 on: February 17, 2022, 05:54 AM »
Thank you, I appreciate the kind words.  It’s been an adventure, that’s for sure.  The one consistent theme….I’m still learning new things!
Offline TXFIVEO
« Reply #524 on: February 17, 2022, 09:30 AM »
5 panel frosted glass doors built and installed in Haslet, TX…
Offline TXFIVEO
« Reply #525 on: March 02, 2022, 10:06 PM »
Flemish glass doors built and installed in Coppell, Tx…
Offline TXFIVEO
« Reply #526 on: March 12, 2022, 08:59 PM »
Eight doors installed in McKinney, TX….each opening has two stationary doors and two sliding.
« Last Edit: March 12, 2022, 09:01 PM by TXFIVEO »
Offline Vondawg
« Reply #527 on: March 13, 2022, 09:32 AM »
Now that’s an interesting installation with the lites lining up when open and letting in light open or closed…..very nice!
Offline TXFIVEO
« Reply #528 on: April 13, 2022, 10:27 PM »
Haven’t been on for a bit due to my orders….but here’s a sneak peek at some upcoming installs.  These reclaimed barn wood doors are 12’ tall!
Offline TXFIVEO
« Reply #529 on: April 23, 2022, 04:12 PM »
Metal and tempered glass doors built and installed in Northlake, TEXAS…
Offline Packard
« Reply #530 on: April 25, 2022, 06:49 PM »
I built a barn door for a bathroom.  I am hanging it this weekend.  Have you ever added a interior lock for a bathroom?  If so, can you offer a recommendation on the type of lock?  Advantages/disadvantages.
My biggest problem was carrying it up from the basement (18 steps) by myself.
Header is installed and door is upstairs.  I have to add the hardware to the header and mount.  But since it is for a bathroom a latching mechanism is suggested.
Thanks,
Packard
Offline TXFIVEO
« Reply #531 on: April 27, 2022, 10:56 AM »
There are several options for you. If it’s a single door I have primarily used hook system commonly found on fence gates, although I use more decorative ones.   For double doors you have many more options.  I’ll find some pics of both and attach.  Feel free to reach out if you need any advice on install.
Offline Packard
« Reply #532 on: April 27, 2022, 11:04 AM »
Thanks.  I have seen the hook system and there are "blacksmith" versions available. It seemed the easiest to install.
I will watch for your suggestions.
Offline TXFIVEO
« Reply #533 on: April 30, 2022, 08:44 PM »
Total of three doors built and installed in Landon Winery in Greenville, TX….the two large doors are in a bypass configuration while the third is a single door.  Very cool place…
Offline TXFIVEO
« Reply #534 on: May 02, 2022, 08:03 PM »
A total of (5) reclaimed barn wood doors built and installed in Historic Downtown McKinney, TX…(2) are 11’ tall and 5’ wide!  One is a cafe swinging type door…
Offline TXFIVEO
« Reply #535 on: June 06, 2022, 09:31 PM »
Steel and glass sliding doors built and installed in Frisco, TX…these two are 9’ tall and 4’ wide EACH!
Offline batmanimal
« Reply #536 on: June 06, 2022, 10:01 PM »
Those steel doors are 🤩
You have quite an impressive range!
I recently began working with metal out of necessity. I much prefer wood.
Anyway, thanks for sharing - always nice to see your work
Offline TXFIVEO
« Reply #537 on: June 16, 2022, 01:57 PM »
Thanks!  It’s nice to work with metal from time to time.  Something different
Offline TXFIVEO
« Reply #538 on: June 18, 2022, 02:48 PM »
“Diamond Doors” built and installed in Prosper, TX…
