Author Topic: Drill Collars  (Read 930 times)
Offline Birdhunter
Drill Collars
« on: May 26, 2022, 07:27 PM »
I needed some drill collars so ordered a set from Amazon. They were trash. Thanks to Amazon, the return process was easy.
I watched a video on a guy making his own.
I cut off segments from a 1” dowel. I chucked them in my lathe and used a center drill to start the drilling. I drilled through each segment using the selected bit size.
The key is to let the bit extend out the segment by the depth you want to drill then butt them against the drill chuck.
The trick works.
Birdhunter
Offline Crazyraceguy
Re: Drill Collars
« Reply #1 on: May 27, 2022, 05:21 PM »
The trick works.
That's what I usually do, but it's still not great. The flutes pack up with debris and reqires some fiddling after every few holes. It's no worse than metal stop collars as far as that goes though and can't slip to change your depth.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline FestitaMakool
Re: Drill Collars
« Reply #2 on: May 27, 2022, 05:50 PM »
Was it of this type?:
.. Was thinking of trying out one set, similar to this in the photo.
And yes, the Saturn rings packs sawdust pretty well..
Re: Drill Collars
« Reply #3 on: May 28, 2022, 06:54 AM »
I was thinking the set-screw type like a Kreg jig, but they all still suffer the pack up thing. The Kreg doesn't because the jig itself stops the bit rather than the actual workpiece.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Offline ChuckS
Re: Drill Collars
« Reply #4 on: May 28, 2022, 10:04 AM »
I've used the plastic drill stops (about $10 Cdn a pair from LVT), and they won't mar surfaces like metal collars. Made of plastic, they're not as robust as metal ones or shop-made hardwood stops, so use them with care, and don't push the drill too hard into the workpiece. I like their adjustable feature for bits of varying diameters.
Re: Drill Collars
« Reply #5 on: May 28, 2022, 10:11 AM »
I like these...in the lower LH corner.
They're Slipstop collars with a nylon end to prevent marring wood.
https://woodworker.com/18-id-slipstop-collar-mssu-908-295.asp?GF=908-449&gclid=EAIaIQobChMI4f2J3q6C-AIVcwNlCh0jPAGzEAQYAiABEgLXj_D_BwE
Offline ChuckS
Re: Drill Collars
« Reply #6 on: May 28, 2022, 10:11 AM »
Snip.
I seldom have to return any purchases (online or in store), but when I do, Amazon's return process is pretty simple and easy. Often they also offer a replacement option for a defective item, and that also often solves my problem.
Offline Econoline
Re: Drill Collars
« Reply #7 on: May 28, 2022, 01:53 PM »
