Here's the first of three pieces commissioned by a client for her wonderful 1850's house. I'm sorry I can't show you the fully built-up dresser - but the top section weighs 95kg (210 pounds) and I can't lift it
Maybe a clever Photoshop member on here can weave his magic ..... It's ready to go apart from some gilded lettering which will be applied above the trefoils on the upper section pilasters. The heavily distressed/aged paint finish was as per the lady's request - 'Make it look like it's always been here'.
The basic specs;
Carcasses, shelves, other bits = 18mm MRMDF.
Rear facings = 14mm Scandinavian redwood, machined into V-groove T&G.
All mouldings = Redwood, all machined as customs on my spindle moulder. I've made enough for all 3 pieces.
Face frames, drawer & door fronts = 25mm Redwood.
Drawers = 18mm kiln-dried oak verticals, crown-cut oak veneer over 12mm plywood bases. Hand-cut dovetails.
Drawer hardware - Grass Dynapro liquid-damped soft-close undermount.
Base pilasters = A commercial Howdens stair newel post ripped in half on the bandsaw.
Door infill = Cloverleaf perforated steel sheet.
Pullout vegetable baskets = IKEA !!!
Hardware = 'Old Forge' brand lacquered cast iron.
Top = Finger-jointed 40mm oak block with oak edge mouldings.
Paint = Craig & Rose 1829 eggshell acrylic.
Patinated/aged using Finneys patinating wax.
Top finished with Rustins solvent-based dye + 4 coats clear Fiddes wax.
Kevin
