Author Topic: Domino, white oak and sipo tenons  (Read 2349 times)
Offline Rick Herrick
« on: December 24, 2021, 09:21 AM »
I am planning my first outdoor project which is a couple of side/end tables with a 12x12 tile top.  I want to use white oak.  The plan is from Woodsmith and they used pocket holes.  I have used them many times but I don't really want to use them on this outdoor furniture.  I couldn't find their 'blue coated' screws in the right size and I had read that their stainless steel screws are softer and could be problematic.
I am thinking the Domino is a better solution.  I have a bunch of 8mm sipo, that I over bought for another project.  The intended thickness of my material is 3/4".  I know the 8mm breaks the 1/3 rule so looking for opinions on whether or not this could be an issue.
Offline ChuckS
Re: Domino, white oak and sipo tenons
« Reply #1 on: December 24, 2021, 09:40 AM »
8mm dominoes are totally acceptable for 3/4" hardwood (6mm for plywood). Your Domino machine manual says so too. Check the related page there (p. 10?).
« Last Edit: December 24, 2021, 09:46 AM by ChuckS »
« Reply #2 on: December 24, 2021, 10:07 AM »
Thanks Chuck.  I did just find that section:
It is acceptable to use a tenon that is slightly thicker than 1/3 when the width of the Domino tenon is relatively narrow compared to the width of the joint. This is why 8mm Domino tenons are the most common for joining 3⁄4-inch lumber.
It did not specifically say hardwood but the associated paragraphs do talk about softwood and plywood, so this statement appears to be hardwood related.
Offline Crazyraceguy
« Reply #3 on: December 24, 2021, 03:37 PM »
To me, lumber was the key word in that statement. I don't think of plywood (or any other sheetgoods for that matter) as lumber.
I generally use 6mm for 3/4"  sheetgoods. That can be 18mm or 19mm depending on specific type.
Those are the ones I stock in large quantities. Thicker solid wood items get either 8mm or 10mm, again based on size/application. Once in a while a few 5mm get into some small projects. I still have most of the original bag of 4mm. I bet I have only used 30-40 of them.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Online Birdhunter
« Reply #4 on: December 24, 2021, 09:21 PM »
I’d use a thin coating of glue on the tenons as you don’t want the hydraulic pressure to blow out the wood as you are using large tenons. I use TB III on outdoor projects. It seems to hold up as well as epoxy.
Birdhunter
« Reply #5 on: December 25, 2021, 09:01 AM »
Thanks for the reminder @Birdhunter .  I have been doing a lot of 4mm tenons in some 1/2" Baltic Birch and man, you need to get the amount on the tenons just right to keep from having problems.  Hoping though, that the tougher white oak will be a little more forgiving.  Also going to see if my stock is thick enough that I can plane it to 20mm instead of 3/4" just to help a little bit more.
Offline ChuckS
« Reply #6 on: January 03, 2022, 06:30 PM »
Snip.
I've used the 5mm cutter in half a dozen projects, but only three with the 4mm cutter. In one of them, I used the 4mm cutter to cut a slot for a utensil handle. The Domino Joiner makes a good "drilling" tool.
« Last Edit: January 03, 2022, 06:36 PM by ChuckS »
