Project looks great Matt.I used the TS55 jointing technique and it work well. Straightens the edges and self corrects if the blade isn't perfectly 90 degrees. Given you can adjust the distance between tops on the track tubes, how about dogs at the end of each piece and double sided tape to secure them?RMW
@Richard/RMW can you give more info on TS55 jointing technique?Thanks
Mike you just butt the two pieces to be joined edge to edge, position the guide rail so the saw kerf straddles the joined edges, and the cut is basically mirrored on each piece. If the blade is tilted slightly the tilt cancels itself out. The edges have to be pretty close to start with since the material removed for each edge is only half the kerf. IIRC I first cut each board so then followed up by recutting at each joint. Not my idea, but I forget where I stole it from. RMW Quote from: Mike Goetzke on March 29, 2022, 04:13 PM @Richard/RMW can you give more info on TS55 jointing technique?Thanks
Quote from: Richard/RMW on March 29, 2022, 02:45 PMProject looks great Matt.I used the TS55 jointing technique and it work well. Straightens the edges and self corrects if the blade isn't perfectly 90 degrees. Given you can adjust the distance between tops on the track tubes, how about dogs at the end of each piece and double sided tape to secure them?RMWDang it that's a great idea. Thanks Richard.
...What I don't like about that is the boards are much narrower than the track so I have to double them up side by side to give support. It makes clamping tricky....
Matt, if you haven't already seen this method, it's another option. RMW
Matt - I like the design too. Nice and clean and somewhat rustic. Looks like you had time to polish up your Domino joining skills on this project. Can't wait to see the final result!Mike
Nice-looking project, Matt! How are you going to finish the cherry?
Dunno, after reviewing your photos again I see a disturbing lack of saw kerfs in the MFT tops... Reminded me of the last time we both shared photos on the same thread and I ended up polishing my filthy routers afterwards out of embarrassment. I'm playing around with some new MFT tops to replace the monster cart I disassembled and your setup gave me some ideas. I've toyed with buying track tubes but have been limping along with chunks of 80/20. Any overriding benefits to the tubes?RMW
Looks great so far! How do you plan to attach the Xes to the ends?
I probably skipped some steps but with young kids and spring break this week I don't have the luxury to take pictures of everything. Very happy with how it is shaping up to this point and I'll do some final tweaking before working on finishing.Matt
Quote from: DynaGlide on April 04, 2022, 12:23 PMI probably skipped some steps but with young kids and spring break this week I don't have the luxury to take pictures of everything. Very happy with how it is shaping up to this point and I'll do some final tweaking before working on finishing.MattLooks great. I would reconsider dropping the dfecorative X parts. The sides look a bit baren without it, now it is complete.Or think up some other decorative fill, not have to be X ... maybe even simple vertical "poles" would work out well. The decorative X in the original also "hides" the shoes placed in there when looked from side, makinge the whole think a bit more "woody". Having something "woody" in that area just seems right, me thinks.
In cases like these I like to choose a low-tech approach and make an oversize piece and then snug up to it with a plane. What helps is the Veritas Adjustable Shooting Board I have. I use a bevel square to get the precise angle and set the shooting board to just that angle. To get the angle I do as you did and just clamp the wood to the workpiece. Try to err on the cautious side and be patient while getting close to the size you need. Lots of fitting...https://www.leevalley.com/en-us/shop/tools/jigs-guides-and-fixtures/110737-veritas-shooting-board
That still means Matt has to create cuts at the right angle and the right distance. And for 2 semi-diagonals on each side at that. More work and as far as I can see not much easier to do. Just one diagonal per side should be enough for stability. You'd loose symmetry, but it would mean less work.
