Author Topic: Entryway bench  (Read 7697 times)
Offline sawdustinmyshoes
Re: Entryway bench
« Reply #60 on: April 25, 2022, 03:31 PM »
For years I've used this shop-made version of turntable and placed items on horizontal surfaces with painters pyramids.
Re: Entryway bench
« Reply #61 on: April 25, 2022, 03:36 PM »
Love the look of the top.  I just finished two blanket chests with nearly identical tops (cherry and breadboard ends).  However, I rushed the fininsh process of the tops and sprayed on a day that was too cool.  I've been dissatisified with the results and tried to buff it smooth with Abralon 2000 followed by paste wax (no wax was too dull).  But it's just to shiney  and there is contrast along the edges that I avoided with the Rotex to avoid sandthrough.
I've been on the fence about refinishing them (chemical stripper), and seeing how great yours looks pushed me over the edge for the redo.  Pics attached with BLO only followed by the one that gives me heartburn. Wood is air-dried cherry that was stored for generations before I purchased it about 15 years ago.  I'm slowly using it up.  It works wonderfully.
« Last Edit: April 25, 2022, 03:46 PM by sawdustinmyshoes »
Offline DynaGlide
Re: Entryway bench
« Reply #62 on: May 03, 2022, 02:18 PM »
Here's what I had to work off of:
Versus how it turned out:
It was a fun and challenging build. I'll give it another week before I put it into its new home upstairs. I still need to make the buttons to attach the top.
Matt
Instagram @matts.garage
Offline Mike Goetzke
Re: Entryway bench
« Reply #63 on: May 03, 2022, 02:52 PM »
@DynaGlide
Came out perfect! Looks like it has some heft to it  [big grin] be careful bringing it upstairs.
Offline mike_aa
Re: Entryway bench
« Reply #64 on: May 03, 2022, 02:56 PM »
@DynaGlide It's truly been a joy following along on all of your builds and this one is no exception!  Great project!
Thank you for sharing.  I always learn something!
Mike A.
Offline DynaGlide
Re: Entryway bench
« Reply #65 on: May 03, 2022, 03:25 PM »
Thanks guys, I appreciate it.
Some comments: pre finishing was the way to go on this one. I was able to get a nice finish everywhere except inside those X areas. That's just a tough spot to lay down smooth. I debated waiting 21 days (cure time for full hardness on GF High Performance) before clamping. I got antsy and did it in 8 days. I cut up an old t shirt and used it in between the clamps and the bench. Worked out fine.
The joints aren't dead on perfect but that's because I don't have a jointer. They're good enough that only I'll notice the one or two that didn't close up completely, though.
I was pretty nervous spraying Shellac and GF High Performance since I never worked with either before but honestly, it couldn't have gone better.
Next project is going to be the Wood Whisperer Hybrid workbench with a Benchcrafted leg vise. I've gotten the itch to integrate hand tools more into my workflow and want to make myself a solid bench. I'll be leaning on my neighbor to assist with squaring up the lumber for that.
Matt
Offline Rick Herrick
Re: Entryway bench
« Reply #66 on: May 03, 2022, 10:57 PM »
A beautiful piece Matt.  Should last a lifetime. Sure looks heavy...
Offline DynaGlide
Re: Entryway bench
« Reply #67 on: May 04, 2022, 07:35 AM »
Thanks @Rick Herrick . It is heavy. Luckily I should only need to move it once.
Offline Sparktrician
Re: Entryway bench
« Reply #68 on: May 04, 2022, 08:25 AM »
Spectacular, Matt!!!   [smile]
- Willy -
Offline FestitaMakool
Re: Entryway bench
« Reply #69 on: May 04, 2022, 05:13 PM »
Congratulations - it came out great!
Offline Crazyraceguy
Re: Entryway bench
« Reply #70 on: May 04, 2022, 06:52 PM »
It came out great. The Xs were worth it. The beauty of heavy is that it is stable.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline DynaGlide
Re: Entryway bench
« Reply #71 on: May 05, 2022, 03:42 PM »
I made up some buttons using some scraps from the project. I had to plane down some 3/4 stock to 5/8 so I could use 1" screws. The top is 3/4" thick and doing this allowed the screws to penetrate half of the thickness of the top. I felt 1/4" into the top wasn't enough and anything more than 3/8" I'd risk splitting the top.
To install the buttons I ended up gluing the dominos into the buttons since the original screw location would've been too close to a glue line on some of the top panel joints. Original plan was to screw through the dominos in the buttons to lock them in place. I put 3/16" spacers between the button and rail to allow for some seasonal movement. Probably more than needed but still plenty of tenon in the rail mortise.
Done just in time for Mother's Day, too. I'll move it upstairs Sunday with some help.
Matt
Offline Richard/RMW
Re: Entryway bench
« Reply #72 on: May 05, 2022, 06:34 PM »
Beautiful piece Matt, destined to become a family heirloom. Nice work.
RMW
Offline DynaGlide
Re: Entryway bench
« Reply #73 on: May 05, 2022, 07:37 PM »
RMW
Thank you Richard  [big grin]
Offline rvieceli
Re: Entryway bench
« Reply #74 on: May 05, 2022, 08:11 PM »
Turned out very nice.
Great work Matt. Being cherry, that will develop a nice rich color as it gets exposed to UV.
Ron
Offline Tim Raleigh
    • Oakville Cabinetry
Re: Entryway bench
« Reply #75 on: May 10, 2022, 12:12 PM »
@DynaGlide Looks great! Thanks for posting your build.
Adding the X I think made the difference.
Tim
Offline Tim Raleigh
Re: Entryway bench
« Reply #76 on: May 10, 2022, 12:14 PM »
Matt
I look forward to seeing your build on that.
Tim
Offline DynaGlide
Re: Entryway bench
« Reply #77 on: May 10, 2022, 12:16 PM »
@rvieceli @Tim Raleigh
Thanks guys I just realized I never posted a final shot:
It has a little give in the middle when sitting on it. I'll probably reinforce that area with a 2" wide or so strip of hardwood across the long rails. Kids and wife are very pleased with how it turned out.
Offline Tim Raleigh
Re: Entryway bench
« Reply #78 on: May 10, 2022, 12:25 PM »
Interesting. You wouldn't think so based on the construction.
Tim
Re: Entryway bench
« Reply #79 on: May 10, 2022, 04:55 PM »
Excellent work, Matt!!!   [big grin]
- Willy -
Offline mike_aa
Re: Entryway bench
« Reply #80 on: May 10, 2022, 05:00 PM »
Beautiful!  Fits the space like a glove.
Mike A.
Offline TSO_Products
    • TSO Products LLC
Re: Entryway bench
« Reply #81 on: May 22, 2022, 08:26 AM »
Matt,
you continue to inspire.
Welcome to the world of Hybrid Woodworkers!
Hans
PS: - and thanks for taking the time to document and share the build and the thinking behind some of the decisions you made - all very helpful!
