Author Topic: Help on Spraying BM Advance/Regal Select  (Read 13002 times)
Offline Mace
« Reply #30 on: February 06, 2018, 08:24 PM »
I have a friend who is a great sprayer and he stopped using BM Advance. Said it runs on him like crazy.
I myself never used it but have sprayed other paints. My favorite is PPG Breakthrough. I spray it with my Graco Ultra handheld and it sprays beautifully. I put my gun on number 2 and move on the fast side.  If I'm spraying other paints like SW Pro classic I would put it on around 5-7.
I taught myself how to spray just by doing it and watching YouTube videos helped as well. I used to look around for old pieces of furniture like dresser drawers, bookshelves.... whatever I could find and take it home and practice my spraying.
I never try to cover anything with one coat but fewer light coats.... well now I can do things in one coat if I want but you get a better finish doing multiple coats.
Practice makes perfect.... well if not perfect it does make it a lot better.
Take care
Offline Scott Burt
  • Magazine/Blog Author
  • painter/writer/educator
    • Prep to Finish
« Reply #31 on: February 06, 2018, 08:28 PM »
The cure time is a real bummer. It is a nice looking and feeling finish, but rather soft and slow.
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #32 on: February 06, 2018, 08:40 PM »
BM Advance, sprayed with a 395 AAA.
Offline Alan G
« Reply #33 on: February 06, 2018, 09:00 PM »
Nice
Offline PaulH99
« Reply #34 on: February 07, 2018, 11:44 AM »
Did you spray these in place, or did you spray the parts and assemble after the paint dried?
-Paul
CT 26 • DF 500 • ETS 125 • KS 120 • OF 1400 • PS 420 • RO 125 • TS 55 R
Offline JCLP
« Reply #35 on: February 07, 2018, 03:01 PM »
Very nice Tom. Maybe I should get a Graco 395 Finish Pro II as well.
JC
Offline JCLP
« Reply #36 on: February 09, 2018, 04:25 PM »
I'm back. Can't stay away from this punishment. Needed a project so I built a new spray booth, 7'x7'. Was able to make air tight and I created an air chamber behind the filters for maximum air extraction. No fear of overspray going into the house. I posted a video on my instagram account, woodworking_by_jc.
Check it out.
Cheers,
JC
Offline gunnyr
    • Compass Custom Creations
« Reply #37 on: February 09, 2018, 04:46 PM »
Check it out.
Cheers,
JC
Hah!  My booth ended up 7x7x7 also.  It should really be 7x7x6'8" so that it would fit beneath my garage door tracks.  Mine is made of 5 panels that I bolt together with carriage bolts when in use.  I break it down and store it above my garage door when not in use.  I use furnace filters for the intake and exhaust.  I spray only water based paints and finishes so I am not concerned with combustion.
I am new to spraying but encouraged with my results so far.  I have sprayed PPG Advantage 900 with limited success, and Deft Satin Poly with much greater success.  I have a MiniMite4 rig with tips from 1.0 to 1.8.  Seems the 1.5 works well with latex for me when thinned 20%.
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|DUO-SET|SYSLITE KAL II
Offline tjbnwi
« Reply #38 on: February 09, 2018, 08:48 PM »
Yes and no.
The parts were primed, assembled, filled, primed, painted, installed, filled, caulked to wall, touch primed, sprayed 2 coats.
The exterior parts are Boral I machined, coated with BM Aura Exterior, finished as above.
Offline tjbnwi
« Reply #39 on: February 09, 2018, 08:54 PM »
JC
It can be a cruel mistress. Even with my experience it took me a couple of attempts to get the hang of the unit. 6" becomes 12", overlap changes, pass speed changes, listening to what it tells you is a different story in an unknown language until you learn its language.
« Last Edit: February 09, 2018, 09:02 PM by tjbnwi »
Offline JCLP
« Reply #40 on: February 14, 2018, 11:43 AM »
Why is this so difficult. Even with an airless, 312 tip, no thinning, 12-14 inches away from surface and no success. I even tried laying thin and laying it down thick and I can get a smooth surface. It's got to be the colour.
totally confused,
JC
Offline Lettusbee
« Reply #41 on: February 14, 2018, 11:50 AM »
Have you tried a different brand of paint yet?
Sherwin pro classic is easy to get good results with when spraying?
Sent from my SM-G950U using Tapatalk
Offline JCLP
« Reply #42 on: February 14, 2018, 11:58 AM »
I have tried spraying pro classic in the past with no success. There is something I'm doing wrong and I can't figure it out. I have done other projects in the past with advance and regal select with great success, that is what is so frustrating. The other issue, is that other brands are not able to match the colour the client wants perfectly. Some pieces that I have to spray are very close to existing grey colour. When others, Sherwin Williams and Dulux try to match the colour they both end up having a redish hue to them. Also, as there is brushing involved, I need to use a pint that is brushable and sprayable. If there was no brushing involved in this project I probably would use Kem Aqua from SW. I have even tried some of the commercial paints from BM, but they too have difficulty matching the colour.
JC
« Reply #43 on: February 14, 2018, 12:41 PM »
JC
If the exact same finish is installed in a different plane it will look quite different. If the pieces you will add are not installed co-planar with the existing stuff close is good enough.
Offline JCLP
« Reply #44 on: February 14, 2018, 05:56 PM »
Here is a sample of what I'm getting.
BM Advance, no thinning, colour is Stone Harbor # 2111-50, sheen is pearl ( satin in the US ) tip size is FFLP 314. Airless is Graco Ultra Handheld.
That is what the entire panel, 18"x24", looks like. Any ideas on what is going on?
The image of the sun is my light reflecting off the panel.
Thanks,
JC
« Last Edit: February 14, 2018, 05:59 PM by JCLP »
Offline Pnw painter
« Reply #45 on: February 15, 2018, 02:03 AM »
What is the substrate? What primer are you using? What grit sand paper are using before spraying Advance? After you finish sanding are you wiping the surface with a rag or blowing it off with compressed air?
It’s also possible that the issue has something to do with your spray booth. Maybe you exhaust fan is pulling too much air when you’re spraying?
Have you discussed the issues you’re having with your BM rep? I’d recommended having them visit your shop and watch you spray a sample.
I’d also try using another product from a different manufacturer. If you get the same results than at least you know it’s not the paint that’s causing the issue.
Offline Pnw painter
« Reply #46 on: February 15, 2018, 02:10 AM »
After spraying the paint does paint look like glass when it’s wet? When do all the micro bubbles appear after you’ve sprayed the paint?
Offline Mikeoutrage
« Reply #47 on: February 15, 2018, 06:50 AM »
I have been watching this for some time now. I am no painter but have done a little for time to time. Are you sure there are no contaminates from the gun from cleaning? Are you pouring the remainder of the paint back into the can? If so it could have been contaminated the very first use? Baffled. I will keep watching. I liked BM advance when I sprayed it right up to I learned about the 30 day plus cure time.
Offline JCLP
« Reply #48 on: February 15, 2018, 07:04 AM »
The gun is really clean. I even had Fuji provide me with several new guns to see if that wat the issue, but I get the same thing. The remaining paint is thrown away. This is why I am going through so much paint. the paint store loves me.
JC
Offline JCLP
« Reply #49 on: February 15, 2018, 07:07 AM »
If you have ever been to a skating rink, the paint looks like when a Zamboni just finishes cleaning the ice. Wet as a lake. The bubbles appear almost immediately when tha paint hits the surface. It really gets bad after about 15 minutes of drying.
JC
Offline neilc
« Reply #50 on: February 17, 2018, 06:21 PM »
Look forward to hearing / seeing what you found out!
Offline Pnw painter
« Reply #51 on: February 18, 2018, 02:32 AM »
I’d guess your paint was reacting with the primer or fillers you’ve been using. Either way it’ll be interesting to find out what the fix is.
Offline jmbfestool
Re: Help on Spraying BM Advance/Regal Select
« Reply #52 on: February 18, 2018, 04:03 PM »
Send me a tin of the paint your using I’ll spray with it and see if I get same problem.
Or better still see if some one local to you will spray with it.
*********************************************************************** [thumbs up]UK members click me
Offline JCLP
« Reply #53 on: February 21, 2018, 02:17 PM »
This thread was moved to the Member Projects folder because I was not able to see it anyore in the Finishing & Painting folder.
Anyway. Well as many of you know, along with BM Advance I was also trying to spray BM Regal Select and this paint, which is really thick, has proven to be more of a challenge then Advance.
Well, by thinking outside the box and ignoring common HVLP turbine rules, I believe I have figured out how to spray BM Regal Select pearl Finish. I have tried 5 test panels and all of them look like the one in the photo. The pencil is there so the camera had something to focus on as the surface is too smooth. This is after 5 hours of drying.
Cheers,
JC
« Last Edit: February 21, 2018, 02:20 PM by JCLP »
Offline Alan G
« Reply #54 on: February 21, 2018, 03:09 PM »
Looks great! Glad you were able to figure it out. Can you share what you did for both the Advance and Regal?
Offline Jasonj888
    • Blog about woodworking and family life.
« Reply #55 on: February 23, 2018, 03:13 PM »
I don't have nearly as much experience spraying paint as the rest of the folks that have commented, but I find myself frequently breaking the rules and thinning my paint 15%, or even a little more. I've painted quite a few vanities with several varieties of paint and haven't had a customer complaint (including in my own house, and my wife is a critical client). The added thinning seems to help the paint smooth out, I suppose it just stays wet longer. I generally use my Lex-Aire with a  1.3 mm tip.
Offline JCLP
« Reply #56 on: February 23, 2018, 03:24 PM »
Hi Jason,
Good  point. Glad to see I'm not the only one thinking outside the box. I think that existing procedures for HVLP turbines are out of date as they were thought of before these new thick waterborne were common stream. As well, when you are using 3MPPS system, the rules change a bit.
I use a 0.8mm needle when spraying thick Waterborne paint from Benjamin Moore. Great finish just like the photo I posted.
Cheers,
JC
Offline JCLP
« Reply #57 on: February 23, 2018, 04:10 PM »
One of the issues I had was that my air exhaust was sufficient, so I need to design a new way of extracting air. So I decided to use an air chamber powered by 2 - 20" variable speed fans that both have the capacity to draw out 1900cfm's if needed.
The chamber in the photo is 4'x4' and 2' deep. The two fans lay horizontally at the top of the chamber and everything is exhausted out the basement window. The front of the chamber will have filters installed to catch the dry spray before it goes outside.
At the entrance, I added a half door so I could controll how much air cross the surface of the panel. the height of the door is very clse to the height of the panel that I will be spraying on my rotating table. The bottom of the door is 6" from the floor, so the air can also come in and cross the floor to the chamber.
Due to fast drying Regal Select, it was important that I was able to limit the air crossing the panel but still be able to exhaust the bounce back and/or overspray that happens.
The test panel in the photo I posted was painted in the new booth.
Cheers,
JC
« Last Edit: February 23, 2018, 04:13 PM by JCLP »
Offline JCLP
« Reply #58 on: March 05, 2018, 07:39 AM »
Good morning,
BM Advance sprayed with a Fuji Q5, T75G gun, 1.3 needle and cap.
Cheers,
JC
