Author Topic: diagonal grain direction again.  (Read 2117 times)
Offline Crazyraceguy
« on: August 11, 2023, 06:05 PM »
Apparently, the owner of a new gas station visited one of the Duchess stations we did last year, and liked the pattern. So, it gets repeated in the new one, at least partially. The job is being done in two phases and the first one is the same. As far as I know, the second phase might be a different color/pattern, but hasn't been officially approved yet.
This first phase is just a coffee bar, which is mostly cabinets in a straight run. The second is more of a cashiers station, but I haven't seen the drawings for that yet.
These cup dispenser boxes are actually separate 36" units and everyone would be fine with them laminated individually. However, that would leave an ugly (IMHO) vertical seam, cutting through the angled woodgrain.  Angled grain needs angled seams and they totally disappear.
Do you see it?
A clue
The floor looks especially dark in this pic for some reason and so does the laminate. The lighter first pics are more accurate.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
TS60
Offline luvmytoolz
Re: diagonal grain direction again.
« Reply #1 on: August 11, 2023, 08:41 PM »
Nice work CRG!
« Reply #2 on: August 12, 2023, 02:27 PM »
Like some kind of dummy, I left out the important part. Those edges were cut with my TS60, using the original blade. It cuts a beautiful straight line.
I normally straighten long edges with a huge 5' x 12' vacuum table CNC machine, using a 1/4" downcutting bit. These smaller joints get the track saw, since it's capable.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
TS60
