Author Topic: Drawer construction using dominos  (Read 1638 times)
Offline Woodworkingnut
« on: January 19, 2020, 05:15 PM »
Does anyone use the (500) domino cutters for drawer construction?
I have for several years now and find it extremely quick to do with very little effort(marking). I built a jig and can cut all the domino locations in four boards in 4-5 minutes consistantly. It is the only method I use now for drawer construction.
Offline Bernmc
Re: Drawer construction using dominos
« Reply #1 on: January 19, 2020, 05:40 PM »
pics of the jig? I've got around 4.7 billion drawers to make...
Online TheTechRunner
« Reply #2 on: January 19, 2020, 10:14 PM »
Definitely need some more info on that! Can you post some pictures along with how you construct your drawers? I just got done making 11 drawers using 4x20 dominos in 1/2" plywood but I'm not necessarily sold on my construction method. Thanks!
Sent from my SM-G950U using Tapatalk
« Reply #3 on: January 21, 2020, 04:55 PM »
Hi, Give me a few days to put a few pictures together. Hope to have it to you by Friday.  I was just finishing up on a cyclone system for my Mini.
Offline vkumar
« Reply #4 on: January 21, 2020, 05:18 PM »
Looking forward to the pictures.
Vijay Kumar
« Reply #5 on: January 24, 2020, 11:23 AM »
I was just searching the web and found that no one makes the drawers the way I do. So go check it out. This is my first video so don't be to critical. More importantly it so fast and easy to make drawers this way I was surprised I didn't see tons of videos showing this method. Hummmm...made me wonder about all my other Festool tool improvements. I plan on making more videos. in the search box on youtube type in   Domino Drawers in 3 minutes   Please let me know what you think of this method. Like I said it is simple and fast!
Offline elfick
« Reply #6 on: January 24, 2020, 11:27 AM »
That's funny... doesn't seem to want to let me past a youtube link...   youtu.be/Tro7ecIPP-o
« Reply #7 on: January 24, 2020, 11:43 AM »
Here are a couple on the top shelf of the work bench. There's probably 20-25# of stuff in each one and they need to be lowered down to the bench each time to get what I want. I made them about 6-7 years ago and they're still tight/rigid after all the use.
Here are some under-bed rolling drawers using bed box wheels.
« Reply #8 on: January 24, 2020, 12:09 PM »
I just went to youtube and copied the link. hope this works...
Offline jarbroen
« Reply #9 on: January 24, 2020, 12:14 PM »
For those of you that have built boxes with Dominos have you also tried using dado sides/rabbet f&b?
I have the Domino and recently got a lot of practice when building 2 loft beds, a dining table and other odds/ends.  It's definitely way faster than any method of M&T I've tried and gives some unique options and efficiencies.
What I'm wondering is whether the Domino drawer box method is any faster or more efficient than the dado/rabbet.
Both are excellent at alignment and helping with squareness, less clamps/aids for assembly, and much faster than box joint or dovetail.
I don't want to derail this thread from the Domino method, just wondering how it compares to other options.
p.s. Cheese - I wish I'd seen your post about bed box wheels a week ago!  I could have used those for loft bed drawers instead of slides.
« Reply #10 on: January 24, 2020, 12:20 PM »
« Reply #11 on: January 24, 2020, 12:43 PM »
It is much faster than M&T method. Because your not marking parts and adjusting tools and bits. Using the correct amount of Dominos make a box of equal strength. It all comes down to your time and how long you want to spend setting up your tools. I can cut a drawer box in about two minutes without marking a single piece and more importantly everything is flush . The Domino tool is very expensive, but it's one heck of a tool!
Offline cpw
« Reply #12 on: January 24, 2020, 01:06 PM »
The jig you made to hold the domino in place is great!
On the small number of domino drawers I've done, I have made the sides longer and the front/back shorter.  That way the edge of the plywood will die into the false front instead of sticking out the side.
Offline vkumar
« Reply #13 on: January 24, 2020, 01:17 PM »
Nice video. Nice jig.
What is the plywood thickness, and the size of the dominoes? Also the dominoes will not offer much strength in the pull direction. How is the bottom attached?
Vijay Kumar
« Reply #14 on: January 24, 2020, 01:23 PM »
This style of bed box wheel has always been very popular, they were available everywhere. Then about 4-5 years ago they suddenly became unobtainable. They actually disappeared and no one offered them including Häfele.
I've noticed now that recently Häfele has reintroduced them however in a different style. While this new style takes up more real estate, it is a better design as the earlier version sometimes loosened up after a lot of use.
https://www.hafele.com/us/en/product/bed-box-caster-rigid-35-mm/000000170001a46e00020023/
Offline TinyShop
« Reply #15 on: January 24, 2020, 03:06 PM »
I concur with @vkumar - the drawer front will eventually pull out since it's not inset and domino'ed into the sides . That's why you were unable to find anyone else who builds drawers this way - it's a recipe for structural failure.
That said, I admire your method of bolting the domino down to the work surface - I think I'll adopt that method along with using clamping elements to hold the parts fast to the face of the domino. Thanks for sharing! :)
« Last Edit: January 24, 2020, 03:11 PM by TinyShop »
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
« Reply #16 on: January 25, 2020, 06:29 AM »
Have faith in the Domino, modern glues , and proper gluing. It will hold well. If not just rotate the box 90 degrees and the domino location is now the way you are comfortable with.
Offline ChuckM
« Reply #17 on: January 25, 2020, 09:24 AM »
 Yes, the proper solution is to rotate the orientation, if the intention is to build to last.
« Reply #18 on: January 25, 2020, 10:03 AM »
Like others have said, you want to place the Domino in shear to the load direction. That way the joint is supported by the shear strength of the Domino and the strength of the glue.  Belt & suspenders... [smile]
Offline jobsworth
  • Festool Baby.....
« Reply #19 on: January 25, 2020, 10:34 AM »
I just clamp them to my MFT at 90 degrees like clamping it in a dovetail jig and domino them together very fast and easy.
You could always find a old used dovetail jig craigs list swap meet etc and use for the domino drawers.
Using the mft is just as fast if ya ax me
« Reply #20 on: January 25, 2020, 06:36 PM »
Here's the jig I made for the under-bed storage boxes. I used all scrap wood and a pair of DeStaco clamps.
I decided to use prefabricated drawer sides. They come prefinished, contain a rabbit for the drawer bottom and will be tucked under the bed for storage so no one will ever see them. Just cut them to length.  [smile]
I used a 5 mm cutter.
Adjust the height of the DF 500 fence so that it will place the mortise in the center of the material you're using. Get as close as you can but you don't have to be exact because everything uses the same surface for registration.
Place a drawer side in the jig, flush it up with the end of the jig and then clamp it down.
Hold the DF in a vertical position
Make sure the side of the DF is against the LH oak stop, plunge.
Move the DF over and make sure it is against the RH oak stop, plunge.
This is the result, 2 mortises that will be consistent because your using hard stops for left-right movement and the base of the DF is always registering the same height.
Now to the end mortises.
Rest the fence of the DF on top of the material making sure you're against the LH oak stop, plunge.
This is the result.
« Last Edit: January 26, 2020, 09:20 AM by Cheese »
