Thanks guys. Almost went with barn door hardware since I installed a door with it adjacent to bathroom. In the end tried the slide idea on a prototype and liked the look.
I made a simple jig to align slides for mounting. You need latch mechanism on side facing out for access to it! I used wood the same thickness as slide glued to heavy paper aligned with slide. Ran a block of wood over paper to emboss mounting holes. Marked each side with different colors to keep track of each side and direction of slide. Used wood on the jig as a guide on the cabinet side. Alignment was important. You might come up with an easier way than I did.
